Hay wagons; let's see them!
/ Hay wagons; let's see them! #101
I use this one 10 bale MF 505 selfloader/unloader, capable of picking a stack back up
Has a fork on each side.
/ Hay wagons; let's see them! #102
Yet another approach. I've seen a few commercially built wagons made this way, so I thought I'd try it on one of mine. It costs less because there are no 4x4 cross members and 2x6's cost less per foot in shorter lengths than 16 foot lengths. I don't see why it wouldn't be just as strong. Now I have 32 2x6's supporting the outside edge instead of 5 or 6 4x4's. Time will tell.hay wagon.jpghay wagon 004.jpghay wagon 005.jpg
Should work, plus it's a little lower to the ground that way!
/ Hay wagons; let's see them! #104
Yet another approach. I've seen a few commercially built wagons made this way, so I thought I'd try it on one of mine. It costs less because there are no 4x4 cross members and 2x6's cost less per foot in shorter lengths than 16 foot lengths. I don't see why it wouldn't be just as strong. Now I have 32 2x6's supporting the outside edge instead of 5 or 6 4x4's. Time will tell.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=322634"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=322635"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=322636"/>
Looks good. I've replaced 3 4x4's and one main runner on my h&s basket like yours a few years ago so hopefully a full rebuild is a long ways away.
/ Hay wagons; let's see them! #105
Here is our squadron. Some old, none new, some borrowed, none blue.
/ Hay wagons; let's see them! #106
Actually, it's no closer to the ground because I had to use 2x10's for the stringers to be able to clear the tires.
/ Hay wagons; let's see them! #107
/ Hay wagons; let's see them! #109
Thank you
/ Hay wagons; let's see them! #110
Here is the hay trailer that my father built several years ago.
There are several advantages over some of the 4 wheeled wagons posted here.
  • It generally tows and backs nicely. No brakes/lights, but it is generally street legal (with follow vehicle), and could have lights added.
  • The Drop axle design means that the first row on the trailer is lower than the traditional wagons (where the first row starts at the height of at least the 2nd row on this trailer).
  • The tires/fenders are inset, so that it is rare to get bumped by a fender, or have one's toes run over (which can happen with a car trailer).
  • Square fenders are designed to be bale sized, so it holds the stack together.
One gets about 70 bales with 4 rows. (16+18+18+18) which is easy enough to load from the ground (50 to 60 lb bales). The fifth row is a bit tougher to load from the ground, but one can generally toss another 8 to 10 bales up on top if one wishes, and it isn't too late in the day.
/ Hay wagons; let's see them! #111
I have a running gear for one when I put the main runners for one how do I bolt it down? I was told not to bolt all four corners down so it can flex when going through the fields. Is this so? The way I was told to do it was bolt one down in the front and the other in the back? Is this rite? Please let me know. Great looking wagons everyone!
/ Hay wagons; let's see them! #112
We have all 4 corners bolted with no issues, but we have fairly even ground.
Aaron Z
/ Hay wagons; let's see them! #113
Its the only way we build wagons here, until looking on the internet I didn't know the other practice of running the deck lengthwise. You can pick your stringers to be 3/4" or so above the tires so they normally tend to be lower than most I see of the other style.
I'm in the process of redecking 6 running gears which has turned into an expensive project as I want to use steel main stringers so I don't have to do this again for a long time.
I have each corner bolted down and hay on very uneven terrain. It still flexes; believe me!
/ Hay wagons; let's see them! #116
Pretty heavy duty Tor! What will go in the box along the underside of the deck?
/ Hay wagons; let's see them! #118
/ Hay wagons; let's see them! #119
Storage for straps to tie down the load. Frame is built for 14 metric tons
Nice!
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2022 EZ-GO ELITE...
King Kutter II Tiller for sale.
King Kutter II...
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
Wooden Swing (A64557)
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
