sand spreader
/ sand spreader #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I have an 800' shale driveway. About 3times a winder I get iced up real bad. I need to spread sand. What are some good ideas to store/spread the sand?
/ sand spreader #2
I have an 800' shale driveway. About 3times a winter I get iced up real bad.
__________________________________________________________________________________________________
Hello Chuck172,
It is all going to come down to what you can afford.
A spinner spreader will waste more salt and sand than a pendulum spreader due
to the spinner UNLESS you can purchase one with baffles to direct the sand.
I have no idea what the drop spreaders for sand cost now but they were expensive
when I checked the last time as they are ground driven units.
As you have a 4 wheel drive mule I hope your tires are loaded and you have chains too.
As far as sand goes you have to decide whether you want concrete sand or mason sand.
Any type of sand will freeze unless it is stored indoors with a heat source.
Putting the sand in a bin that is above the ground helps to keep it from freezing as
it is not in contact with the ground.
Another option is dumping it on a round silo tarp and having a second round
silo tarp to cover it and sealing it with a layer of sand to hold the edges in place.
If you have a salamander you can heat the pile up for an hour and then use it
BUT the sand will become a magnet for moisture.
Sticking a dehumidifier under the tarp after the load is dumped will get rid
of all the water in the sand if you buy a truckload of it. Gravel sand is washed to
skim it away from the gravel after while it is screened and after it falls through
the screener.
It all depends on what you can afford or spend.
Buying a pallet of bagged mason sand is another option where you can simply store it indoors
and you have no issues with moisture or freezing clumped sand.
A small three point hitch mounted spinning spreader would work well if you keep the
mule indoors so the spreader stays dry too.
I will tell you that a bag of sand goes a long way when it is spread.
/ sand spreader
thanks leonz
/ sand spreader #4
Herd makes a spreader designed for sand. It has a more robust agitator to keep sand fluid. The local mall has been using them for over 10 years now and are on their second one with their new tractor. It works well. PTO Powered Sand Spreaders, Salt Spreaders
/ sand spreader #5
Why not use stone dust ( small stone pebbles )they are less susceptible to freezing and can be stored in weather proof box or container. Its what we use, throw a bag of salt in the odd time and stir.
/ sand spreader #6
I used a rotary (spinner) fertilizer spreader and dry "play" sand. Extended the top link to get better coverage, lower gear, and hit it twice, going and coming. That worked well for flatter ground and had sand barrels at hills to be able to add as needed.
/ sand spreader
Is stone dust quarry process?
/ sand spreader #8
I've got a Herd spreader, 750s. Works well but it get's mighty cold up here and if it's down near zero the sand will freeze to the sides of the spreader. Even with the agitator banging the sides it still sticks. I leave the sand outdoors and just dig through the frozen layer to get to stuff that I can shovel. Before that I just used sheetrock buckets and would fill a 1 gallon bucket that I used to spread it. It really wasn't that hard. I have a side by side (a pickup would work well too) and would just stop near each spot I wanted to sand, do it, then move on. The spreader, even used, wasn't cheap and you still need to shovel the sand into it. Not sure if it will ever pay for itself but I now get to use the tractor even more.
/ sand spreader #10
I got my father a 3ph Polly fertilizer spreader. It works very well with straight salt. But with sand, it needs to be completely dry and any if not it will clog the spinner. If you have somewhere to keep sand inside and dry you would be ok. Even mixing 80/20 sand salt would help.
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
Jack Daniels Metal Decorative Sign (A64557)
Jack Daniels Metal...
2018 VOLVO VNL860 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2018 VOLVO VNL860...
JOHN DEERE LOADER MOUNT QT BALE SPEAR (A64278)
JOHN DEERE LOADER...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64556)
2022 Chevrolet...
