Hydrostatic Tractor, Loader, Backhoe Options
/ Hydrostatic Tractor, Loader, Backhoe Options #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
I need a bigger tractor and am currently in need of something capable of digging stumps. I think I would like a mid size hydrostatic Tractor, Loader, Backhoe. Something with a rear lift and PTO so I could take the backhoe off and use it as a farm tractor. I am thinking at least 40+ HP engine with 30+ PTO HP. Would prefer used around 20K in pricing or less. I have seen the John Deere 110 TLB that seems to fit the bill. Does anyone have experience with these or have any suggestions? Any used Kubota, Massey, or other brands that fit this category?
/ Hydrostatic Tractor, Loader, Backhoe Options #2
I don't think you will find a JD 110 for less than 20k that is not beat to **** and back. How big of stumps are you planning on digging out? A full size backhoe or large mini excavator is more suitable for that. A Kubota L45 is pretty equal to a JD 110. The Kubota M59 is a good bit stronger than the 110.
I realize my price range limits what I might find. That is why I'm seeking input.
Stumps vary in size. I rented a 7,000 lb excavator to see what I could do with that and it left something to be desired. After a few I just drove around the larger pine stumps.
I think I could aggravate most of my stumps out with a mid size backhoe and if I owned it I wouldn't be pressed for time. I could always dig around the biguns and just burn them in place.
Excavators are too popular and pricey for me and then when you are done with what they will do you still need a tractor. A TLB would be the most versatile option I think.
/ Hydrostatic Tractor, Loader, Backhoe Options #4
I think the cheapest TLB's under $20k are the Kubota BX25D-1, JD 1025R, and MF GC1720 if you plan to get new probably can do stumps under 12" with some time, experience, and ripper tooth. Most of the time that backhoe is $7-8k premium minimum. So if you want larger used might be the way to go something like Kubota B26 TLB with a few hundred hours. You got to pay to play unfortunately big toys are expensive. I also priced out a loaded Kubota 2601 TLB from Barlow's for about $26k new with 0%. All the larger TLB's in CUT form will be in $30k range for something not beat to ****.
/ Hydrostatic Tractor, Loader, Backhoe Options #5
A 7k excavator is similar to JD 27D mini excavator which is much stronger than a CUT backhoe. Something close to 5000 lbs. of digging force at the bucket. A Kubota Grand L6060 (60Hp tractor) with a BH92 backhoe only produces 4500 lbs of digging force at the bucket. Even less than 7000 lbs mini excavator.
I think renting out a job to a CAT or JD 60D excavator might be a better way for large stumps unless you want to grind them down and fill the hole every year for a decade.
The main reason I want to dig out the stumps is so I don't have the ever forming depressions and holes. Went through that with my 2 acre yard.
I have a couple of quotes on having the work done. One guy offered to dig out the stumps, rake the roots, and burn it all on 5 acres for $10,000. He wasn't planning to grade it out I don't think. I got another quote of $4500 per acre to do all that and level the ground out from an excavation company.
I'm not in a big hurry and I can't seem to come to terms with paying that much for having it done versus putting that cash into machinery and doing the work myself.
/ Hydrostatic Tractor, Loader, Backhoe Options #7
The excavator you rented has a arm digging force of 4589 pounds, bucket digging force of 6968 pounds, and lift capacity of 2537 pounds. The JD110 has a arm digging force of 3764 pounds, and a bucket force of 5723 pounds. If the excavator was a disappointment the JD 110 will be bigger disappointment.
/ Hydrostatic Tractor, Loader, Backhoe Options #8
I understand what you are saying. I have only about 2 acres of lawn on my 5 acre property and about 12 larger silver maple stumps I have to remove. I decided to go with a TLB like you but go with a smaller machine. It will take longer for sure but I can do it myself when I have time along with mowing, plowing, grading, etc... it's not the most efficent way to do it. But it is investing money into your own machine.
However, if you have 50 or more stumps. Then renting a bulldozer or a 30000 lbs excavator might be the way to go for a weekend. Get the job done and then just use a smaller CUT or SCUT or TLB to do the rest of the work you need to do.
/ Hydrostatic Tractor, Loader, Backhoe Options #9
A JD 110 will do a better job than a rear mounted "add on" backhoe on a similarly sized tractor. It will have a stronger loader as well.
Down side is that you cannot remove the loader like you can on most modern CUT's.
Like already mentioned, it seems like you would be disappointed by a BH this size IF you already weren't happy with a dedicated mini excavator of 7000 lbs.
Question is, how many stumps do you actually have, and how patient can you be while removing them a few at a time?
Renting a 30K excavator is on my list of options. Cost for that is about $2000 per week or a little more with delivery and rental protection.
/ Hydrostatic Tractor, Loader, Backhoe Options #11
I would think this is smartest option if you have a lot of stumps. Take a week of vacation and just clear all the stumps you have. Then get a smaller 30-40 hp CUT and do the grading / filling etc... and use it around the property.
Just had the 5 acres clear cut so I'm guestamating 900 to 1000 stumps. I have 3 years before having to have something planted to keep the ag rating.
Haven't done all my research yet. I see the specs on a Kubota L45TLB is 42 engine HP, 32 PTO HP, with a digging force at the bucket of 5825 lbs.
Bucket digging force on the Bobcat E32 I rented was supposed to be 6968 LBS. Not sure they had the relief adjust right cause it seemed to give up pretty easy.
/ Hydrostatic Tractor, Loader, Backhoe Options #13
So pretty much a lifetime of digging stumps with a SCUT or CUT... lol. That's a lot of work even for week. I think forgo the excavator and get a very large dozer if you can fit it on the property and just go to town.
/ Hydrostatic Tractor, Loader, Backhoe Options #14
/ Hydrostatic Tractor, Loader, Backhoe Options #15
If you get a 110 or L45 either will remove most stumps. I would see how many I could get out first and leave the remaining stumps for a large backhoe such as a Deere 710 or Cat 426 size machine. My reasoning is there are a lot of these older backhoes around and you may find an owner operator that can remove these remaining stumps at a lower cost. For all but the largest stump removal the 110 can easily handle the rest of the clean up.
Used as a tractor with three point hitch and three rear hydraulic outlets it seems to work well in my use. Worked pretty well with my MX6 mower and 673 tiller as well. Using a 110 as a tractor does have one limitation, I found that for high draft loads not having extra rear wheel weights can be an issue. Deere does not recommend adding weight to the rear wheels using the backhoe. You will experience more wheel slip pulling a heavy box blade than my weighted 4520. While both machines will work the 4520 will do a better job.
That said above I would recommend the 110tlb and would also recommend the L45 and larger M59 tlb.
Edit, With 1000 stumps to remove or 200/acre the $2000 /acre for stump removal and clean up seems reasonable to me. Larger equipment would be a more cost effective way to go.
How difficult is the backhoe to remove on your 110?
I didn't think the 10 grand to dig them all up and burn was a bad price. I tried calling the guy back and he didn't return my call so he may have had second thoughts.
Like I said above, I have 3 years to piddle along with it and I kind of enjoy the work. I've done a fair amount of cutting other trees with my chainsaw and dragging them out to the piles with my little 855. Can drag most of the stumps I dug out with the Bobcat too.
/ Hydrostatic Tractor, Loader, Backhoe Options #17
Get one of these... :)
/ Hydrostatic Tractor, Loader, Backhoe Options #18
I am getting old and slow but can still remove the hoe and switch to top n tilt hitch with another implement in 15 minutes. That is not a problem to worry about, I have seen people fight hooking up implements longer than that.
Pulling stumps with a backhoe or excavator and having a lot of them you need to be able to pull them up easily. With a thousand of them you don't need to have to dig around all of them to get them out. If you have a lot of small stumps the 110 can be effective an you should be able to get most of them out and carried to burn piles. That would leave the larger stumps for a larger machine to deal with. You would quickly be able to decide which stumps you could remove efficiently and which ones to pass up. I think you will find that you need to be able to get a high enough percentage of the stumps out to be able to smooth the holes out as you progress. Otherwise you will have a mess when it rains. To be clear I am saying you need to be able to make enough room to be able to drive around the larger stumps.
If you use the 110 to do most of the clean up work, building up the piles then the stumping cost for the larger machines can be reduced.
How big are the stumps? Is this fresh cut or has it been several years since cutting? What type of trees?
I knew this query would go off track. While I appreciate the motives I don't want or need advice on my situation. I want to know if there are other options on a mid size TLB and any pros or cons on those brands/models.
/ Hydrostatic Tractor, Loader, Backhoe Options #20
You have a lot of stump grubbing, even for a compact TLB like the 110. Aside from hiring it done or renting some large equipment and doing it yourself, another option that hasn't been mentioned is buying a used full-sized TLB for the stump work, then selling it and getting a compact for ongoing maintenance chores. TLB's in working condition can be found and will probably also sell for about what you paid.
Fork and Frame Mini Skid Steer Attachment (A61567)
Fork and Frame...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
