Trimmer recommendation? Stihl? Echo? something else....
/ Trimmer recommendation? Stihl? Echo? something else.... #21
Just my experience-have had a Stihl 85 since 2002. Only problem was the ignition module that I replaced last year for $70. It has been used on 2-2 acre proper tires for lawn trimming, as well as heavier work clearing ditches and property edges.
Also have a Stihl 250 bought in 2009. That is used with line and steel blades maintaining woods trails and a half acre pond too steep for any mower. Did have to change a carb-story is Stihl had some poor carbs in that time period.
I also use a KM 130 with a trimmer head. Bought in 2015, I have the pole primer and the rubber paddle sweep. Not any problems with that.
Will
/ Trimmer recommendation? Stihl? Echo? something else.... #22
The Dewalt 40V chainsaw also. Just bucked 24 poplars with it in one go. Did I mention I'll never go back to gas-powered? :)
/ Trimmer recommendation? Stihl? Echo? something else.... #23
The original poster Tangoddess, asked about two gas powered machines. And some people use these machines for many, many hours on end. A battery powered machine just won't cut it. We also gave up on 4 stroke ones. We found they are two heavy to be used all day.
/ Trimmer recommendation? Stihl? Echo? something else.... #24
I have used an Echo SRM220 for around 12 years without issue. Only after all this time did I need to rebuild the carb on it this year. It has been fantastic.
/ Trimmer recommendation? Stihl? Echo? something else.... #25
After owning three Stihl trimmers since the later 70's, I went with a Redmax BCZ3060TS. Had it about a year now and I am happy with it. It was not cheap though
/ Trimmer recommendation? Stihl? Echo? something else.... #26
My current line of trimmers is Stihl, echo, and redmax. My Shindiawa got stolen and it was my favorite.
/ Trimmer recommendation? Stihl? Echo? something else.... #27
Owned several Stihl, all garbage. Pull your guts out! Then, throw out your back as you try and hurl the piece of junk as far as possible!
Have a Toro that I got at the RESTORE, for next to nothing, had to put a reel on it. Starts and runs great after maybe ten years!
But I love my 18 Volt Oregon. Quiet, start and stop as you please.
That's very different than my experience with Stihl. I have 3 4 Cycle Kombi Units, a Hedge Trimmer & a Climbing Chain Saw. I never even drain the gas on the winter and they always start within about 3 easy pulls .
I use then hard and have had no issues, except when Stihl had the recall because the gas was dissolving the gas caps
Andy
/ Trimmer recommendation? Stihl? Echo? something else.... #28
Since some posters are getting picky:
The OP may not realize how powerful the new battery powered machines are and how long they last on a battery. The OP also only mentioned trimming, not brush cutting. Tangoddess has not been back to give more info but based on using my 40V stuff I'm sure the 40V and Flexvolt machines with A SPARE BATTERY OR TWO will run most of the day. Tangodess also indicated she had been using a 30CC 4 stroke and one of the problems was
The problem is that it is really hard to start, and takes a lot of yanking.
My battery operated stuff only takes a light yank on the trigger.
Andy
Similar experience if I try and start my Stihls the Stihl way- Full choke, one or two pulls so it pops (fires), cut the choke back, pull and run.
/ Trimmer recommendation? Stihl? Echo? something else.... #29
A little off topic...
At the Christmas tree farm they do fresh cuts prior to loading the tree...
For years the saws were little Stihl two strokes.
Last year... the Dealer set the farm up with a battery Stihl chain saw... now it is the only saw the guys want to use and it cuts hundreds of tree trunks on a single charge...
I really like using it... especially compared to winding up a gas saw for seconds of work...
/ Trimmer recommendation? Stihl? Echo? something else.... #30
Yeah, that was why I brought it up. I had the same issues as the OP.
Anyone who hasn't owned one of the newer battery operated trimmers or saws, might want to try it before they bash it.
/ Trimmer recommendation? Stihl? Echo? something else.... #31
Well lots of YMMV anecdotes.
However, if you decide to make a big box purchase who will service it when the time comes?
I went to a local dealer and building up that rapport learned a bit from the service tech.
For the 2 stroke user he said use Sta Bil in the fuel. The ethanol eats up gaskets. Or get the ethanol free gas; From store, marina, airport , etc.
Size of property is also a factor to consider when deciding battery versus 2 stroke.
Will a set of batteries cut 1800 feet of fence line and run a cutting blade to cut down small sapling growth along the fence?
lots of variables. To say my electric runs all day long does not provide enough info to help make a decision.
After, about 9 years the PAS 230 finally had to have a new carb. I let the tech do it cause I know it will run correctly.
My ego had to take a back seat to the: I can fix anything with enough u-toob videos. ha...yeah right.
If you have a local small engine repair shop near by stop by and chat.
Ask them what the pros are using the most. Which machine/brand has the most/least issues, etc.
Then you should have enough info to help make a good buy.
Regards..
/ Trimmer recommendation? Stihl? Echo? something else.... #32
I only needed to pick one up before I decided it wasn’t going to work. It weighs more than my gas trimmer and turns about 1/4 of the rpm. I would like to have a cordless blower to blow off trim and doors for painting, but the price is too steep for that one job.
/ Trimmer recommendation? Stihl? Echo? something else.... #33
Regards..
I second his advice.
Don’t forget to take care of it. Too often, homeowners neglect proper care of small engines, especially 2-strokes. I always use non-ethanol gas in my mix and at the end of the season, I dump the gas out, run it dry, take out the spark plug, squirt a bit of oil in the cylinder, pull the line once to let the oil coat the insides, reinstall the spark plug & store it.
I’ve had a cheap string trimmer in my early years that still worked but was too small for the job after I moved. I now have a Husky straight shaft & Echo.
/ Trimmer recommendation? Stihl? Echo? something else.... #34
Well we really need the OP to come back, hasn't been here since she posted.
Hi,
How is everyone enjoying the summer? Today I finally got tired of my trimmer, it was one I got from a Sears stor, 30cc, 4 cycle, uses gas, Craftsman brand I think.
It is barely used, but has given me a lot of issues. The fan broke, and I think the pull string got loose etc.
I am thinking of getting a better/easier to turn on unit, which has a better warranty.
Decent battery unit would fix those problems.
We have pretty thick native weeds and a large plot of land, so quality, and durability is important. We need it to cut around the edges and in narrow spaces where the mowers do not fit.
Size matters, what does thick mean? Dense growth or stem diameter?
What is a "large plot of land" using Google a "plot" seems to reference a either a size unit used in Africa (less than an acre) or any size area. So the OP may be talking about an acre or hundreds, but she is talking about "where the mowers do not fit".
Which brand/model do you recommend? Echo? Stihl?
And what is a good sweet spot in terms of size, capacity, the Craftsman is 30cc...but I noticed that is on the higher end of the Echo trimmers?
Easy to start and not an earthquake on the body when operating is important :)
Thank you
And the OP wants one that compares to the Craftsman 30cc 4 stroke.
(Which weighs 14 lbs.)
And the OP wants easy start.
and one follows
The OP doesn't say anything about a third of a mile of fence line OR needing to run a cutting blade. I would think that much fenceline would require a refill, either from a fuel tank or another battery.
And more YMMV ancedote
Regards..
The OP doesn't indicate they need a "pro" solution to cut down saplings. And a battery solution won't need a new carb - EVER. Might need new brushes.
But how often do we read here about fuel systems failing due to alcohol or bad mix.
If the OP needs to cut down saplings they probably need more power than present battery operated trimmers offer, but if the OP just needs to do what was done with the Craftsman with trimmer line many battery operated units will do.
I've a 40V battery operated chainsaw and a 35CC Stihl chainsaw. I'd rather use the 40v for suitable tasks. But when I need to take down a 30" diameter tree I go to a 90CC Stihl.
And
<snip>
<snip>
With my battery operated tools I neglect ALL of that.
/ Trimmer recommendation? Stihl? Echo? something else.... #35
I bought a Shindaiwa T270 about 15 years ago or a bit longer. I have run just over 20 lbs of line through it and it is still performing extremely well. I have replaced the carb once, the fuel bulb twice, reattached the fuel line in the tank once, and the fuel cap has started to leak a bit. I have used it to mow almost two acres while the lawn mowers were down. It is heavier than the OP wants but I wish all my engines were so reliable.
My dad has both orange and gray Echo trimmers and chainsaws that range in age from new to 30 years old. He uses avgas 100LL and his machines sit idle a bunch. All his are featherlite and they have been rock solid performers.
Stihl makes fantastic and ho hum chainsaws. Their other products I have found to be overpriced duds.
/ Trimmer recommendation? Stihl? Echo? something else.... #36
Nothing beats a Honda!
After fighting 2-stroke trimmers for years I had enough and bought a Honda 4 stroke string trimmer 20+ years ago. Light, strong, and like any Honda engine, absolutely dependable. Never had to do anything to it in the years I've owned it but pour in some gas and change the oil once a year. Come late October I'll put it up in its rack and next spring I'll pour some fresh gas in it; two pulls on the cord and it will fire up and runs smoothly.
It was more expensive than the 2-stroke trimmers but now I know it was well worth it!
+1 on the Honda! Can't speak to the other brands, since I've never owned one, but the Honda is fantastic. Yes, more money up front, but should last a lifetime, and easy to use & maintain. I also have a couple of the Honda portable generators (EU2000), and they are equally impressive. Love Honda power equipment!
Thank you this is very good information I am going to read through it and get back on here in a day or so
/ Trimmer recommendation? Stihl? Echo? something else.... #38
I run a STIHL 2-stroke, straight shaft with harness and the 'bicycle' handles. Swap between trimmer string & a triple blade (depending on the job). A major reason for going with STIHL is that there's a local shop that sells & services. I've had zero problems with it.
I did have a non-harness Echo 2-stroke prior to this but the vibration from holding it made my hands go numb and ache for days after using it! I tried using foam-neoprene 'diver' gloves whilst using it, to no avail. Otherwise, the Echo was a dependable unit.
A harness distributes damaging vibration and is easier on the body... whatever your age.
Ok so here are some updates and thoughts based on the comments posted here.
I am also posting some pictures of the weeds that we have along fences within the property (i.e not the fence between our and other properties, but internal fences) and also weeds in areas which are too narrow to use even a handheld mower.
Of course these have not been trimmed in a month or so, thus the expansive growth.
Here are some updated thoughts from our end:
1) As the trimmer will be used by fit and less fit individuals, weight is of importance, something that is not too heavy is preferred, hopefully while not sacrificing on performance
2) Honestly, the trimmer will be used a couple of times a week, for maybe a couple of hours each time. this is not a commercial 5x a week 6-8 hours a day type need
3) However, as the plot is about 8 acres, but we just need to trim around the occupied areas, e.g home, playground areas, animal barns etc. it may be couple of acres to trim
4) I feel that a off the shelf mid level trimmer from a BB store may not make it as the growth is native grasses etc and of course servicing becomes an issue
5) So...maybe a trimmer that is between commercial and home owner level or an entry level commercial? We do not mind paying a premium for quality
6) Is battery the way to go?
Your thoughts please?
Thank you
/ Trimmer recommendation? Stihl? Echo? something else.... #40
They make wheeled trimmers. I've always wanted one, as trimming is hard on the arms, back and shoulders. This is a Cub Cadet, but Husqvarna, DR Power, and other brands also make them.
If you're worried about *snakes* in the grass, this puts the machine in-between you and the critters. :)
Your weeds look manageable. You might have to use lopers for the pokeweed.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
