Level type recomendations?
/ Level type recomendations? #21
At 34, it looks like you've got a lot of projects ahead of you.
Let me say, if the budget allows, you will never regret the convenience of a quality rotary lazer level. There are huge advantages to being dead nuts on the level rather than just pretty close.
Pop for the tripod and target so one person can level anything with in the range of the instrument.
Some models Also allow the instrument to be laid on it's side to project vertical lines for partition lay out.
B. John
/ Level type recomendations? #22
B. John
THIS is a SPOT ON response!!
/ Level type recomendations? #23
While I agree to some extent it does seem a little over the top for this particular project. If the OP does a lot of his own construction and grading a slope laser may be beneficial to own. If he is standing up lots of poles and walls then a horizontal/ vertical laser may be beneficial to own. I use everything from the trusty string levels to high end slope lasers but the inexpensive torpedo level with the laser built in would work well for this project. The OP can decide whether he wants to spend $5 or $5,000 to level his poles.
I ended up grabbing a Zircon water level with 100' of tubing. I figure the fittings to fill & clamp the ends of the hose are worth the extra $20 over just 100' of plain tubing. Even if the electronics aren't worth it.
Still want a rotary laser, but just can't justify the price short or long term.
/ Level type recomendations? #25
And I would prefer the Zircon water level over a $500 rotary laser for construction projects because the water level is more accurate.
/ Level type recomendations? #26
They built the pyramids with water levels......Just sayin.
/ Level type recomendations? #27
And the batteries don't go dead in a water level.
/ Level type recomendations? #28
X10 on the string level for the post cutting. K.I.S.S.
/ Level type recomendations? #29
I'm okay with the LAR method. Looks About Right
/ Level type recomendations? #30
All I can say is if he hasn't got it level by now, he better forget it.
/ Level type recomendations? #31
I have a Black and Decker self leveling laser level that would work perfectly for that. Just put the tack (included in the level) in the lowest post 1" from the top, hang the laser level and look for the line on the other post, cut 1" above the line. This is best done in subdued light since the red line is a bit hard to see in bright sun. Cost is about $30 from Sears or Walmart.
Hoping the water level comes in today or tomorow. Not gonna have a chance to even try to work on it until this Sunday or maybe next Sunday. Days are getting longer, but still not enough light after work to sink into a bigger project.
/ Level type recomendations? #33
For a project like yours a simple sighting level would have worked fine, probably would get you within a degree or two of level depending on how good your eyes are. Used to be used in surveying and construction before lasers became widespread. Johnson Hand-Held Sight Level-8-5556 - The Home Depot
Ficklin 435 (A64127)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2022 EZ-GO ELITE...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
