Home-made attachments...
/ Home-made attachments... #121
ovrszd,
thanks for the reply. And yes I enjoyed the dig to Aaron.
Keep warm. Spring is not that far away.
John
John, us Northerners won't even say the word "spring" for another month. We're very dry up here, been below normal temps and the wind has blown almost every day for the last 60 days.
/ Home-made attachments... #122
Well, I'll be. I knew you guys talked different but I didn't know you had a different map too :D
/ Home-made attachments... #123
ovrszd,
John
/ Home-made attachments... #125
Better wait until Sunday and find out what Phil has to say. Feb. 2nd.
Screw that overrated rodent!!! If he says 6 more weeks of winter, I say choot 'em, choot 'em!!!! :D
/ Home-made attachments... #126
Up here the thinking is that on Feb 1st you better have half your hay and half your wood left because winter is only half over. Sometimes i'm jealous about you guys that might have spring in six weeks on the say of a ground hog.
/ Home-made attachments... #127
the ground hog is an over rated celebrity and a fake like all celibs. :groundhog:
/ Home-made attachments... #128
Plus he'll make a mess of your vegetable garden in a heartbeat.
The Plant Manager runs after them with her pellet gun whenever she sees one.
They can move surprisingly fast when they have a notion to do so.
I'm not so sick of Winter that I'm in the mood for unremitting mud just yet.
/ Home-made attachments... #129
Ya, he's only 40 + mile from me, I think this is his brother I got!!!!!!!
/ Home-made attachments... #130
Yeeehaww you got that there vermin.... I learned the hard way that lake surfaces refract light and it messes with your aim trying to get one like that many moons ago. Wait I'm supposed to be talking about home made attachments.... Does my cup holder zip tied to the ROPS count?
/ Home-made attachments... #131
Zip tie?
Boy, if Red Green could hear you now.
DUCT TAPE, man!
Duct
Tape
They say you only need two things to fix anything duct tape and WD-40
"if it is moving and it shouldn't be use duct tape if it isn't moving and it should be use WD-40"
/ Home-made attachments... #133
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=358352"/>
:thumbsup:
/ Home-made attachments... #134
Looks like a Dana 30 rear axle under a Jeep Cherokee or Grand Cherokee to me??? :)
/ Home-made attachments... #135
Actually, there are four things. The other two:
1. JB Weld for things that are leaking that shouldn't
2. Baling wire for stuff that needs to move a little, but not too much.
/ Home-made attachments... #137
Clever rock bucket design, makes it possible to build one without expensive plasmas/etc. and just a simple bender! I might try that this year, how much solid rod did you end up using?
/ Home-made attachments... #138
I bought 5 20' pieces and have 8 'left over. $45 ea Spacing is about 2" Used 1" hot rolled (I think it was hot rolled . The cheaper of the 2, hot or cold rolled) Bought the skid steer plate for $100. Used 2x 4 tube for framework and 3/8 plate for the sides. I tacked it all together nd had a welder get it solid as I doesn't have a big enough welder.
Whole thing was $550.
Each of the bars took close to 200 pumps on the manual hydraulic bender.
The welder suggested a last piece welded under the front plate on the bottom for more support.
Last thing the bucket front is 2 pieces a 4" wide and a 1" wide to form a lip
/ Home-made attachments... #140
If I have enough hay to get through March, I'm usually OK till around November.
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
WHEEL BARROW (A62131)
2015 LeeBoy 8510C Asphalt Paver (A61567)
2015 LeeBoy 8510C...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
