Texas Grapple Shootout
/ Texas Grapple Shootout
Somehow we missed the story of your customized Canopy shape?:laughing:
It looks like what a lot of us Yankees have done to ours..
Low limb, not a fallen one. That's why I did not get a cab. It also keeps the sun out of my eyes more on that side.
/ Texas Grapple Shootout #122
The curved teeth without the crossbar sink into the ground just as I imagined they would. I drive forward and tilt the grapple back slowly to take advantage of the curl.
The live brush/small trees are taken out in one of three ways with this grapple: 1. The teeth pop the roots out. 2. The jaws clampdown and I pull the bush/small tree out. 3. The "V" at the back of the teeth traps the stems and I push them out.
Don - That's EXACTLY what I'm hoping to do with mine when I get one. I've been reading everything I can on these things and trying to find all of the manufacturers to see how their rake grapples are designed. I came across the ones from The Rake Shop a few days ago (before I read this thread) and thought "WOW! That's a good design!"
I don't want to hijack your thread so I am probably going to start a new one looking for advice on all the options that I've been considering for what I need to do around. And not all of the options involve grapples. There's a lot of smart, experienced people on this board that will probably point me in the right direction. Of course, right now I'm thinking the right direction is something similar to what you bought! :)
A look from the bottom and a "Wheel of Fortune" game for Ron. Category: Ranch name.
Parachute Ranch
Close enough.
You really need to get on that show! Even with the reflection I figured it at least would take you 2 hours.
Note: That is not the name of this place now. That was the sign on the front gate when we bought the place.
/ Texas Grapple Shootout #126
Don,
I have a grapple and your grapple is giving me Grapple envy, like Charlie.
Those 1 inch thick bottom tines makes it a heavy weight grapple in my mind. I only have 1/2 inch bottom tines and it is no lite weight. Your one inch tine design is exactly what I saw on that articulated forestry loader hauling longs. Let me know if you need some help trying to bend one of those tines.......or keeping the rust off!
hugs, Brandi
/ Texas Grapple Shootout #128
Again great grapple .. I'm still laying mine out and those pictures sure help .. I've got 3 hay accumulator grapple sets to get out and my personal stuff is on hold!!!
Don't be surprised when you see your message box loaded with pm's from me!!
Just let me know if you need a measurement or specific photo.
Well Brandi, it doesn't look so pretty any more. I used it a abused today and it took a bunch of hits and scrapes. It is one tough grapple it took everything I thew at it. I was cleaning up storm damaged cedar trees from 7 years ago. One of the hydraulic cylinder protective covers came off when a Yaupon limb hit it but it was easy to put back on. Looks like rain tomorrow so it will get a rest.
/ Texas Grapple Shootout #132
Don,
Well, what's an old girl without a few marks of experience. Glad to hear you are not babying her!
hugs, Brandi
/ Texas Grapple Shootout #134
My wife has got to get serious about that Lotto thing. If she hits the big one it'll be easier to add to the toy (errrrh) implement collection. And the Padre wants a new church.
Charlie
Very nice grapple. Do you know how much it weighs?
Tom, the shipping weight said 700#
I came close to your suggested opening width of at least 45" with 41.5"
My tractor can lift 2347# so that gives me an payload of 1647#. So far none of the largest dead trees I can find have exceeded that weight.
Assuming a square foot of dry oak weighs about 30# I can carry a 2 foot diameter tree that is about 26' long.
(disclaimer - This is a rough field estimate (on straight sided tree) and not knowing the moister content and the exact weight of the wood and not using the formula V = (D / 2)^ 2 x P x H / 3. In other words I lift till I can't then I know its over 1647#)
/ Texas Grapple Shootout #136
Remember to keep your front tire pressure up:thumbsup:
I forgot to check the pressure after these cold spells. When I was cleaning out the pond a while back and the heavy mud load would squish the front tires and air would leak around the rims. So Thanks, I will!
/ Texas Grapple Shootout #138
kick *** grapple don fer sure...if you ever do get something stuck in those "V"s -- you can normally get it out by scraping it backwards on the ground. The extra $200 for front door delivery was certainly worth it. I paid $1700 total for mine but I had to pick it up at the freight yard. (in Houston at the time). Living in Angleton and wanting the grapple up here meant I was going to have to haul it anyway.
/ Texas Grapple Shootout #139
Oh I see where you had listed the 700# earlier, sorry. 1647# is still a lot of weight to lift and your curved tines will naturally hold the load closer to the tractor allowing you to work faster. I often have to curl to get the load to slide back on my flat L bottom grapple. Your looks like a good combination between rake and L bottom. The classic dilemma is one top clamp or a wide single for back raking when choosing between rake and L bottom. Yours is the best for hauling.
I was raking with the bottom tines backward (smooth) and forward (sifting). I also have the box blade on for counter weight and it has a row of ripper tines, a.k.a. rake.
However, I had to disconnect one top and tilt on the box blade for the grapple.
Do they make a "Y" valved splitter for the hydraulic lines? I don't mind getting off the tractor to turn a valve but I do mind making sure all the pressure is off then yanking two lines out and the connecting two other lines.
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2015 Yamaha 350hp 4-Stroke Outboard Boat Motor (A66738)
2015 Yamaha 350hp...
2829 (A65055)
2829 (A65055)
PAIR OF TRACTOR TIRES AND RIMS (A67714)
PAIR OF TRACTOR...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
