wire in plastic conduit
/ wire in plastic conduit #1
geneP
Platinum Member
Central Mississippi, USA
Case-International 385, Kubota L5450 w/LA1150A loader
I went to the box store and bought wire and conduit to bury a lighting circuit to the new garden shed. I thought I was buying copper 10/2 w/ground underground wire, but when I got ready to install it I found it is not UG wire. I'm putting it in the water-tite UV resistant schedule 40 pipe. Can I use this wire? I'm assuming it will stay dry in the conduit.
/ wire in plastic conduit #2
Unless the conduit can be sealed airtight it will fill with water due to the water in the air condensing in the colder underground conduit.
James K0UA
/ wire in plastic conduit #4
Underground (direct bury) or exposed (outside) wire is called UF. I think you'll be ok with what you have in conduit. I have heard that in underground conduit it is best to use the loose wire without the jacket (thhn). But that's what circuit breakers are for!
Alright, it is marked UF-B. I'm accustomed to the underground wire that is mean to skin. This wire has a vinyl/plastic jacket that encases the neutral and two insulated wires like the tuff stuff, but skins easily. Google says it's ok for direct burial, so I guess I'm OK without another trip to the store?
/ wire in plastic conduit #6
UF-B stands for underground feeder with 90 deg insulation. You should be OK.
(2) Tool Boxes (A62613)
(2) Tool Boxes...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
2001 International 4000 DT 466E (A60462)
2001 International...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
iDrive TDS-2010H...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
