Ever feel like an idiot?
/ Ever feel like an idiot? #1
wmonroe
Elite Member
Southwestern, PA
1958 Ford 961 Powermaster
I am putting a new electrical entrance in a barn I had built last summer and had the inspection on it this afternoon. This is not the first time I've done electrical work or the first entrance I've put in so I wasn't really worried about it, first mistake. I have the conduit coming into the bottom left side of the meter box and also have conduit exiting through the left side but on the side not the bottom. The inspector tells me that this will be unacceptable to the power company because they do not like the line & load wires to cross inside the meter box. Now I'm stuck because there are holes in the metal siding where the conduit goes onto the panel inside and where the meter box is screwed in. I'm going to call the power company tomorrow and see if I can talk them into allowing it as is, but the way this company is I'm not holding my breath. The worst part is the inspector told me there is absolutely nothing wrong with it the way it is but they just don't like it that way. Just a little frustrated right now and venting.
/ Ever feel like an idiot? #2
Good luck - the companies can be fairly stick now a days
/ Ever feel like an idiot? #3
Just put the panel back in the box, tape it shut and return it to Home Depot. Just tell them you never opened it. That's what some jack ***** did in my local Home Depot. Luckily I like to open boxes and inspect things before I buy them. I would have been severely pi$$ed if I had gotten all the way home and opened the box to find that. (my local Home Depot is about 30-45min away)
By the way, that was sarcasm. Please don't do it..
/ Ever feel like an idiot? #4
i do not see why the line and load wires must cross inside the box, although I have never wired a meter box. Can't the line leads enter the box, turn right, go up, turn left, then down to the meter receptacle? Then the load wires exit down, turn left (but still above the incoming line leads), and exit out the left side?
Sent from my iPad using TractorByNet
This is a quick sketch I made up of how the wires come into the meter box. It looks like a crayon drawing but the best i could do quickly on my iPad.
The picture needs rotated 90* counter clockwise to make sense.
The blue is the box, green would be conduit, red is the wiring, and yellow is the meter lugs where the wire connects.
/ Ever feel like an idiot? #7
In my opinion, so don't take this to the bank, it is just an opinion.. but I think it is a bad idea to cross the wires.. a lightning strike could easily perforate the insulation of the crossed wires, and cause a connection between the wires. You could then pull the meter thinking you had de-energized the service to the house and it would not be the case. I would re-do it. I wonder if some of the actual electricians like Grsthegreat or Mace Canute would care to weigh in with their opinions.
James K0UA
/ Ever feel like an idiot? #8
Did you alter the divider that separates the utility wires from the load wires ???
/ Ever feel like an idiot? #9
inspection? what in the world does that mean:D
/ Ever feel like an idiot? #10
Take it apart an fix it..It will short out, not may, but it will.Its just a learning thing.Patch the holes an get on with it:)
/ Ever feel like an idiot? #11
Definitely check with power company and have them look it over. You aren't the first person for sure who ever had a situation where something was less than ideal for wiring up the meter. I agree service wires preferably are not crossed but if that is the only option that is available it can be done. Like others said a UL listed divider can be put between the service wires. Did you already wire up the load end of the meter? If there are just tails in it now and the utility company can route them as they wish there shouldn't be too much of an issue I wouldn't think.
/ Ever feel like an idiot? #12
They make a hole plug with gaskets for electrical boxes. Just put one in the unneeded hole and relocate it.
/ Ever feel like an idiot? #13
This in just in regards to the title of the thread :
For Me , Everyday , Usually the first thought that enters my head when I wake up in the morning :thumbsup:
Like Gary wrote , They make plugs , don't know if you have enough wire for reroute though ? I would think that if the inspector puts their sticker on it , that the power company would be good since basically the inspector has " Approved " it , But know what your saying .
Fred H.
/ Ever feel like an idiot? #14
Line in the top, load out the bottom and sides. that's the way its usually done.
/ Ever feel like an idiot? #15
:laughing: When it comes to building practices, NEVER say "the way it is usually done" unless you add "around here" to the end of that.... Practices differ so much around the country, there are very few real "standards" it seems. Around here, almost all new construction is service underground, so the line in is most often the bottom, and the line out depends on where it is going... On my house, straight out the back to the panel. A friends house, it comes out the bottom. Both very common here.
Ok the engineer at the power company had me send him some pictures so he will look at them Monday morning and let me know. The issue with moving anything is that the metal siding will then have holes in it. It is frustrating when the inspector says that it's fine and that the power company about 30 miles east (who I don't have an option of using) would be perfectly fine with it. To quote the inspector "your power company is very difficult to work with". Oh well.
Here is a picture of what I have.
/ Ever feel like an idiot? #17
Can you move the conduit coming up to the left a foot or so? Or, put a couple 45's in to have it come up over there? I was thinking you might be able to unscrew the box and remount it to the left a bit - if the conduit could come up over there. Wires could straight up to their terminals. Then exit the box on the lower right of the box to the building, instead of out the lower left.
You'd still have the small screw holes from the old mounting location, but they'd be pretty small to caulk. And you'd be re-using the large hole through the wall.
/ Ever feel like an idiot? #18
I feel your pain. I made boneheaded mistakes like that a couple times. I just ended up making more work for myself.
In your case - instead of moving the box, creating new holes in building or flipping the box upside down, can't you take box off the building and put it on the bench. Flip the components right and left inside so the wires will not be crossed. I am not sure how much work you will have to do to flip the cover though due to the meter hole is on right and the hinges orientation on it. You might have to have a new cover made by a local metal shop.
/ Ever feel like an idiot? #19
From looking at your pics, you also need anti-short bushings on both conduits... Yes, even with plastic conduit (at least around here...). They are worried about chafing/cutting the insulation, I guess.
They don't require that here. This is the fourth entrance like this I've installed in the last 5 - 6 years and they've never mentioned them. It is interesting how the requirements change not only from state to state but also just different counties.
