Underground electrical service for cabin
/ Underground electrical service for cabin #21
My electrical service from the street line is about 500'. Power company has to install a transformer to get adequate service to my home,200amp. The entire operation was performed by the power company. Cost me about $3500.
/ Underground electrical service for cabin #22
A lot of utility company's will want to pull the service in conduit that you have installed and will supply the wire, but as has been said already it just depends on what there policys are it seems to vary regionally, and I don't know of any power company's that install copper services for residential customers only commercial and then it is there service not supplied by the power company. P.S. I would'nt have it any other way than in conduit.:D
/ Underground electrical service for cabin #23
I had to install the 3" pipe 100 ft from the pole to the house and buy the wire. but now they own it, if something goes bad they replace it and not supposed to cost me any more.
This was 4/0 al, on the day they pulled mine all the linemen were admiring the new wire they were using, they said this was the first job they used it on and that the insulation was much thicker than normal. Hope so, look how they left the top of the pipe, no weather head!
Called them and they said don't worry all conduit is full of water?
JB.
/ Underground electrical service for cabin #24
New conduit is not full of water, but all old conduit is full of water.
/ Underground electrical service for cabin #25
Call the utility...In these parts Duquesne Light wants only aluminum wire to mesh with theirs (at least when I built my house)...That's an expensive mistake you don't want to make.
Mine is direct bury in PVC...Wanted to protect it from the citters...My mom's neighbor, who had more money than God, built a raised garden in the shape of South Carolina, his home state,. His power ran under that thing...A most unfortunate groundhog ate through one of the legs....Result: whole yard torn apart..Including South Carolina:D
/ Underground electrical service for cabin #26
JB.
Most power company's put a filler in the pipe not a weatherhead on a secondary riser like you have on your pole, the ones we use is 3 part first you stuff foam down into the pipe around the wires this keeps the 2 part liquid that you mix together from running to far down into the pipe and in a few minutes it is hard, it keeps the squirrels from getting down into the pipe and helps keep the water out, we use these on everything from a 1-1/2 streetlight riser to a 6" 1000 mcm primary riser and they seem to work well.
/ Underground electrical service for cabin #27
I've never see that is it like Chico used in seal fittings for class 1/2/3 explosion proof fittings?
or more like duxseal?
tom
/ Underground electrical service for cabin #28
That's a pretty long run, and your losses will not be trivial. I strongly recommend that your drop a dime on a licensed electrician to do the numbers for you.
BE SURE TO BURY IT DEEP! The morons that did our house....
/ Underground electrical service for cabin #29
or more like duxseal? I don't know anything about Chico, but this stuff will get warm when you mix the 2 parts together and will start swelling up and will be fairly hard in a few minutes, have also used a similar product to fill woodpecker holes in poles and it has held up well, I have used duct seal before in manholes but it does'nt seem to hold up as well when exposed to the elements ie up poles but does seem to do a good job in the manholes.
tom
Tom I typed my response in your quote, I'm a better linehand than computer man.:D
/ Underground electrical service for cabin #30
So is the water anything to worry about? or is it more critters?
The odd thing is that other pipe with the weatherhead on it just goes down into the ground with direct burial underneath. Goes to my shop in the back.
This pole is right at the bottom of a hill so I know there could be a few feet of water in that pipe. I do drainage work, and if I thought about it I would of put a draining tee right at the lowest point. afraid to try and do anything like drill a hole in it know, don't want to damage the wire or get zapped
I've seen electrical manholes just totally flooded with water, with all the electric underground I guess it's not as bad as I think it is. My buddy has a manhole on his property in a low spot near a brook crossing, right next to a sub station, that thing pours water out the top for days after a rain, so I know it must be full all the time.
JB.
/ Underground electrical service for cabin #31
With all those bare peanut connectors up there on that pole the critters would probably get shocked before they got a chance to get down your pipe.:rolleyes: As far as water in conduit very few runs of conduit are immune to water intrusion, gray electrical conduit is not made to the same standards as say white water pvc conduit meaning it is not guaranteed to be water tight, a certain amount of groundwater is going to seap in if the water table is over the conduit during periods of heavy rain, if it were mine though I would want it sealed to minumize the amount of water entering the conduit, after all that is the only place that you can control it, so many things are sold as waterproof but in my opinion after long periods of time they are really only water resistant under periods of constant submersion, we also have manholes that stay full of water and we do our best to waterproof our connections ie splices and terminations of cable, but after years of constant submersion they fail.:D
2014 DODGE RAM 2500 (A58214)
2014 DODGE RAM...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
MINI EXCAVATOR ATTACHMENT SET (A60430)
MINI EXCAVATOR...
