woodmaxx flail mower?
/ woodmaxx flail mower? #81
REALLY? Then WHY do people ask for others' input for all sorts of other things? AND, there HAS been some feedback here from OWNERS, but has been early feedback.
azkubotaguy, yes, I saw that you had mentioned that you did not wish to wait any longer, I completely understand that: I'm patiently waiting, several months, for a tool box. IF Woodmaxx did not communicate the back-order queue well then THAT is certainly not good; BUT, again, I am looking for feedback from people who HAVE one.
Asking for feedback on a Kubota BX is one thing, but as evident here, it may be a while before enough users own certain uncommon or new implements before first hand feedback is available. Leonz gave you pretty good advice if you need an answer now.
/ woodmaxx flail mower? #82
Please, stop. I am asking PEOPLE WHO OWN A WOODMAXX. If you don't own one then PLEASE do not waste your or my time, thank you!
NOTE: There are already people who have given feedback, who OWN a Woodmaxx flail mower. I am just asking for a follow-up. I CAN WAIT.
/ woodmaxx flail mower? #83
I just took delivery of the 78 inch hydraulic shift model this week. I've just got it hooked up and the PTO shaft adjusted so no real use yet other then a very brief test on a small patch of woody edge row. The flail came well packaged in a metal frame/pallet and required no assembly. The unit is solidly built and the fit and finish is good. The unit ran smoothly during my brief test and laid waste to the small patch I tried it on. The included pto shaft is a low end China model but does the job. I ordered mine with the duck foot blades installed and also ordered a set of Y blades. I have a look of barberry and invasive junk on my woodlot so I intend to put to the test when I get a chance.
/ woodmaxx flail mower? #84
Looking forward to hearing how the hydraulic shift works out. I'm always fighting to not hook fence posts wile mowing as tight as possible to the fence. Hydraulic shift seems like the answer. Also curious what you think about how duckfoot vs side slicers work out in brush vs grass. My beatup old Ford 917 is just getting more beatup & I keep eyeing those Woodmaxx...
/ woodmaxx flail mower? #85
Lesson #1 on TBN: if you aren't the OP, DON'T tell others what to post and what not to post. It is rude and makes you look like a little jerk.
Lesson #2. If you don't like a thread go start your own.
/ woodmaxx flail mower? #86
Good Advice
ORIGINAL POST and Poster
[B said:
BLUEBONNET2
[B said:
good afternoon,
anyone have a woodmaxx flail? I'm considering a flail mower for about 4 ac. I have a 25 hp tractor...........I'm looking at the 62 model with the cone type blades....
thanks for the input......no flames pls....
good luck,
PURA VIDA,
bluebonnet2
/ woodmaxx flail mower? #87
To all that are interested....
I have finally had a chance to put my woodmaxx flail to the test. Mowed about 2 acres of heavy grass/weeds, and part of and also some grass/clover cover crop.
My unit has the side shift and duck foot blades. I'm very happy with the performance over all. It will cut at a surprising pace, and leaves a finely chopped layer behind. Side shift is really useful along tree lines etc.
The only complaint's at this point are:
The gearbox weeps oil from the vent. I will correct this with a short hose to extend the vent up higher.
The paint has faded quickly.
The scraper for the roller is vunerable, and has bent. I will be removing it and if needed reinforcing it.
I would buy one again. Considering value for the price, I'm happy. I will be planting acres of clover and wildflowers for bee yards. Maintaining these will be it's main use and I don't see it wearing out.
/ woodmaxx flail mower? #88
I got a chance to run mine a bit this weekend as well. It performed well, turning barberry and other assorted woody junk into fine chips . The only issue I had was that I hit a big rock with it and lost a blade. I was able to find the blade and ordered a couple extra duck feet and bolts from Woodmaxx. I think all have to be a bit more careful about scouting the mowing area. I'm basically mowing in the woods and there are a lot of rocks that aren't apparent until you knock down the overgrowth.
/ woodmaxx flail mower? #89
I had some of the same sort of thing, I was able to pick up a low cost brush hog to take the first cut with. I'll probably sell it in the next year or two after I've gotten the rough stuff all cut. I found lots of stumps and rocks this way. But did it with a mower that can take the abuse better. Then went through the area with the root rake to clean out most of it.
/ woodmaxx flail mower? #90
I would suggest making a bracket that raises that roller scraper angle iron. Its current design is awfully low.
/ woodmaxx flail mower? #91
Mine is a different design than the one shown in your post. Yes its not very well designed. I will be moving it as well as stiffening the angle iron as it is ineffective at the center of the roller due to it flexing out.
/ woodmaxx flail mower? #92
Howdy,
Since I received some helpful advice through multiple threads on TractorByNet when considering a flail mower I figured I'd better share my experiences thus far with my new-this-spring WoodMaxx FM-96H. There were some delays and miscommunications on the order but it eventually arrived in time for mowing season (having ordered a couple of pieces of equipment from Everything Attachments as well I will say that WoodMaxx could take some pointers on customer service and technical support from EA). Set-up was fine, just followed the directions, including shortening the PTO shaft.
Since I've already cleared the bigger brush on our farm I went with the Y-blades. They are working fine and will take out small brush, too. I have had to replace a few blades due to rock encounters. I had concerns about the weight for my tractor (Case IH DX55), not so much from the 3 pt lift capacity but on my steep hills. I was also concerned about the power requirements since I was at the lower end of the mower rating. Not to worry it turns out. Weight has not been an issue (tractor is 4WD, with loader and R1s loaded with RimGuard) as I've been up, down, and across some steep slopes with no problems. Power has been fine and I just downshift if need be to keep the RPMs up. I mowed with it for about 12 hours this past Saturday and really put it to the test. The worst was very thick marsh grass that hadn't been mowed for 5 years and up to eye level on the tractor. It did a nice job mulching it up on the middle height setting. The scraper bar is holding up so far.
The hydraulic offset is worth the extra cost. It's a nice way to only mow over one wheel track instead of two and reach a bit under the trees overhanging the fence. I was surprised to find out after arrival that I still needed to purchase the male connectors to hook it up to the tractor remote (EA asks you what need and puts them on). You do need to keep the tubes it slides back and forth on relatively clean as they can slow down or stop the shift after a day of dirt/dust accumulation.
We'll see how it holds up over time but I'm pleased thus far. I'm also glad I chose this over a rotary mower. I like the fact it doesn't stick out so far behind the tractor to reduce scalping and allows you to operate in tighter spaces. The quality of cut is much better and the offset adds utility.
Hope that's helpful to folks trying to make buying decisions. I appreciate all the good info I found on here when making a box blade, grapple, and flail mower purchase.
/ woodmaxx flail mower? #93
I want to welcome you as the newest member of the Flail Mower Nations.
you should invest in the $99.00 USD slow speed wet well grinder from
Micro Mark to keep yourside slicer knives sharp.
Happy mowing.
/ woodmaxx flail mower? #94
I think they may have changed the design on the newer models. Mine looks like the attached. One question I have is the 3 pt connection hole and slots on the hitch. The manual makes some reference to the the mover being able to move during operation, but does really provide any details. Is the mower intended to be attached by the elongated slots on both the top link and the lift arms or just the top link?
/ woodmaxx flail mower? #95
No clue on the Woodmaxx offhand, but all terrain following impliments needs to float. Rotary cutters have a flex link connected to the toplink. My old Ford 917 flail has lift hooks that have about 4-5" of vertical movement. Others use a slot for the toplink.
If the hitch doesn't have some flex mechanism the roller could end up carrying all the weight of the back of the tractor & the rear wheels would come off the ground when going through a small dip or ditch.
/ woodmaxx flail mower? #96
Any new updates from the Woodmaxx contingent? I'm seriously considering the 54" model. As of last week, Woodmaxx indicated they had 6 or 7 units coming in that were not taken. I think I may get in line!
I like the price, free shipping, & 2 year warranty, with at least some US involvement (design?). And the size & weight should be OK for my mini KB.
/ woodmaxx flail mower? #97
I mowed another 2-3 acres of 4-5ft tall brush/weeds. All went very well mowing at about 4in height. Side shift was very useful around trees and boulders as well as along the road side. I stalled the unit and the pto clutch did it's job when the unit picked a partly buried 6" log out of the ground. All is well with the unit after prying it off the roter
After this I mowed 2 acres of wild flower meadow. Mine has the hammer knives and I couldn't be happier with the cut and reprocessing of the clippings. It's a fine carpet of clippings that will dry fast.
Over all so far my only issue with the mower is the roller scraper which has been redesigned. I'll have mine modified this weekend and solve this small issue.
/ woodmaxx flail mower? #98
Seriously considering getting the 78H or the 88H. Thanks for sharing.
Is there a benefit to have the adjustable rakes on the 88H?
/ woodmaxx flail mower? #99
Hello, good thread! I have the Woodmaxx 62 inch with side to side cylinder on order. The boys at Woodmaxx called 10 days ago saying the mower was there and wood be shipped soon after some checkout process they perform. Glad to read those having one are happy with them. I'll be cutting mostly pasture grass around the house and barns, areas we fenced the cows out of years ago, about 4 acres worth, also some brushy areas along the pasture fences.
Ricn
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
New/Unused SDLGC80 4-Seater Electric Golf Cart (A65583)
New/Unused SDLGC80...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
