Pull from the front or the rear?
/ Pull from the front or the rear? #21
If you want to feel a little safer, pull from the fixed drawbar, with the chain running under a raised implement, like a box blade.
Bruce
/ Pull from the front or the rear? #22
What people have to differentiate here is there is two examples (definition) of "drawbar".... One is a horizontal bar with holes in it mounted in 3PH hitch and able to raise up and lower down.... Other example is a bar (or plate) extended out from under chassis at a fixed height (usually below differential/axle height) with a single hole in it.....
Think people need to be more specific in defining "drawbar" in these sort of discussions...
Dale
The forces would be extreme. But you don't need vector analysis to imagine the scenario where the rear axle can't move forward (due to the drawbar chained to an immovable object) and a mechanical driveline continues to send torque to the rear axle that has perfect traction. If nothing breaks then rotating the tractor up and over backward is inevitable. I suppose if the drawbar extended out beyond the tires and didn't bend then the rotation would end when the weight of the tractor rested on the tip of the drawbar so the tires lost traction.
Here's a thought experiment...
1. Imagine pulling an immovable object from the top of the ROPS. That's not an abstract concept and I think we can all agree the tractor would flip. The forward force would create a downward force on the rear wheels (more traction, "digging in") and an upward force on the front wheels. And then the she flips.
2. Imagine a 12" drop trailer hitch installed in place of a draw bar, so that the ball is maybe 1" off the ground, pulling against an immovable object from the ball (as close as we can get to the exact opposite of scenario #1). The opposite forces would be at play. Downward force on the front wheels and upward force on the rear wheels until they spin (opposite if "digging in," traction decreased below that of not pulling anything). This is a little bit more abstract than scenario #1 but I think most of us could still agree: the tractor won't flip over backward.
3. Replace the 12" drop hitch for a 6" drop hitch. All the same forces from scenario #2 are at play, but to a lesser degree.
4. Pulling directly from the axle pumpkin. The are no forces induced by the pull on the immovable object. The only forces at work are those inherent in the tractor itself. The torque of the engine on the rear wheels, trying to turn, lifting the engine up. Kinda abstract but not really. Drag cars do it all the time. No forces induced by a pull on an immovable object, yet they still lift in the front.
5. Pulling from the draw bar. This is going to be somewhere between scenario 3 and 4. There will be forces induced by the pull, but they will be in opposition to the tractor's inherent proclivity to flip itself over backward.
So I conclude that pulling from the draw bar is, at a minimum, safer than drag racing.
What people have to differentiate here is there is two examples (definition) of "drawbar".... One is a horizontal bar with holes in it mounted in 3PH hitch and able to raise up and down.... Other example is a bar (or plate) extended out from under chassis at a fixed height (usually below differential/axle height) with a single hole in it.....
Dale
Point taken. I'm talking about the one under the rear axle that points fwd/aft.
Sorry until now I hadn't considered there was more than one type of draw bar. Probably why some of these posts didn't make sense to me.
/ Pull from the front or the rear? #25
Pull from the draw bar (not the three point spreader!)
Fit a draw bar as long as you can get, and make sure the bar is below axle level.
With that combination , the tractor can't flip unless you are pulling well casing!
I just wrapped a two-hour-long session of watching competitive tractor pull "fail" videos on YouTube. It was a sport I had no real interest in until now. I think I need to print a retraction:
Yeah, not so much. I think people just watch this stuff for the inevitable carnage. I saw all kinds of explosions, rollovers, fire, departures of heavy iron into crowds of people, wheels flying off, tractors broke in half... it was like watching an episode of "1,000 Ways to Die" with a particular focus on tractors pulling from a point below the rear axle. What I did not happen to see in two hours of looking specifically for it, was a clean backwards flip as a result of pulling from below the axle. I saw front tires get off the ground, but they never get higher than a certain point and then they come back down. Maybe it's the operator letting off the throttle before it rolls over backwards, but statistically speaking, surely in two whole hours of watching hundreds of bad judgement calls made in a very specific situation, I would have seen at least one guy screw that up. I didn't. I think it's physics keeping them from flipping over. I think that as long as you keep the pulling point below the axle, the tractor's torque forces can only raise the front end up so high before the load's countering forces make it lose traction and come back down.
That being said, I realize that those are highly modified tractors built for a singular purpose and probably more closely related to a helicopter than they are to my CUT. I don't plan to go out and try to pull mountains over with my drawbar. It's just a curiosity for me, and if anybody has evidence to the contrary I'd be glad to see it.
/ Pull from the front or the rear? #28
Dale
As if the distinction hasn’t been made several times here already.
/ Pull from the front or the rear? #32
Pulling from the front of a tractor that does not a designed front pulling point is a good way to break a tractor. The front axle can be yanked off or the engine block break.
Always pull from a fixed draw bar mounted below the axle (not on the 3pt) and don't yank.
/ Pull from the front or the rear? #33
The way I was shown was there's the draw bar under the tractor's rear axle, sometimes also called a swinging drawbar. Then there's the drawbar with the multiple holes in it that goes between the 3pt lift arms called the 3pt drawbar, or spreader drawbar. I was told to not pull from that 3pt drawbar, only the drawbar under the axle.
Anywho, let's be careful out there....
/ Pull from the front or the rear? #34
Vector analysis may help you here, actually.
Given perfect traction, and the drawbar attached to the immoveable object, as the tractor attempts to climb, the drawbar would dip down, which would require an increase in the distance between the drawbar and the immoveable object. Assuming a perfect non-deforming (no stretch) attachment - a chain made of adamantium or unobtanium or somesuch - this distance can't increase, so the tractor can't climb.
Something, somewhere, has to break - either traction (tires spin), tires (tear?), chain (breaks or stretches), object (starts to move), axle, transmission, engine (breaks or stalls).
/ Pull from the front or the rear? #35
This says it well:
View attachment Tractor Overturn Hazards 202[1].pdf
They do cite an example of a tractor flipping backwards by a load on the drawbar, and that is if tractor is travelling fast, or uphill, and the load suddenly digs in, but then releases (like a log being skidded that hits a rock) the upward momentum of the front of the tractor raising may carry the front of the tractor past the "natural" angle that the front would otherwise lift to and the tractor could flip.
Professional pulling tractors (at tractor pulls) often have wheelie bars.
I think it's nearly impossible to flip a normal tractor over backwards by pulling from the drawbar under the axle (under 99% of conditions).
/ Pull from the front or the rear? #38
I like your analysis. It seems the most accurate of anything in this thread.
Let's introduce a real world factor. There has to be a weak point somewhere, if not a stall: as the drawbar is forced lower, the nose of a trailer also goes lower and the trailer is dragged forward slightly because its traction is the weak point. That could rotate the tractor to the point where its weight rests on the drawbar and the tractor loses traction, assuming that the drawbar extends beyond the tires to act as a wheelie bar.
I'm still visualizing this in terms of the situation described above, my friend's father was crushed by a small crawler that walked over backward when it couldn't budge a heavy trailer.
Come to think of it I saw this almost happen when I was a little kid. A baby crawler going up steep terrain and suddenly the nose lifted to 45 degrees. The operator got the clutch in, in time. The adults around me all went white in the face to a degree that really spooked me.
/ Pull from the front or the rear? #39
There are a fair number of dead tractor drivers that would dispute your theoretical wandering if they could.
/ Pull from the front or the rear? #40
The very best answer, call a tow truck, that's what they are designed for. No risk to you or your tractor.
There is nothing to prevent the 3pt and drawbar from rising up and putting the forces above the rear axle under the right circumstances. If you try to pull from the front you will lose a lot of tractive effort from the rear wheels.
Joe
First, the 3 PH is different from the drawbar. A true drawbar is attached to the belly of the tractor and only swings from side to side (on some models but not all). They cant be raised up or down and can never cause the tractor to flip over. With lots of traction like with dual rear tires, one may get enough traction to raise the front wheels a bit but as the front comes up, the drawbar gets lower and this tends to lessen traction to the point that the front wheels will go back down (been there done that a lot with my Dads 9000 Ford tractor with dual rear wheels).
If you use the drawbar (not a bar placed in the 3 PH) then there is no way for it to raise up since it is hard attached to the underbelly of the tractor. Folks using an old tractor like and 8N Ford and others that didn't have a fixed drawbar and instead used a bar attached to the 3 PH lift arms could indeed raise the CL of pull above the axles and cause a flip over backward in extreme cases.
You really don't have any attachment point at the front of a tractor that is designed to pull from. A FEL may have bucket hooks for lifting but the FEL is designed for some pushing but not a lot of pulling. Don't take a chance of damaging your tractor by hooking a chain to the FEL or around the front axle of your tractor. Besides the possible damage, you have very little traction backing up with your tractor.
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
2012 Ford Expedition SUV (A61574)
2012 Ford...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2019 Ford F-550 4x4 Service Truck (A61573)
2019 Ford F-550...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A61574)
2022 21ft Scout...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
