Show What Tool You Made*
/ Show What Tool You Made* #281
that's the thing. I replied late at night and actually went back to the page a few times and I was right after the post about the magnet..then it was moved..but its all good
By default, the TBN forum software puts posts on the order of the time/date when they were posted. If you hit "reply with quote" you will have a copy of the post you are replaying to in your post.
Aaron Z
/ Show What Tool You Made* #282
Just did the timing belt on my son's Jetta. Yet again another example of the people that build stuff never having to work on it.
16mm socket needed to remove the motor mounts but the bolt is recessed in the mount too far for a standard socket and the body is in the way to use a deep socket or extension. Took a spare 16mm and 10mm, cut about 1/4" off the 10mm to get the right length and welded them together. Deep socket is there as a comparison for length.
To adjust the tension pulley, I couldn't find my snap-ring pliers which would have worked so I had to come up with something else. Using a method suggested earlier in this thread, a couple stubbs of welding rod fit the holes perfectly so I welded them to the side of another spare socket. Worked great until I realized that I couldn't tighten the center bolt with the modified socket in place so I made the next tool.
Used a piece of 1/8 x 3/4 flat, narrowed the end to 3/8" then drilled a couple holes for more welding stubbs and tacked them in. When my mechanic buddy came over to verify timing prior to reassembly, he asked for snap-ring pliers and I handed this to him. He was impressed.
/ Show What Tool You Made* #283
next time look for a grinder wrench ... a handle with 2 pins and the center between the pins hollowed out .... ( a long Y )
BTW , what year Jetta?
/ Show What Tool You Made* #284
Ya, I can never find my grinder wrenches when I need them for the grinder, never mind other uses. I'm skeptical that they would have fit anyway. Good thought though.
2002 with the 2.0 motor and about 235,000 km on the original belt
/ Show What Tool You Made* #285
I always use my welpers when I need to remove something from the grinder.
/ Show What Tool You Made* #286
makita ones for the 9005B fit the rear calipers ... and Bosch / B&D / , all use different sizes ...
that's a lot on the belt . try to hold it under 140K between changes ... and YES they are a pain to change ... I've used a pair of long needle nosed pliers too...
get ready ... slide under and make sure the VNT actuator is working , they tend to stick and the motors go into limp mode ...
/ Show What Tool You Made* #287
I'll have to try that on the rear calipers...brakes is next weekend. Bought the car with 225k on it front the original owner and just finally had time to get to it.
What's the VNT actuator?
/ Show What Tool You Made* #288
if your car has a turbo .. ( most do, varoom :) ) it is the tin can underneath and beside the exhaust that pushes and pulls the variable vanes on the turbo .... closes when running slow ( to bring boost on early ) and opens the vanes when the motor starts to rev ( to maintain a safe boost level ) ... so you don't blow head gaskets from too much pressure ...
front ones just push in with a big C clamp ...
you can also do the rear calipers by using your pins and a socket ( like you did before ) and a big C clamp ....
compress the piston slightly , and turn the socket with pliers to walk the piston in a bit , tighten , twist , repeat ...
watch for the park brake actuators ( levers on the back of the calipers ) the rubber boots fail and the levers seize in the ON position.
/ Show What Tool You Made* #289
No turbo, not on the 2.0s we have. The 1.8T is certainly nice to drive by comparason.
I made this doing the brakes on the other son's jetta:
Was doing rear wheel bearings & brakes on my Son's Jetta. Rear calipers are a stupid screw-in design rather than the normal push in style. Mechanic buddy of mine lent me his snap-on set doing the first side but had to give it back before I got to the second after fighting with the bearing for a week. Dug thru the "too good or too many to throw out" bins and made this in about 15 min which is about the same amount of time it would have taken to drive to his house and back.
Did the job and actually worked about as poorly and the snap-on one did. As a bonus, the head is removable to compress regular calipers if I want rather than using a big C clamp.
/ Show What Tool You Made* #291
Here's a handy gadget I made several years ago.
It is a Kodak 35mm film container with a magnet inside for collecting up the metal chips when drilling holes. The chips are attracted to the magnet and stick to the plastic container. To get rid of the chips you just hold the container over the trash can and shake it. The magnet inside moves and the chips fall off. It saves you from getting metal chips stuck in your fingers while cleaning up.
/ Show What Tool You Made* #293
What us a film container in today's world!
/ Show What Tool You Made* #294
Yeah, I know. They are probably an antique by now. I suspect there is some similar container out there that would work also.
/ Show What Tool You Made* #296
I use a ziplock bag with a magnet inside.. kinda same idea.
/ Show What Tool You Made* #297
or wrap with plastic bag and tape ...
any way you look at it , it works ;)
/ Show What Tool You Made* #298
Sweet deal. If those film containers are hard to find, just use a plastic soft drink or water bottle. :)
/ Show What Tool You Made* #300
Is a little unsure if it qualifies as a tool but it can certainly give someone a idea. Had a small project truing up a drum on a excavator, a piece of flat steel tacked to the machine to keep the grinder steady so I get correct diameter to fit new sprocket wheel.
2021 Ram ProMaster 2500 Cargo Van (A61568)
2021 Ram ProMaster...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
UNUSED CFG INDUSTRIAL QH12R MINI EXCAVATOR (A62130)
UNUSED CFG...
2018 Infiniti QX60 AWD SUV (A61569)
2018 Infiniti QX60...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
