Loader mounted blower
/ Loader mounted blower #21
I was also back at Cabela's and here are more pictures of the Sheyenne Toolings model.
View attachment 403370 (not sure I like all the hardware just for the chute rotation)
Extra filter hardware on loader arm.
PTO pump
Why they did not turn that thing into a true single stage with a solid auger with short narrow width flighting I will never understand!!!!!!!!!!!!!!!
The cross augers rotate as fast as the impeller as they are connected GGGGGGGGGGRRRRRRRRRRRRRRRR!!!!!!!!!!!!!!!!!!!!!!!!!!!
/ Loader mounted blower #22
Not so. Look at this picture:
It the speed is stepped up from the motor to the impeller (large sprocket on motor, small sprocket on impeller) and stepped down for the right side cross auger (small sprocket on the shaft coming from the motor and large sprocket on the cross auger).
Also note the bearing on the inner end of the RH cross auger.
Edit: Here is the OEM's site explaining their models:
Sheyenne Tooling & Manufacturing
Aaron Z
/ Loader mounted blower #23
Aaron Z
The cross auger is slower yes but the issues are the same
When you see their videos you can see the problems this
unit has with wet snow.
/ Loader mounted blower #24
Per their video, the cross auger spins at 183-200RPMs and the 2nd stage fan spins at 1100-1200RPM (they said that the fan spins at 1100-1200RPM and its 6x as fast as the cross auger), thats about twice as fast as a rear snowblower fan on 540RPM.
Which video are you referencing as having problems with wet snow? I see the one on their page where it isn't doing much in thin snow, but thats no different than I have seen with a 2 stage walk behind blower.
Aaron Z
/ Loader mounted blower #25
Again the design of any two stage snow caster with open cross augers
is problematic because not everyone has powder snow.
If these things were made as single stage units they would
perform much better and could not be plugged with wet snow.
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
Bobcat SC72 (A64127)
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2022 EZ-GO ELITE...
