AZ ranch
/ AZ ranch #181
Ranger Rick beat me to the punch with the suggestion of a mobile batch truck.
I used one for a small job and it was worth it to me. Whether they have them big enough to minimize cold joint possibilities is unknown to me.
/ AZ ranch #182
I don't think it will waste any lumber as none of the inside of the 4 walls will have any lumber. Only interior walls, and they will be based on standard sizes, more or less. As far as the shell, nothing gives you more square feet than a square. Perimeter; 35 + 35 + 35 + 35 = 140 ft ; 35 X 35 = 1,225 sq feet
Same perimeter 30 + 30 + 40 + 40 = 140 ft; but 30 X 40 = 1,200 sq feet
but the biggest reason is that I only need one pile of logs; about 60 logs at 40 feet; instead of 30 logs at 35 feet and 30 logs at 45 feet. So I have more options on the next log each time.
And the inside dimensions will be somewhat up-in-the-air depending on the diameter of the logs. I can plan on 16 inch, but if I get 22 inch logs delivered, then my overall internal dimensions just shrank by 6 inches. I know that would drive a lot of stick builders nuts, but I'm actually looking forward to it.
So you did decide to use even dimensions (32' x 32' per your post no. 170) in spite of your above justification!
When I read that post of yours talking about how a 35' x 35' was what you were planning, I just sat here scratching my head and trying to figure out your reasoning. And then you rebutted my suggestion to go dimensional, i.e. even dimensions (my post no. 118) per the above and I was wondering what you knew that everyone else didn't. Well, a 32' x 32' two-story should work out nicely.
/ AZ ranch
I down-sized from the 35 X 35 because it is way more expensive to get logs that long. I was gong to go with the plans I had for 30 X 30 but decided to "stretch" it for two reasons. First was so that I would have at least a 30 X 30 inside because my logs are in fact 20-21 inches in diameter. The second reason is so that the roof comes out even without wasting materials. A 32 X 32 home has a roof with 48 X 24 on each half. Easily divisible by 3, 4, 6, or 8. The interior walls are still up in the air, depending on how big my Ridge Pole Support Logs are as well as my girder logs. So I'm taking dimensional lumber into account for the roof, but that's all. I won't know the length of the interior walls until I build them.
/ AZ ranch
Thursday I picked up my plans from the county and am I bummed. :mad:
There's not a square inch on the 6 or 7 pages that is not marked up with their red ink. I thought I had more than enough detail, but they want WAY more. Half the stuff they are asking for is none of their business in my mind, but what choice do you have? These were put together and stamped by an engineer, but they still want to see more, more, MORE.
Is this somewhat typical or did I just get someone bored and set on ruining my day?
Insulation value of my stem wall? Come on. I was going to make my own front door, but I need to list the manufacturer, the R value of the door, the R value of the door seal. :confused2:
/ AZ ranch #185
Bo,
That is so messed up. R value of the door seal?
hugs, Brandi
/ AZ ranch #186
Bo, it's sad, but it is reality. On my thread we just went through a page or so of Code discussion.....more of a rant on my part;) Anyway, a big part of my moving here was because we had NO CODES. We now have a "building code", but it is very innocuous for now, but I fear it is the beginning of the end.
Sorry, this does not help you, but it should not be anyone's business what structure I choose to build and live in....period. I am truly sorry that our rights are so trampled these days and we have to tippy toe around county inspectors for fear of pissing them off, which in turn they can make our life more miserable.
/ AZ ranch #188
Well I will be the first to blame this state, for a LOT of things, but building codes have been around for a LONG time, and California wasn't the first.
Here's a little quote to inform those who wonder about the truth.
"The first building codes in the United States where established in 1625 by addressing fire safety and specified materials for roof coverings. In 1630, Boston outlawed chimneys made of wood and thatch roof coverings."
Here's another excerpt from the same article,
"History tells us that both George Washington and Thomas Jefferson encouraged the development of building regulations in order to help provide minimum standards that would ensure health and safety for building occupants. If there is one consistent building regulation throughout our country’s history of building regulations it’s the one dealing with our fear of fire. With respect to the early requirements for exterior and party walls of brick and stone it’s also interesting to note that early changes incorporated wood-frame structures be not more than 12 feet high and not over 328 square feet in area. However, as our population grew this code was soon abandoned and much larger wooden structures where build and the loss of human life and property by fire grew with it."
I am sure the cities and states across the country have played leap frog with them ever since. California probably has some of the tightest codes going, but houses here built later stand up to earthquakes FAR better than older homes.
I just finished a new house here in 2010, and there are a LOT of hoops to jump through, including there being only 5 approved wood burning fireplaces for the county I live in. As real PITA but let me tell ya. I spent the last two days making trips to beach (30 min drive) and coming home, to sit in sunny 70-80 deg weather.
There are many things about this state I do not like, many things I do like, and like I said, I will be the first to hold them to the fire for a lot of things, but this isn't one of them.
Building codes were in effect in this country long before CA was a state.
While I feel for the OP (I did the plans for my own 24 x 30 workshop) and I understand his frustrations, the codes are not always to tell us how we will live in OUR homes, but to protect someone that may buy the home after we leave it.
Some on this board may not, but trust me, there are a lot of people that when the state allows them to build a home in a certain place, and to a certain standard, then disaster strikes (ie New Orleans) they want to blame the state or feds for it. For them it's called CYA. I cannot blame them a lot for that.
/ AZ ranch
Handrifle, I agree with the basis of your argument. They do want to cover their XXX and there is merit in the next owner having some assurance that the place won't fall down, but there is also a lot of overkill, minute detail on little things that don't really mean anything, except someone's power trip. :thumbsup:
And though codes were started before CA existed, CA has taken them to extreme. I know, I lived there 20 years and did a room addition to my house. They made me put a concrete footer in that would hold a skyscraper!
/ AZ ranch #190
.........OFF TOPIC>>>>>
I talked to a friend of mine who is a builder in rural Mitchell County NC a week or so ago. He used to build a lot of really upscale houses a lot of which were for summer residents. He said there were two (2) building permits issued in the county during the past twelve months. I have been wondering what the inspectors have been doing with their time?
A lot of the inspectors I ever dealt with were former tradesmen that couldn't make it in the real world. Many had no idea what they were talking about and were basically on a power trip as stated above.
Any county inspection department that red lines a set of plans on a residence which has been stamped by a professional engineer is way out of control. Most of them have no one in any professional capacity on staff and are not qualified to do so. It would be interesting to see what the state board of registration for PE's had to say about that.
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
2015 WESTERN STAR 4900EX (INOPERABLE) (A60736)
2015 WESTERN STAR...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
(250) Iranch Safety Traffic Cones (A60463)
(250) Iranch...
