Home-made attachments...
/ Home-made attachments... #163
Two homemade items here.
ry%3D400
1st is a 3pt receiver hitch....simply a copy of one sold commercially. Quite useful to move anything in the way of a trailer/etc.
2nd is a something I did come up with to roll off field fence wire. Piece of 2" square tubing (to go in the the receiver hitch hole ), then a piece of flat plate , and a 3' piece of 2" pipe welded at a 90 to the plate to act as a "toilet paper holder" for the roll of wire.
To load a roll, I remove the top link of the blue hitch, and raise the lift arms as high as they will go, this puts the 2" pipe about 15 degree angle from the ground, slide the roll on, and tilt it forward, reattach the top link pin.
Worth building if you have a lot of field wire to install. I attach the start of the roll to a post, and simply drive down the line of posts. Throw a crow bar or piece of 3/4 pipe in the roll at some point to keep it from turning, and use the tractor to tension the wire ( very gently ! )
Later modification was a piece of 3/4" plywood on top the metal plate at the base of the roll..the roll would hang on those square corners of the metal plate, so I cut the plywood in about a 24" circle and screwed it to the plate. Solved that problem.
Sure wish I had one of those when I was doing my fence. Nice job!
/ Home-made attachments... #164
Why does it stick out so far from the hitch?
It would make a place for your future ex-wife to stand on the 2 inch tube and hold the fence roll while you drive as fast as you can through the pasture. You wouldn't want that roll of fence to bounce around too much and get dented.
/ Home-made attachments... #165
Here's a simple set of forks that I made for my BX25. Only used them a few times so far. Plan on using heavier angle next time I set this idea up.
/ Home-made attachments... #166
I've steadily worked, weather permitting, on the mods for my yard/pine needle rake. I added tines to get the spacing to every 3 inches and built a 3pt hitch so I could raise it higher to get it out of the pile of needles I just raked.
1., 2., & 3. 3pt hitch I made
4. & 5. rake on tractor
6. &. 7. before raking
8. some raking done
9. pile of pine needles 10ft in diameter and 3ft high. About halfway done on this side of house. I have a pile similar in size on the other side of the house.
10. after raking
/ Home-made attachments... #167
8. some raking done
10. after raking
:thumbsup:
/ Home-made attachments... #168
Nice job!
/ Home-made attachments... #169
A set of real forks with quick attach so you can swap between them and bucket is SO handy, I can't imagine being without them. I use my forks probably 5:1 over the bucket. Once you have a set, you'll start putting EVERYTHING on pallets or finding new ways to use the forks.
/ Home-made attachments... #170
Ok Ill Bite.. what the TV in the tripod at the end of video. Looks to be interesting also..lol
/ Home-made attachments... #171
ry%3D400
Wish I had an attachment like that years ago when putting up and taking down wood lath snow fence.... Would have been real handy...
I don't think snow fence like that is used much anymore...
Thanks for sharing...
/ Home-made attachments... #172
You mean the obelisk? The pyramid thing with the mesh on it? It's meant for in gardens for climbing vines.
I'm curious what the garbage can upside down under it is for
/ Home-made attachments... #173
Ok got ya...I have a water fountain that is supposed to be covered up during the winter. So I cover it with a large garbage container to give it the protection. As this looks ugly out in front of the house I made up this wooden structure to look something like a tree. The tree fits over the garbage container. I string xmas tree lights around the "tree" for the season. Here's a picture of it.IMG_4570 2.jpg
/ Home-made attachments... #174
My original idea was to use the "obelisk" exactly as you mentioned during the summer time. Haven't actually done it yet though. See my reply to chopped re the winter use of the structure.
/ Home-made attachments... #177
Ripper/hiller I built. Can change the angle of the foot by moving 1 bolt for deep ripping or tipped for hilling.
/ Home-made attachments... #178
:thumbsup: _____________________
/ Home-made attachments... #179
S-tine cultivator that started out as a 3 row 16' for large scale farming. My dad took a chunk out of it for his use and gave me the rest. Only bought steel for the rolling basket harrows. All other was re-used from original frame or scrap I had laying around. I use the snot out of this in my horse corrals all summer keeping the hard packed clay worked up and soft. Sides can fold down for an additional 42" coverage or folded up for close tight work.
/ Home-made attachments... #180
Rolling harrow pics. Still haven't figured out a way to keep the wing harrows up without the use of tie-downs. Not a big deal I guess. Also with the wings up it adds more weight to the center chunk to dig deeper.
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
Caterpillar 289D (A62180)
Caterpillar 289D...
2022 Case 5550 Trident Spreader LOW HOUR (A63118)
2022 Case 5550...
2018 GENERAC MAGNUM 25 GENERATOR (A62129)
2018 GENERAC...
2014 CATERPILLAR CB34B XW DOUBLE DRUM ROLLER (A62129)
2014 CATERPILLAR...
2014 John Deere Z930M Zero Turn (A63116)
2014 John Deere...
