LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,909
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
The statement about if you have power and traction and the pulled load exceeds your tractors pulling capacity is just plain wrong
If you are pulling from a drawbar below the rear axle the front will be forced down not up
Draw the force vectors
We did hundreds of times in engineering school
Up violates the laws of physics
Andy
It is not wrong, I have seen it happen, I have had it happen.
You can draw all the force vectors you wish too,
when you start to calculate the rotational torque applied to the wheel and hub as compared to the front end weight and a drawbar that does not stick out beyond the outside of the tires we can discuss this again,
till then you are just plain incorrect.
Lou
