Ballast Question on ballast box
/ Question on ballast box #41
Got it. Thanks JB. What about drilling a hole on the side of the BB just above the cement for drainage. Would you recommend it?
You could do that, but if you have it set up to drain out the bottom of the box/pipes, just drill a hole in the side of one of the pipes. That's what I did.
JB.
/ Question on ballast box #42
My .02 Henri
If you were going to drill anywhere,I would think on the front (pin side),so when the box is up in the tilted position,the water would run out.
If you have holes in the bottom under all your pipes,I think that is enough. What accumulates in the top could be sopped up with rags at the end of the day:)
Greg
Thanks everyone. I think I have all the info I needed.:thumbsup: Wanted to make sure because once you poor concrete in, there's no coming back. If anyone has anymore suggestion, please, feel free to comment. I am only planning this project in a couple of month.:) Henri
/ Question on ballast box #44
This is just the thread I was looking for. I just bought a JD 2305 with the 200CX loader. The dealer includes the BB automatically when you buy the loader and that's fine with me because I don't currently have or need any other 3pt implement that could serve as counterweight on the back.
So I'm getting ready to fill the BB with concrete. I'm wondering if anyone has mounted casters on the bottom of their BB. It seems to me that it would be handy to be able to roll the BB around the shop when its off the tractor. But I'm concerned about what would happen if one of the casters failed at some point down the road. I could see that turning into a real PITA.
So now I'm wondering if it wouldn't be better to leave the casters off and just build a little dolly cart instead. And possibly sink a heavy anchor hook into the top of the concrete so I could lift it on and off the cart with the shop hoist if I needed to.
So what do the experts think? Casters? Or a cart and top anchor hook? I'm also going to sink some 2" PVC tubes for tool handles. Anything else I should consider before I start mixing concrete?
/ Question on ballast box #45
Welcome to TBN:D
Build the dolly, Mounting casters is a bad idea, they will get damaged easily while using the BB or tear up your ground.
I welded a D-ring on the front that can be used for lifting with along with a pin in the hole for the top link.
Two or three 3" pipes are a good idea so you can store some chains or a shovel...
/ Question on ballast box #46
A cart, if I was to do anything.
Often, I use the ballast box to trim off some dirt mounds (like a blade). Casters would just be in the way.
Also, other times, the ballast box drags when through a ditch or at the bottom of a steep grade. Casters would be in the way there as well.
With the iMatch, the ballast box picks up and drops easily and quickly, so moving it about without casters has never been a problem for me. Setting it on a dolly would also be just as easy to do, so no hook needed in the top.
I have stone in mine (thought I might like to remove it for some reason) and leave about 4" from the top to carry chain and odds n end tools. If I get a chance, will pour concrete in the box up to about 4" from the top. And will likely put the plastic tubes in the four corners for flexibility.
(and like kennyd said :D )
/ Question on ballast box #47
Thought I was the only one to use the BB for a grader blade, works very well with packed snow on a blacktop driveway, also.
Stone for BB fill is the only way to go and like you I fill in the summer to about 4 - 5 inches from the top, chains, and one of those small 2 ft shovels. I take about half the stone out for winter and plowing snow.
/ Question on ballast box #48
I use a dolly for mine.
/ Question on ballast box #49
I use a dolly, and filled mine with sand. The sand comes in handy in winter if I need a traction aid. I keep an Army folding shovel shoved in the sand.
Welcome to TBN Joe Gremlin.
/ Question on ballast box #50
/ Question on ballast box #51
I have that same dolly. One caution though. I remember a thread about casters breaking because the ballast box does not always set down exactly even. All the force for a moment combined with the downward momentum as it sets on one caster can break it.
/ Question on ballast box #52
Hello Joe and welcome to TBN:)
If you have to buy the casters,pricewise it might be better to just get a completed furniture dolly from Northern Tool,capable of around 900 lbs for roughly 35.00 dollars. That's what I ended up doing. Just my .02:)
Northern Industrial Carpeted Hardwood Dolly 900Lb. Capacity | Dollies + Accessories | Northern Tool + Equipment
Greg
Yep, all that makes sense so I'm going with a dolly instead. Now I just have to wrestle with the sand vs concrete choice. :confused2:
/ Question on ballast box #53
Of course sand or stone allow you to vary the weight. I have never found that very useful and if you use concrete you can forget about it once dried. I left two holes at the bottom for drainage, which helped hold the plastic tubes when pouring the concrete.
/ Question on ballast box #54
I think the ideal solution is stone of some small size, like 3/4". You can change the amount in there if you need to to carry chains, cones, etc, still change the configuration of tool tubes, and use drill holes for water drainage without worrying about losing fill material.
Sand is scary to me because if you get moisture in there, it can't get out since you can't really drill drain holes unless you want to leave a trail wherever you go. I suppose you could add a few layers of nylon or stainless screen beneath the sand, but it still just doesn't sound like the way I'd choose to go.
Cement is too permanent for my taste although I do recall reading about someone who used cement blocks stacked neatly and that would be ok with me.
As for wheels, I use a furniture dolly I got at a home improvement store which works perfectly for me especially since I rarely use the ballast box anyway. I can just wheel it into a corner and pile junk on it until the next time.
/ Question on ballast box #55
Another thought is lead wheel weights if the tire shops still throw them away, which I doubt due to EPA regulations.
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
New/Unused 6ft Quick Attach Brush Cutter (A61166)
New/Unused 6ft...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
KUBOTA HYD CYLINDER ARM (A62130)
KUBOTA HYD...
2006 Honda Ridgeline AWD Crew Cab Pickup Truck (A61568)
2006 Honda...
