Pull from the front or the rear?
/ Pull from the front or the rear? #82
I think not as easily broken as a chain. I like to lay a horse blanket across the cable when pulling. I've never broke a chain myself but have heard that not the best to pull with.
/ Pull from the front or the rear? #83
Somewhere on site is discussion on nylon tow straps vs snatch straps... Either can release with great intensity and cause injury... A cable also can cut like a sword.... Chain?... Have tracks up tailgate of my pickup where a link gave way under strain and slapped back of truck....
Any tow device when over stressed can cause damage or injury if stresses to point of failure.... JUst think a little about what you are doing....I uses term of "situation awareness" in a discussion and got jumped on by self appointed expert, but yes you have to be aware of whatever you are doing and limitations of devices you are using....
Dale
/ Pull from the front or the rear? #84
I've broken straps, ropes and steel cables. I've never broken a chain. I'll say "yet", though, as anything's possible. ;)
/ Pull from the front or the rear? #85
I have broken several chains in my life. Have only had one do anything crazy. The fact that they are made from rigid material limits the amount of energy stored.
/ Pull from the front or the rear? #86
This thread has some factual info, a bunch of hysteria and some nonsense.
Yes, you should try to pull from the fixed belly mounted drawbar most of the time,
that is your most stable pulling point. Can you use a 3 point drawbar? Certainly
they have been used many times, can they be more hazardous? Most certainly.
Any tractor can and will rear up in the air under certain conditions,
1) good traction
2) a hard pulling load
If the pulled load exceeds your tractors pulling capacity but you have traction and power your tractor will rotate the front up,
an unmoveable load with enough traction and enough gearing will lift any tractors front end. Usually traction is lost and the tractor will spin out and stop lifting the front end.
One problem with pulling from 3points is that there is no upward travel stops, under hard pulls when the front starts to lift which it will because you can pull harder with the higher hitch once rotation starts the 3 point hitch will abruptly jump allowing rapid rotation and rear over turning.
When any heavy pulling is done using the lift arms there should be a travel limiter used to prevent the lift arms from uncontrollable lifting.
A chain down to the fixed drawbar or solid limiters from the top link attaching pin point on the tractor.
The statement about if you have power and traction and the pulled load exceeds your tractors pulling capacity is just plain wrong
If you are pulling from a drawbar below the rear axle the front will be forced down not up
Draw the force vectors
We did hundreds of times in engineering school
Up violates the laws of physics
Andy
/ Pull from the front or the rear? #87
Andy
Andy, this certainly makes sense if the pulled load is level with or above the tractor's drawbar. But might it make a difference if the pulled load is below the drawbar? For instance, a not-uncommon situation where the pulled load is a vehicle that has slid off the road, down a slight incline and is well stuck in a muddy ditch. Tractor is on the road, pulling from a D-ring clevis on the drawbar. :scratchchin:
/ Pull from the front or the rear? #89
Your right with the load is at some downward angle. You need to calculate moment arms and unless you have extended the drawbar in a rigid fashion the moment arm is very short
A much more likely scenario is for the load to suddenly release like a broken chain
These are all things studied in Statics,Dynamics and Kinematics courses
Andy
/ Pull from the front or the rear? #90
Thinking back to my friend's father - locked brakes on a heavy trailer is going to add another downward force at the hitch too.
/ Pull from the front or the rear? #91
Correct if your pulling the trailer uphill when the brakes lock. No net downward force on level ground An upward force if the breaks lock while pulling downhill
Andy
/ Pull from the front or the rear? #92
Seems to me the nose of the trailer is going to exert downward force if its brakes are locked, regardless of up/down slope.
/ Pull from the front or the rear? #93
How do you figure that? The load shifting to behind the axle on a single axle trailer will cause an upward force at the drawbar.
Try googling force vector force vector - Google Search
The only reason I keep pushing on this concept is that your misunderstanding of how forces are applied could get you or others hurt
Andy
/ Pull from the front or the rear? #94
Haven't you seen the nose of a car drop when the brakes are applied? You think the nose wouldn't drop if driving uphill? Trying to pull a trailer with locked brakes is the same physics. It's not (primarily) the CG moving forward from the axle (or back as you say), it's the forward force exerted at higher elevation than where the tires grip the pavement and are trying to resist motion.
/ Pull from the front or the rear? #95
Haven't you seen the nose of a car drop when the brakes are applied? Trying to pull a trailer with locked brakes is the same physics. It's not (primarily) the CG moving forward from the axle (or back as you say), it's the forward force exerted at higher elevation than where the tires grip the pavement and are trying to resist motion.
A tractor pulling a trailer is not like a car at all. You really do need to work on vectors and resolution of forces.
With suitable linkages in an "automobile: suspension, You can get the body to rise on deceleration and bank when rounding corners instead of rolling.
Comparing apples to pickles is not a wise thing to do.
/ Pull from the front or the rear? #96
I'm trying to imagine your scenario: tractor pulling a trailer uphill and suddenly the trailer brakes lock.
That's going to shift the trailer's CG to the rear suddenly? How?
/ Pull from the front or the rear? #97
A lot of it depends on the strength of the tow strap or chain. One trick that I have seen was two chains, one attached to each vehicle with the other end of each attached to a tire (no rim). That enables you to "snap" it a little bit with the tire absorbing some of the shock.
As somebody has mentioned though, there are times when it's safer to call a wrecker. They can pull more gently, and hopefully their rig is heavy enough to control the stuck vehicle when things start going sideways.
/ Pull from the front or the rear? #98
There are a fair number of dead tractor drivers that would dispute your theoretical wandering if they could.
In support of this truth that challenges mere vector analysis: Spinning tires lose some traction, but not all traction. Ever seen a one on one pull, where the 'loser' slows but doesn't stop the winner? When touting vector analysis we might quickly assume that tires either spin or grab. They CAN do both!
Those dead operators that Rick mentioned did not assume as so many of us have that the tractor couldn't be going backward slightly with nothing broken and while still having enough traction to 'climb a ring gear' (I'd heard the term 35 years ago among employers when I was grooming harness horses.)
One of them had died when pulling a hay wagon on level ground from the true drawbar below the axle. Tires spun, the tractor shifted back mere inches, and IIRC he was pinned between the the steering wheel and the trailer tongue. Wheelie bars on a pulling tractor?? You darn betcha, and if you ask the guy who has them, be prepared to hear at least one story you likely won't believe.
/ Pull from the front or the rear? #99
'climb a ring gear'. Yes. That's the description that most clearly distills how this can happen. In the real world.
/ Pull from the front or the rear? #100
climbing ring gears only happens in the world of inertia, Not tractive forces.
If the draw bar is below the axle, pulling on the load forces the front end down.
If the load goes slack, and the tractor is allreading headed for the moon, Well, You can't fix stupid!
1997 International 3800 School Bus (A64194)
1997 International...
Quick Attach Rock and Tree Hand (A65579)
Quick Attach Rock...
2004 International 4300 Water Truck, VIN # 1HSMKADN44H679633 (A65563)
2004 International...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
