Box Scraper Box Blade or Rear Grader Blade?
   / Box Blade or Rear Grader Blade? #11
I agree with buying good quality implements. Here is a light duty blade I was using to blade snow with. I caught a frozen down rock and bent the blade. The weight was added for ballest. ImageUploadedByTractorByNet1459090756.077586.jpg
   / Box Blade or Rear Grader Blade? #12
Most I have talked to in person that were not satisfied with the rear blade had been using light blades.
Depending on the driveway I will use a heavy rear blade (1000LBS) or a grading scraper
Have to agree with this. I can't say that I have heard anyone with a rear blade that weighs in at or above 100lbs per foot width complain about it not working well. Just sort of how it typically is. I know that my first manual 8' rear blade weighed 680lbs and worked ok, but compared to my 9' 1140+lb rear blade, about the only fair comparison is that they are both rear blades.
Just my :2cents:
   / Box Blade or Rear Grader Blade? #13
I maintain a shared access driveway and just used land plane to smooth winter ruts and dips.
I rented this one for $75/day - you might check rental places so you can test drive some of these - land plane vs box blade vs scraper.
I don't have a box blade but it is on my wish list and will be joining the horde of pulltoys.
   / Box Blade or Rear Grader Blade? #14
Brian,
This attracted my attention. Got it working yet?
We used to have about an 8 foot one but it was only used for touch-up work on flood irrigated land. No roads to maintain. I'd like to hear your experience using it on your roads compared to the other implements.
Bruce
   / Box Blade or Rear Grader Blade? #15
Brian,
Bruce
Bruce, we have never used it. Got it with a bunch of other stuff and it sits where it sets for the last 12+ years. Honestly, with all the different implements that I have, there is no reason to spend any time fooling with that particular piece.
   / Box Blade or Rear Grader Blade? #16
I've bought many implements for my tractors over the past 12 years. I've sold most of them but not the RatchetRake or the Box blade. I did have a rear blade on a B7800 30/31/32 HP Kubota and got rid of it pretty quick, not worth much to me with my needs and tractor. A 1000 lb blade would probably do a better job than the blade I had but not sure it would have worked well with the size tractor I had. I often see where people on TBN buy weight boxes but a boxblade will do the same job plus many other jobs. BB is a very useful implement and add a RatchetRake and maybe a tiller and some chain on forks.
Can spend lots of time here.Tractor Attachments - Quality Attachments for Sale Online - Everything Attachments
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2020 JOHN DEERE 333G SKID STEER (A52707)
2020 JOHN DEERE...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2012 Volkswagen Tiguan AWD SUV (A55853)
2012 Volkswagen...
2013 Ford F-150 Crew Cab 4WD Pick-up Truck (A55852)
2013 Ford F-150...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
