Box Scraper Box Blade or Rear Grader Blade?
/ Box Blade or Rear Grader Blade? #1
Automobilist
Member
Monroe, WA
New Holland T1510 HST, Husqvarna mower
Just got my first tractor; New Holland T1510. Jumping to get going on it! Got five acres heavily wooded, fallen trees & underbrush. Heaven...
Have about a half acre cleared with driveway, parking, etc. Due to the somewhat wet weather here in the great Northwest, it tends to get chewed up pretty quickly. Hence, I need to get an attachment for the tractor to refinish the drive / parking areas frequently. "She" is skeptical of course, but I have to park my 911 out there.
So, box blade scraper or rear grading blade? Tractor has 30 hp to pull with...
/ Box Blade or Rear Grader Blade? #2
I started with a scraper blade (bought new) It wouldn't bite or dig in enough for any real road re finishing.(at least for me)
Sold it and found a used gannon box blade. It will dig in and move material- Have no plans to buy another back (scraper) blade.
Ps also picked up a well used Landscape rake (Servis) and it can be offset and angled also has adjustable guide tires and If doing gravel finish work It covers some of the duties that i used the scraper blade for.
/ Box Blade or Rear Grader Blade? #3
Hey Auto... good to see another 'local' on the forums! I have a back blade which I borrowed from another member on this forum and ended up buying it because it was easier than returning it. :laughing:
Although I have got my money's worth, I do wish I had a box blade that would dig a bit better. I sort of took on the duties to maintain our shared gravel driveway rather than hiring a local guy with a large grader every time. It does come out better when we hire it out because he rolls it afterward and I can't do that. We still have him come out every couple years but I can smooth out the washboard wrinkles in problematic areas in the meantime with the blade. The blade I have is technically too big for my tractor but the extra weight helps dig. Although no direct experience... I think the answer for you is box blade. I imagine you will be taming some of the wooded area too and I think the box blade will come in handy there too. The experts will chime in shortly. Good luck with your hunt.
/ Box Blade or Rear Grader Blade? #4
I haven't used our scraper blade in years as I find the box scraper a better all around tool. I plan about every year to put the blade on to taper some edges, but never seem to find the time.
For just road maintenance and parking lot, I'd like to have something like this, but I'll probably never get around to buying one: GS25 Series Grading Scrapers | Land Pride
/ Box Blade or Rear Grader Blade? #5
I had a project that involved leveling and redistributing a fair amount of material. I bought a used box scraper, did the project and sold it for what I paid the previous year. It would have done OK at fixing gravel driveways but something like the homebrew "landplanes" below work better for me.
The big large one is used at work. We have a lot of gravel areas to take care of. I recently had the guys shorten it because I was concerned about the stress being put on the Montana's topling attachment point.
The smaller one is used at home. It started life as a more cumbersome piece that required using it chained to my boom pole. One day I saw the big rusty blind flange wasting away on a pile at work and thought it could be put to good use.
/ Box Blade or Rear Grader Blade? #6
I have three implements that I've used for maintenance of my mile long gravel driveway. Land Pride RB3596(rear blade), Bush Hog RO720(roll over box blade) & Land Pride GS2584(Land Plane Grading Scraper). The rear blade is great for snow removal in the winter and rates a zero for summer driveway maintenance - too light at only 565 pounds. The ROBB is great for moving larger amounts of material on & around the driveway. The LPGS is great for smoothing & top dragging the driveway when I'm done with all the other fooling around. Both the ROBB & the LPGS have scarifiers if and when I need to repair big potholes.
I have found that a hydraulic top link is also a fantastic addition for dirt engagement implements. It allows me to make adjustments "on the fly" without having to start/stop/adjust so very many times to obtain the correct "angle of attack". Now, with this hyd top link, I can acheive the correct adjustment and not the - "well, that looks good enough" position, after many tries.
/ Box Blade or Rear Grader Blade? #7
I agree on the rear grading scraper, best bang for the buck for gravel roads and driveways.
I have a Woods 84" and top and side hydraulic links from Fit-Rite.
/ Box Blade or Rear Grader Blade? #8
An advantage of a rear blade with a swinging main beam is it will reach outside the tractor, a BB won't. Otherwise, it's a BB hands down.
/ Box Blade or Rear Grader Blade? #9
Most I have talked to in person that were not satisfied with the rear blade had been using light blades.
Depending on the driveway I will use a heavy rear blade (1000LBS) or a grading scraper
/ Box Blade or Rear Grader Blade? #10
For refinishing the driveway a lpgs is an easy tool to use with or without top n tilt hydraulic hitch. A good quality and heavy 60" would be a good fit.
My thought is a box blade and a rear blade are also good attachments. Top n tilt is great to have with the grader blade and box blade but all of this adds costs. I think if you buy good implements as you can budget them you wont need to repeat the buying process.
I don't see one of the implements as being better for overall use as these all have different capabilities. In time you will want one of each, just get good ones as you acquire them.
/ Box Blade or Rear Grader Blade? #11
I agree with buying good quality implements. Here is a light duty blade I was using to blade snow with. I caught a frozen down rock and bent the blade. The weight was added for ballest. ImageUploadedByTractorByNet1459090756.077586.jpg
/ Box Blade or Rear Grader Blade? #12
Have to agree with this. I can't say that I have heard anyone with a rear blade that weighs in at or above 100lbs per foot width complain about it not working well. Just sort of how it typically is. I know that my first manual 8' rear blade weighed 680lbs and worked ok, but compared to my 9' 1140+lb rear blade, about the only fair comparison is that they are both rear blades.
Just my :2cents:
/ Box Blade or Rear Grader Blade? #13
I maintain a shared access driveway and just used land plane to smooth winter ruts and dips.
I rented this one for $75/day - you might check rental places so you can test drive some of these - land plane vs box blade vs scraper.
I don't have a box blade but it is on my wish list and will be joining the horde of pulltoys.
/ Box Blade or Rear Grader Blade? #14
Brian,
This attracted my attention. Got it working yet?
We used to have about an 8 foot one but it was only used for touch-up work on flood irrigated land. No roads to maintain. I'd like to hear your experience using it on your roads compared to the other implements.
Bruce
/ Box Blade or Rear Grader Blade? #15
Brian,
Bruce
Bruce, we have never used it. Got it with a bunch of other stuff and it sits where it sets for the last 12+ years. Honestly, with all the different implements that I have, there is no reason to spend any time fooling with that particular piece.
/ Box Blade or Rear Grader Blade? #16
I've bought many implements for my tractors over the past 12 years. I've sold most of them but not the RatchetRake or the Box blade. I did have a rear blade on a B7800 30/31/32 HP Kubota and got rid of it pretty quick, not worth much to me with my needs and tractor. A 1000 lb blade would probably do a better job than the blade I had but not sure it would have worked well with the size tractor I had. I often see where people on TBN buy weight boxes but a boxblade will do the same job plus many other jobs. BB is a very useful implement and add a RatchetRake and maybe a tiller and some chain on forks.
Can spend lots of time here.Tractor Attachments - Quality Attachments for Sale Online - Everything Attachments
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
Landhonor 65' Extension Cord Reel (A66408)
Landhonor 65'...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
Farmhand CG 3000 Tub Grinder / Bale Processor (A66408)
Farmhand CG 3000...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
