Hay wagons; let's see them!
/ Hay wagons; let's see them! #81
Last time i used it, i had to brake on the tractor alone, and those dry drum brakes squeeled like an Arab warrior.... ;) The tractor wheels didnt skid due to the 2 ton drawbar load, but when i have another wagon hooked behind it, i get over 15 ton CGVW so i do need trailer brakes... When tractor and my own trailer have brakes, the borrowed trailer behind it, will never be able to overtake me when i get into an emergency situation..
"those dry drum brakes squeeled like an Arab warrior.... ;)"
Now THAT'S funny!!!!!
Bolting longitudinal beams to the front and rear supports will stiffen the gear and prohibit the axles from articulating over rough terrain. Does anyone have an answer?
You can try the chains like others have mentioned, but believe me the hay wagons flex....a LOT!
/ Hay wagons; let's see them! #83
No it's a good question. In NH they are street legal. When pulled behind a tractor, they are just consider an implement of husbandry(farming equipment) State only requires they display the triangular slow moving vehicle emblem. I don't know how fast they can go. I have only pulled them down the road behind my tractor, not much more than 20mph.
Yes in NH they are considered farm equipment, but only if you use a pin hitch. If the wagon has a ball hitch than its a trailer and needs to display lights. As for road speed. I tow my racks behind my pickup to go between fields, some running gear are straight down the road at 40 and some shimmy at 20. That's unloaded, loaded speed is usually 15-30.
/ Hay wagons; let's see them! #84
Decided to get the wagon out today and snap a few shots.
/ Hay wagons; let's see them! #86
/ Hay wagons; let's see them! #87
chain the front axle so it will not rotate, then slide the front tires where you need to go, unless your tractors "green" and dont have enough power!:laughing:
/ Hay wagons; let's see them! #88
hello I wanted to ask were did u get that brake mechanism for your hay wagon. I am very interested installing one on my wagon.
thank you
/ Hay wagons; let's see them! #89
Update: the Miedema tandem didnt show durable enough, 2 weeks ago i hauled 15 ton of haylage home with my wagon, and a borrowed wagon behind it. After driving 20km the left front wheel came off when i just turned onto our driveway:
This muck spreader i used the walking beam tandem of, made their own hubs with bad castings. The wheel hub splattered in four pieces, although the bearing it should retain, wasnt deformed nor hot, and was properly greased.
Nother update: last summer i welded an 8 ton tandem under it from a scrapped Deutz-Fahr sefloading hay wagon, and cut wheel wells in the siderail to accomodate the bigger 13-16 tires.. It pulls much lighter now, both on- and offroad :)
/ Hay wagons; let's see them! #90
Here's my old wagon. It would hold 200 bales of hay and the Bota pulled it easily. . . John
/ Hay wagons; let's see them! #92
Is your hay wagon for sale, it just what Iam looking for if so please call me 860-377-2896 thank you
/ Hay wagons; let's see them! #93
Here are a couple shots of a wagon a neighbor just gave to me. Took all of about 5-10 minutes to pull the rotten deck apart. Anyone have any idea what kind of load this thing is rated for? 6 lug wheels. I'll be cleaning it up, giving it a paint job and replacing the deck. Will see good use around here for hauling hay, firewood, logs, lumber, and hay rides too of course. IMAG0590.jpgIMAG0595.jpgIMAG0596.jpg
/ Hay wagons; let's see them! #94
My best friend in Ct. jave me this several years ago, I shortened it , It s great.
Army Grunt
/ Hay wagons; let's see them! #95
I know this is a old thread but Ive been playing around with a old hay wagon I bought. I got it for $107, after I got it home I noticed it had a hoist under it. I rebuilt the ram on it and tried it out today. I hope to paint it up in the summer and build a new deck.
/ Hay wagons; let's see them! #96
Do you have an orchard or vineyard? I see you have a narrow John Deere 5000N series. I love those tractors but the hydraulic lever placement wasn't great.
/ Hay wagons; let's see them! #97
This is my dads tractor, its used in grapes. Its a 5500N, the 5520s had a lot better setup with the controls. They are setup just like big tractors.
He also has a farmall 140, I have IH 484 and a JD2010 diesel with a kelley loader.
/ Hay wagons; let's see them! #98
Where are you located? What type of grapes did your dad grow? I'm mainly concord with some Niagara and some Catawba.
/ Hay wagons; let's see them! #99
Im in southern michigan, my dad has concord grapes that go to welches. He used to have niagaras but he was leasing them and the lady who has them decided to let some big factory farm tear them out and lease the land for grain.
/ Hay wagons; let's see them! #100
This is the only pic of my one wagon that i have. I bought this for $195 at a consignment auction this past spring. I put a fresh coat of paint on it. I wasn't sure of the brand running gear but i painted it new holland red and yellow. That's my wife and our 2 dogs stacking the hay on the wagon.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2022 EZ-GO ELITE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATERPILLAR...
