house circuit breaker question.
/ house circuit breaker question. #21
Nope not the same.. 3 way switch is a single pole double through switch and a 2 pole switch is a double pole single throw switch..
/ house circuit breaker question. #22
A 3-way switch is also described as a single pole double throw, maybe that's where the confusion in terms comes from.
/ house circuit breaker question. #23
"Not sure how to answer because I don't know what you mean by double pole switch."
LD1, Maybe I was told wrong 30 years ago, I have a light switch at top of my stairs, I have another light switch down cellar/basement, when I flip the switch upstairs the lights come on, I go down stairs next to the outside door and flip the switch, the lights go off, then I go out side, now I know it's not a single pole switch, but is it a 3-way light switch or a 2 pole light switch?
/ house circuit breaker question. #24
NOT double pole.
3-way or
Single pole double throw
Either are correct.
It IS a single pole.
/ house circuit breaker question. #25
"Nope not the same..".........................If this answer was any clearer than that, it would be water, but the explanation put's me in over my head and over my pay grade. I'll be re-reading this trying to understand it.
/ house circuit breaker question. #26
Confusion of terms is exactly right, in the last hour, my hair has turn 3-way double throw greyer
/ house circuit breaker question. #27
NOT double pole.
3-way or
Either are correct.
Ok, before my com. runs out of ink, have you ever heard of a "3-way or Single pole double throw" light switch with built in light so I can see it in the dark so I can find/see the light switch on when I come in from out side? Tied of grabbing turning banging everything else but the light switch when I walk in, or am I the only one in the world with this problem.
/ house circuit breaker question. #28
Leviton R72-05613-2WS is one of them. About $10 at Home Depot.
/ house circuit breaker question. #29
You're working with 3-way switches at the top and bottom of the stairs. 3-way switches are single-pole double-throw (either switch can supply power to the load)...as opposed to a standard switch which is a single-pole single-throw (only one switch supplies power to the load). Double-pole switches will switch two lines simultaneously...similar to a two-pole breaker, which is a 2-pole single-throw.
/ house circuit breaker question. #32
The "3-way" description is a term used by electricians. The "single pole double throw" description is the more proper basic description of what the switch does and how it works, even though it probably won't get you the correct switch in a search. Sort of like a "crescent wrench" versus a "adjustable wrench".
/ house circuit breaker question. #33
Going to a lowes or homedepot and asking for a single pole double throw switch will prolly get some funny looks too.
/ house circuit breaker question. #34
Asking ANY question at home depot will get funny looks:laughing:
/ house circuit breaker question. #35
I was thinking this very same thing today, the next time I go to HomeDepot I'll ask for a 3-way single pole double throw light switch, just show what I know about the double throw, but to be fair, there have been a few times in the past couple year's at HD and Lowes where the guys have been very helpful to me, and that could be from more store competition. I guess I was told wrong all those years ago that I needed a 2 pole switch.
/ house circuit breaker question. #36
Its amazing how easy it is finding something online when I type in the right description, (3 way illuminated light switch), just bought a name brand Leviton 3way single pole double throw illuminated light switch on ebay. Next week I' should be able to walk in my cellar and find the light switch without knocking everything else over.
/ house circuit breaker question. #37
Single pole single throw = spst
Single pole double throw = spdt,
You get the idea: image-1272563277.jpg
/ house circuit breaker question. #40
SPDT switches operate in series. The 1st switch selectively powers either pole of the second. Only the second switch applies power to the load.
larry
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
Decorative Pelican Statue (A61574)
Decorative Pelican...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
60" PIN ON EXCAVATOR RAKE (A64279)
60" PIN ON...
