Show What Tool You Made*
/ Show What Tool You Made* #421
Made a front and rear blades for the BX, went looking for a new snow plow all dealers were out of stock. Made the blades out of a 100gal upright LP tank.
Wow, I like the propane tank blades. I will remember that when I build my front loader grader blade. I made a grader blade for my backhoe bucket. It is 1/4 inch bent to 35 degrees to form the "moldboard" with a Tractor Supply King Kutter 6 foot cutting edge from a box blade as the cutting edge. I make a plywood mock up of the "glove" mount to slide over my 24 inch backhoe bucket. This mockup let me design it so it would clear the backhoe's boom when I stowed it and the bucket's teeth would clear the cutting egde's bolts. A chain holds it on, but allows it some slop to grade a little on an angle.
The welding shop that bent the 1/4 inch plate couldn't bend 6 feet, so they cut it in half and bent two, 3 foot sections and welded it up. 9-15-13  Painted Grader Blade Backside.jpg9-13-13 Grader Blade Glove Mount.jpg9-13-13 Grader Blade Bend Profile.jpg
hugs, Brandi
/ Show What Tool You Made* #422
I used to build tap-holders that hold taps from 6-32 to 0-80. A very solid rig. You can cut a perfect 0-80 thread in titanium like butter. I sold as many of these as I could make for $75 each to other knifemakers.
Welcome to TBN Mean Green.
Very impressive finished products, and intermediate processes. :thumbsup:
Rgds, D.
/ Show What Tool You Made* #423
The craftsmanship of some of you guys is just exceptional. By comparison this effort of mine is almost too rough to post here but it did the job for me today and might help someone else out out of a jam.
I backed the tractor into one of the taps that is connected to my bore. The tap was on a black poly pipe riser that was threaded at both ends. I snapped off the tap and most of the top thread. (The bottom end was under concrete so replacing the riser would not have been simple). I don't know if you can get glue-on connections for black poly pipe but the hardware store is a miles away anyway so I decided to try and make my own die and cut a new thread.
Using my angle grinder I cut chunks out of an old 3/4" galv tee piece. Its a bit of a mess but I got an arrangement that worked. 4 angled teeth, about 1/4" wide, with about 1/2" space between them. (If I was making it again they would be a lot more evenly spaced.) You need a lot of space between the teeth to allow the plastic to shed off.
At first the new thread was so rough that I thought I was wasting my time but as I cut further down the thread became a lot cleaner and sharper. Eventually I cut about twice as much thread as I needed and then cut off the top inch. With a few turns of plumbing tape the tap went back on and sealed perfectly.
/ Show What Tool You Made* #424
alchemysa - You just gotta love back yard mechanics. Very clever. :thumbsup:
/ Show What Tool You Made* #425
this is not my invention.... there is a video on you tube already - I just copied it...
I wanted to make raised beds - with the tiller.. so I copied that guys design...
Use 2X8X10 - makes a 8 inch tall bed raised above the ground - have a five foot tiller (for the commercial folks I am sure my tiller is a POS - but it woks...)
I reduced the output to 30 inches, so I get 30" wide 8" tall raised bed directly from the tiller output...
/ Show What Tool You Made* #426
Alchemysa, it is said that when a real farmer needs a tool, he builds it. You, my friend, are a real farmer. Well done.:thumbsup:
/ Show What Tool You Made* #427
I have done something similar to clean up the threads on a wall fitting for a shower arm, using a grinder on a pipe plug. The fitting was too shallow to allow a proper tap. This was after picking the remains of the old shower arm threads out of the fitting. Didn't take much to clean up the remaining putty and metal bits and straighten out the threads. A little tape and everything sealed up nice.
/ Show What Tool You Made* #428
I have lots of stumps and trees to remove so I put together a single tooth ripper for my mini excavator. This is just a mock up and it has to be welded.
/ Show What Tool You Made* #429
I adapted this front end loader from (I think) a B6100 onto my B5100. I had to make a new subframe, and added a hydraulic pump driven off the front PTO since the built-in pump is too small to run a loader w/ 2" cylinder. I replaced all the hoses and added a 10 micron filter in the return line. The only tricky part was making an adapter to connect the pump to the 18 mm, 22 tooth spline on the front of the crankshaft. I ended up using a Fenner shrink disc to squeeze a sleeve onto the spline shaft.
- Bart
Yeah, I know. They are probably an antique by now. I suspect there is some similar container out there that would work also.
I put my magnet on the end of a piece of brass rod and put the magnet in a pill bottle. To get it to drop something, just hold the bottle & raise up the magnet with the brass rod.
BTW, it's really difficult to put a photo on here. What am I doing wrong?
/ Show What Tool You Made* #431
/ Show What Tool You Made* #432
Not as useful as others but fun none the less.
/ Show What Tool You Made* #433
Hi JWM,
That's very interesting...
I need weatherproofed models to mount at the corners of my house and on the perimeter of my property, and if you could manage to make them belt-fed I'd really be pleased...
:thumbsup:
Otherwise I'm back to square one with stealing the concrete noise barriers from local highways to wall off my "estate".
:mischievous:
Thomas
/ Show What Tool You Made* #435
This is a good old thread time to wake it up.
I made this rolling tool chest exactly 30 years ago. We didn't have much money so couldn't buy a steel one. I had some material left over from a cabinet job. The casing and drawers are glued and stapled. The drawers have adjustable dividers. On the bottom there are oak boards that the casters screw into. After 30 years it is just as solid as new. I have several steel roll-aways now but this is still in daily use.
/ Show What Tool You Made* #436
For me, it's just beautiful when something get made and used for so long.
I have some wooden ones I inherited from the guys in the maintenance shop in my hospital, when they retired.
A few of them even left a few tool in them for me.
I will being using them for the rest of my life, amd leaving them to my nephews when I'm done with them, as my father-in-law did for me.
/ Show What Tool You Made* #437
That came out great. I know you have metal ones now but no need to ever replace that and if you did, I'll bet you would still gravitate back to the wooden one. I have an old toolbox that I have since replaced with a much better and more expensive one but I still use and prefer the old one. Some things money can't buy.
/ Show What Tool You Made* #438
Not sure everyone would consider it a tool, but it makes mean bbq
/ Show What Tool You Made* #440
This is a good old thread time to wake it up. I made this rolling tool chest exactly 30 years ago. We didn't have much money so couldn't buy a steel one. I had some material left over from a cabinet job. The casing and drawers are glued and stapled. The drawers have adjustable dividers. On the bottom there are oak boards that the casters screw into. After 30 years it is just as solid as new. I have several steel roll-aways now but this is still in daily use. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=459789"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=459790"/>
I'D take your wooden roll cabs over new steel ones ANY day! :)
Terry
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2011 TROXELL...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A64557)
2018 Freightliner...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
AR500 Deer Target (A65640)
AR500 Deer Target...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
