AZ ranch
   / AZ ranch
I was able to get a coat of primer on my gate last weekend.
   / AZ ranch
I was busy grading this past weekend, but I found time to get a coat of blue paint on the gates. Next trip I'll do some red.
   / AZ ranch
Reflective tape may fit into it eventually, but the plan is to turn the gates into flags. The left gate will be the American flag and the right gate will be the Arizona flag.
   / AZ ranch #328
Mr Fuller that building permit must of been completed by now. So soon going to start the foundation then putting up the logs. They will have to be lighter with a year of drying out.
Are you going to take some off the top and bottom of log so will fit tighter?
ken
   / AZ ranch
Finally made it to the Ranch today. I've been traveling a lot at work so I haven't been here in a month. Tomorrow I'm having a 700 pound gun safe delivered.
I finally got all of my details finished up for the building permit and hope to submit everything next Wednesday.
I forgot to turn off the pump switch when I left a month ago. When I got here I could hear my water pump running but the tank was empty. It must have been running for days. I quickly filled the water holding tank and it actually pumps water to the sinks! But when I turn off the water the pump runs for about 15 seconds before it shuts off. It use to be 1 or 2 seconds. I guess I need to replace it soon.
   / AZ ranch #330
Glad to hear you are getting closer to the permit. Sucks about the pump. I found out the furnace at our farm is shot. Oh well. Good luck.
   / AZ ranch
I had a 700 lb. safe delivered today. I met the driver at the end of the paved road to guide him to my place, as some streets aren't named and some that are do not have signs. Upon meeting him, he said he doesn't do dirt roads. He said most companies won't drive them as they cause too much damage to the trucks. I could have sent it back but figured I'd go for it, so we loaded it in the little bed of my Tacoma double cab. It was only 7.5 miles, but it took me 75 minutes to do it. I was so nervous that the small straps I had would snap and it would tumble out of my truck, especially going up the hills.
   / AZ ranch #332
Mr.Fuller are you going to put the 700 lb. safe in your r.v. camper or the storage shed maybe just put it on the house pad and build house around it. ?
Building Permit about issued. or some one found a typing error.
Looking forward to the first logs placed on the foundation.
ken
   / AZ ranch #333
ken
   / AZ ranch
Going to the County tomorrow to try and get my permit. It's been 14 months. I so hope it goes through this time.
   / AZ ranch #335
Good luck Bo. I just went through it for a pole barn. I can't imagine 14 months. Looking forward to hearing good news.
   / AZ ranch #336
Trust all will go well with the permit. We will be thinking of you. We understand how much this means to you.
   / AZ ranch
Well, I'm closer, but no cigar yet. The Chief Building Officer and the plan checker met with me and we had a good discussion for a half hour. They said everything looked okay, but they wanted to review the engineer's calculations. Good grief, I thought that's why you paid the engineer. I did forget the spec sheet for the propane wall furnace, but they said I could just email that in. I also have to put a heat source in the bedroom since I have no ducting. I can email that in also. So while I still have no permit in hand, I'm pretty optimistic.
It is so frustrating to go through all this, especially when 150 miles away, in another county, a friend is building the same structure and his permit process took one day, two pages of plans, and $250. Mine is taking 15 months, 13 pages of plans, about 100 pages of backup material and will probably end up costing $15,000, counting the engineer, the soils testing, yada, yada, yada.
But my government is taking care of me. Yeah, right.
   / AZ ranch #338
Good thread. Hope the permit goes thru. The gov doesn't want your tushy to get cold in that bathroom...
   / AZ ranch #340
You need to hire an attorney today. There is no reason they should be jerking you around for this length of time. File a lawsuit and you will get the permit.
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
Kubota M108S (A53317)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
