house circuit breaker question.
   / house circuit breaker question. #21
Nope not the same.. 3 way switch is a single pole double through switch and a 2 pole switch is a double pole single throw switch..
   / house circuit breaker question. #22
A 3-way switch is also described as a single pole double throw, maybe that's where the confusion in terms comes from.
   / house circuit breaker question. #23
"Not sure how to answer because I don't know what you mean by double pole switch."
LD1, Maybe I was told wrong 30 years ago, I have a light switch at top of my stairs, I have another light switch down cellar/basement, when I flip the switch upstairs the lights come on, I go down stairs next to the outside door and flip the switch, the lights go off, then I go out side, now I know it's not a single pole switch, but is it a 3-way light switch or a 2 pole light switch?
   / house circuit breaker question. #24
NOT double pole.
3-way or
Single pole double throw
Either are correct.
It IS a single pole.
   / house circuit breaker question. #25
"Nope not the same..".........................If this answer was any clearer than that, it would be water, but the explanation put's me in over my head and over my pay grade. I'll be re-reading this trying to understand it.
   / house circuit breaker question. #26
Confusion of terms is exactly right, in the last hour, my hair has turn 3-way double throw greyer
   / house circuit breaker question. #27
NOT double pole.
3-way or
Either are correct.
Ok, before my com. runs out of ink, have you ever heard of a "3-way or Single pole double throw" light switch with built in light so I can see it in the dark so I can find/see the light switch on when I come in from out side? Tied of grabbing turning banging everything else but the light switch when I walk in, or am I the only one in the world with this problem.
   / house circuit breaker question. #28
Leviton R72-05613-2WS is one of them. About $10 at Home Depot.
   / house circuit breaker question. #29
You're working with 3-way switches at the top and bottom of the stairs. 3-way switches are single-pole double-throw (either switch can supply power to the load)...as opposed to a standard switch which is a single-pole single-throw (only one switch supplies power to the load). Double-pole switches will switch two lines simultaneously...similar to a two-pole breaker, which is a 2-pole single-throw.
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
ALL AMERICAN BIG J SERIES (A51243)
ALL AMERICAN BIG J...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
UNUSED FUTURE MINI EXCAVATOR HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
