J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
The only relief valve I see is on the bottom of the hyd block and takes shims.
Your pump flow is 9.4 GPM, so run the engine at max and check pressure.
You should stay about at least about 50 to 100 psi below the pumps max rated pressure.
31351-37950 100 SHIM 0.4mm
31351-37960 100 SHIM 0.2mm
31351-37970 100 SHIM 0.1mm
