Bump up lift capacity of L3400/LA463 Loader
/ Bump up lift capacity of L3400/LA463 Loader #201
The only relief valve I see is on the bottom of the hyd block and takes shims.
Your pump flow is 9.4 GPM, so run the engine at max and check pressure.
You should stay about at least about 50 to 100 psi below the pumps max rated pressure.
31351-37950 100 SHIM 0.4mm
31351-37960 100 SHIM 0.2mm
31351-37970 100 SHIM 0.1mm
/ Bump up lift capacity of L3400/LA463 Loader #202
how about this
3000 PSI 2.5" LF LM GAUGE
3/8 X 1/4 NPTF COUPLER
3/8" X 12" 3/8 NPTM X 3/8 NPTM 3000 PSI HYD HOSE
and what ever quick coupler male end you need for your Kubota that takes a 3/8 NPT male end. or an adapter if needed. But the whole thing should be a lot less than $50.
Kens bolt on hooks sells a nice gauge and has a nice video on YouTube on how to do it. He is also
Between the gauge at Surplus center and the M/F adapters at Kens, this has now become a lot cheaper than the McMaster route. Thanks!
I have a tee on mine and leave it on the lift circuit. You get a good idea how much you are lifting that way.
I'll send you a PM... What part of TN? Just got back from driving from Chattanooga through Knoxville and up I-81 into VA.
Remove a FEL hose and replace it with gauge, push lever. View attachment 405093
That was me, I only added 150# and it was an accident, laying upside down, I turned the wrench in the wrong direction. It moved pretty easy so I checked the pressure again and it was close enough.
Thanks for the offer. Due to a much lower cost than I originally thought, plus LD1's idea of leaving it in place, I think that's what I'm going to do. After I get done with an Eagle project today, I'll be ordering the parts this afternoon.
Thanks!!!
/ Bump up lift capacity of L3400/LA463 Loader #203
FYI, depending on the dealer that does the setup, check the relief valve for tightness after installing the gauge. The reason you get two different answers on whether to use shims or just adjust the relief valve is that some dealers will over-shim the relief valve and set the pressure by turning the relief valve in until desired pressure is achieved. Mine was done that way and when I shimmed mine originally and bottomed the valve I ended up with 3300psi(spec on mine is 2347psi). I actually had to remove two of the shims that were installed and bottom the valve to end up with 2700psi.
/ Bump up lift capacity of L3400/LA463 Loader #204
Ok, that explains the difference. Let's hope mine is the latter so I don't have to mess with shims and taking the relief valve apart. I'm going to try to get to 2700 as my target psi.
Still gotta order the parts, tomorrow, too tired from an Eagle project!
/ Bump up lift capacity of L3400/LA463 Loader #205
Just did the PRV on the loader valve on my B2910 (LA 402 loader ) ...
Was reading about 100 psi low (1900-ish) ... added two 0.4 mm shims to the existing shim in the PRV ... took it up to 2200 psi.
Next on the list is to check the PRV for the 3PH, then the one on the rear remotes.
/ Bump up lift capacity of L3400/LA463 Loader #206
Been following this thread closely I've been wanting to check my L3400/LA463 loader with meter as described by lots of TBN members here. I don't have any problems or complaints with my tractor but was gonna shimmy it some according to specs if need be.
Problem :confused: I bought new liquid filled meter from Northern and new hydro/male/female couplins from TSC.I hooked it all up(tapped in) and I 'am getting a zero reading. I'am posting this before I get back to tractor and check to see if hydro fluid running through fittings(gonna have to take apart) and my other thought was bad meter or hole in bottom of meter somehow obstructed. I've cranked tractor up revved up some played with fel joy stick and nothing "NO READING" on meter.Like I previousely stated all new stuff not that something could have come defective. I even turned dial under seat both ways and no reading. Any other thoughts in meantime ? I'am I doing something wrong/misread something.
Big Thanks in advance I've been playing cowboy 40 something miles up road and have everthing hooked up wanting/waiting to check what I mentioned. :confused3:
Boone
Ok, another question: Looking at the first pic above, can anyone tell me which port does what? Especially the one that is closest to the FEL lock (blue cap is partially blocking).
That is the port I'd like to install my gauge on and then just leave it as LD1 suggested earlier. I have my MS 362 CM chainsaw holder attached to the FEL support column and want to clear it so I can see the gauge as I use the FEL. It would be great if that port was the one that lifts or curls the bucket up.
Thanks,
/ Bump up lift capacity of L3400/LA463 Loader #207
Install the hyd gage hose in a tee in the IN port of the first valve.
Then connect the gage where you can see it for troubleshooting or whatever.
/ Bump up lift capacity of L3400/LA463 Loader #208
What you say is true, but.
Curious why you did not install the gage in the IN port.
With gage installed in the IN port, it will indicate any pressure develops by your hyd. FEL, remotes, 3pt.
/ Bump up lift capacity of L3400/LA463 Loader #209
Thanks,
The hose or port with the orange tape is the feed from the pump on a Kubota. The green port/hose tape marking is the Power beyond, and the gray port/tape is the tank connection. Put a T in the orange pump feed to the loader valve and install your gauge. This will be ahead of the loader valve.
/ Bump up lift capacity of L3400/LA463 Loader #210
Hi All,
Just stumbled onto this thread and ordered the gauge, QD and bushing from McMaster Carr. Plan to check my L3800 and hope to be able to boost the lifting capability a little. I also have a JD 2305 and was a little disappointed the 3800 couldn't lift more than it can - granted, it's more than the 2305 but still... ;)
Regards,
Mark
Did you check your L3800? I am thinking about doing this to my tractor and was wandering if the pressure relief is set conservative.
Has anyone checked on the L3800?
Rick
/ Bump up lift capacity of L3400/LA463 Loader #211
Several reasons actually.
First, the location wasnt the greatest to be viewed from the operators seat.
Second, with a little math and experience, I can judge pretty close, how heavy something is that I am lifting. If I had that on the IN port, I wouldnt have any idea if the pressure I was seeing is from the curl, 3PH, or lift circuit. So I put it on the lift.
It is also installed with quick connects. So if I need to check/troubleshoot another circuit on the FEL, I can move its location easily.
Here is what my install looks like:
/ Bump up lift capacity of L3400/LA463 Loader #212
View attachment 405516View attachment 405517
LD1, what exactly is the female/male connectors on the FEL are they ISO 7241 A's or ISO 7241 B's? are they 3/8 or 1/2? I never was sure what they were.
/ Bump up lift capacity of L3400/LA463 Loader #213
You can read the pressure for each spool operated on the tractor with the gage in the IN port of the first valve.
You can also figure load using pressure on the 3pt.
/ Bump up lift capacity of L3400/LA463 Loader #214
So am I correct that simply turning the bolt in ( tightening it ) that is May bump the pressure without swapping washers ?
/ Bump up lift capacity of L3400/LA463 Loader #215
Not sure what the iso number is. They are parker 60-series in 3/8"
/ Bump up lift capacity of L3400/LA463 Loader #216
Yes, that only allows me to see what pressure it takes to operate. After the valve is closed, I am no longer getting feedback as the circuit is isolated.
I like the dynamic feedback. Like when pushing on something with the FEL, I can see pressure climb. When using curl to try to lift something the loader wont, I can see how high the pressure is getting in the lift cylinders. When loading a bucket full by hand, weather its stones from the field or firewood, I can keep an eye on the gauge to judge the weight.
/ Bump up lift capacity of L3400/LA463 Loader #217
If you have a L3400, no.
Your L3400 has shim type adjusters in the relief valve on the bottom of the hyd block.
You simply add the shims you need and tighten down the cap.
Start with the .1 mm and see how much increase you get, then add shims as necessary to achieve your goal.
Your L3700 is the same as the L3400 relief valve.
/ Bump up lift capacity of L3400/LA463 Loader #218
I
Thx,about a year or so ago I got shims from the dealer, just have not gotten around to climbing under the tractor to do it yet.
/ Bump up lift capacity of L3400/LA463 Loader #219
From the Parker web site.
60 Series Couplings are general purpose, double shut-off, quick disconnects that can be used in a wide spectrum of applications. They have poppet valves and manual sleeves. 60 Series couplings comply with industry standard ISO 7241, Series B.
/ Bump up lift capacity of L3400/LA463 Loader #220
If you have a L3400, no....
This is NOT correct at all, J_J... See ritschner post number 203 above to see why. It depends on how many shims were put in when the tractor was assembled (?). Not sure who puts them in. I was able to tighten and get 150 extra psi.
As for just blindly turning the nut without knowing the psi... you have to ask yourself, are you willing to gamble with buying a new pump???
Anyone willing to bump theirs up to 3000 to see how long it lasts??? :) I'm thinking of bumping it up to 2700, too :p
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2017 Subaru Forrester (A62613)
2017 Subaru...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
