Need help deciding on a grapple
/ Need help deciding on a grapple #81
Now I do think some of the light duty grapples I see, I would not buy. Look at how the anchor points are on the upper claw, and the cylinder.
I agree there are a few showing up on eBay that could give standard duty grapples a bad name. They just look too light to me.
/ Need help deciding on a grapple #82
Yep. You among others convince me of that before I bought the first time....about 85% of the way. Once I used, I knew I made the right decision. Thanks for the help back then.
BTW I didn't have a CUT then, nor now, but an M7040. And I worked that grapple hard. Now I do think some of the light duty grapples I see, I would not buy. Look at how the anchor points are on the upper claw, and the cylinder.
Yes, to be fair, I should have mentioned that at least one manufacturer used less than 1/4" top tubing on a light duty grapple in an effort to save themselves ten bucks. That is a mistake. I won't mention the name as I am not sure which of a couple manufacturers it was. But any light duty built with mild steel 3/8" tines and 1/4" square tube or pipe seems to handle the stresses of CUT use just fine. I also imagine that the high strength 1/4" tines on the EA light duty 48 are just fine too. Again, all of these grapples are more strongly built than any standard bucket so they are simply not delicate items. You can injure a grapple or worse the FEL by twisting with asymmetric pushing/lifting or by pushing with the top grapple open (all things that would injure a heavy duty grapple too) but for straight digging and lifting there is simply no way that an FEL with up to 3000lbs of lift (at least) is going to hurt a light duty grapple.
I have been arguing that point for years here. I don't know why people think grapples should be as wide as the standard bucket but in practice there is simply no real benefit and lots of disadvantages. Cost, maneuverability, net lift capacity, safer for the FEL as less risk of torquing, easier digging.....the list goes on. Wide grapples make sense for cleaning up construction debris but 48" is all you really need for most other tasks. Read through the thousands of posts here on TBN and see if you find anyone who complains that they wish they'd bought a wider grapple than 48".
The confusion continues for two simple reasons. Most important is that ANY grapple is better than no grapple so guys with 72" grapples are also happy (though poorer). The second reason is that dealers are still not thinking about the difference between a CUT and a skidsteer when selling grapples. Dealers generally don't have much experience themselves with grapples and so rely on SS standards for grapple size based on horsepower and typical SS commercial usage. Even the few dealers who have come to understand that 48" grapples make a lot more sense for CUTs are still being too conservative with the horsepower issue. Look at ANY light duty 48" grapple construction and then look at ANY standard factory bucket for a CUT. The grapple is made more strongly of thicker steel. Nobody breaks their standard buckets, why are dealers so concerned about light duty grapples on CUTs???
Im glad to see you guys discussing the 48" grapple advantages, I just got home from RCO tractor and that thing was built like a tank(1/2" steel) I was really impressed and it was reasonably priced at 1300.00... my only concern is I will be disappointed when in use on my larger cab tractor, when its on my CUT I think I will be really happy with it, the unit will likely be on the cab tractor the majority of the time.... you guys that have the 48" do you think if it was on a large cab tractor you would still be happy with it?
/ Need help deciding on a grapple #84
I didn't have a cab, but used on a 70hp Kubota M7040, and had no problem, and I used it hard. It was beefed up with 1/2 steel. I intend to rebuy the exact same grapple.
So....don't see why not.
I think u guys have me talked into the 48" grapple... I just priced running hoses from the front to back with a disconnect at the loader (not sure I need that I never take my loader off))parts alone came out to about 375.00 seems steep does that sound about right? FYI that 1/4" hose
/ Need help deciding on a grapple #86
For myself I am having a hard time finding one in the 50" range that will open far enough for my needs. Everybody I talk to wants me to buy a 60" heavy duty one and I DO NOT want that. Almost looks like I will build one myself or have MIE build me one. Here is a few pics of the mods to my econo grapple. grapple 001.jpggrapple 004.jpgand 1 loaded with 2 rows of hardwoodgrapple 005.jpgCJ
/ Need help deciding on a grapple #87
Seems high. I don't recall what I paid, but it wasn't that much. I used 1/2 hoses. I ran hoses from to back, with no disconnect in the middle...since I doubted I would take the loader off. And if I did, I would seeming coil the loader portion of the hoses off and tie off somewhere.
/ Need help deciding on a grapple #88
That sounds really high. First, I would not bother with the two part system. It just isn't that hard to take the hoses off if you ever do remove your loader. I don't take mine off much either but had a two part system on my Ck20 that I literally never took apart. It takes only about fifteen minutes to reroute the hoses to the rear if you ever do need to remove the FEL so save the cost of four fittings and four crimps and four quick connects by eliminating the split. Second, it sounds like you went to a local hydraulic shop and got full retail pricing. Figure out the length of hose you need (I measured with an old garden hose) and then buy something from surplus supply over the internet with fittings in place for a third the price that a local shop will charge to make things up custom. Also, 1/4 inch hose is all you need for flow but I'd personally use 3/8 if I did it again. Just a little tougher to stand up to brush etc under the tractor.
/ Need help deciding on a grapple #90
I did the same but ran 3/8" for running a auger for post holes. I did not do Q/D's for taking off the loader because it will never come off as long as I own it. CJ
yeah that might be a bit cheaper just to make 2 hoses vs 4 hoses.... I think Im with you on this one Ill see what the price difference will be.... any reason you chose 1/2" hose? I thought I saw on here I can get by with 1/4" hoses.
/ Need help deciding on a grapple #92
I bought my hoses local, but after I posted my last reply, started searching. Check here. Surplus Center
Actually, here is the page you want to start: Surplus Center
You should be able to get out of there for less than $150-175 or so even if you put together a two part system (just use double female SAE fittings rather than quick connects for the join).
/ Need help deciding on a grapple #93
I took IslandTractor's advice last December and got a 48" WR Long OBD-II for my Kubota L3940. Best attachment I have, bar none. I have some dense woods I work in (Minnesota behind the bluffs that run along with Mississippi) and the narrow grapple is way more maneuverable than my 72" bucket. I've moved a lot of logs and brush and I'm really a novice. I also use it to break up the soil, remove small root balls, and backgrading using the bar along the back. I've no complaints at all.
Regarding clearing, I had a guy come in with a Terex. Holy cow! 11 or 13 ton machine (can't recall) with essentially a 6' grinder on the front. He cleared 3 or 4 acres of scrub trees and a 900' fence line in 8 or 9 hours at $135/hr. He also put in a 1000' path through the woods, up some pretty serious terrain. We just marked the path we wanted with ribbon and avoided the really big trees. It took 45 minutes. Anything under 8-9" just goes over and is chipped. The thing is incredible.
I checked out that website and I'll be ordering from them.... a two hose set up is going to cost around 120.00 including fittings. Later tonight I plan on pricing a set up with the quick connects at the loader for a "cleaner" look if is cheap enough I'll go that route. I do have a question though... Im not real familiar with the different thread types for Hydraulics do I use NPT, JIC or SAE?? I was planning on NPT but wasn't sure if it was the way to go or not... Lastly you guys who ran 3/8" hoses did yall use 3/8" quick connects up front or 1/2"? 3/8" was a lot cheaper for the male/female set. thanks
that's a good point CJONE.. I will likely purchase an auger in the future, does your auger run good on 3/8" hose? I might save my self the headache of a redo and run 1/2" if necessary to run a hydraulic motor more effectively.
thanks Maibox... Ive pretty much decided on the 48" too... we had a ROW clearing crew come out with a huge grinding machine to maintain a ROW cutting through our property while they were here I had a 12' wide path cut through a section of my woods cost me 300.00 and saved me tons a time... that thing was awesome!!
/ Need help deciding on a grapple #98
No downside to 3/8 quick connects for a grapple. Just make sure you order the grapple with same or get it without qc and add your own.
/ Need help deciding on a grapple #99
I agree that the the 48" grapple should do everything needed and then some. I see no real advantage to a wider grapple unless you deal with a lot of firewood, want to carry multiple stumps or similar objects at one time, and don't mind only grubbing 4' at a time.
A narrower grapple is also cheaper so it saves money AND weight.
Unfortunately, the FACT remains, there is no one single grapple that is best for everyone, even the beloved48" single time grapple is not the BEST choice for everyone.
Of the thousands of posts here on TBN, I've never read any that day they regret going for a wider OR narrower grapple than they did. However, I've read some that say they regret going with HD versions.
I have narrowed my search down to 4 different models the first three are from ebay and are Titan brand and would like some feedback.... on the quality
this model is really a good price and I was hoping someone can attest to the quality of the unit
48" Grapple Bucket Tractor Brush Root Kubota Mahindra Rake Skid Steer Bobcat | eBay
this option is reasonable but a bit more only reason for the option is due to the dual grapple arms
60
this option is on the list because it offers a bit more width at a reasonable price
60" Grapple Bucket Tractor Brush Kubota Mahindra Rake Skid Steer Bobcat Root | eBay
and this option is the one at RCO it is built pretty solid but he is firm on 1375.00 which is a little high compared to Titans.
Root Grapple Attachment - Light Duty - NAI
If the units are not on back order at the ebay store Im leaning toward the 48" mainly due to the cost savings... but I was hoping someone has the titan brand 48" and can give a review of their experience with it.... thanks
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
