winterizing
/ winterizing #1
fosterlot
maine
kubota
In order to store a tractor during the winter in an unheated pole building, what are the things I should know?
/ winterizing #2
I'd get the tires off the dirt if you are storing it - plastic, wood, etc to keep them from drying out over time. You want ventilation - stops the buildup of moisture from condensation which leads to rust. Be liberal with oil. Don't cover it. Some tractors want you to block the clutch. I always using mine- so I really don't know more than that. In the manual if you have it.
/ winterizing #4
if it's a gear / clutch tractor...you should use a block of wood etc. to hold the clutch peddle in the depressed position...to prevent it from sticking to the plate...My tractor came with said block of wood from K_ubota for this purpose...
/ winterizing
How about liquid cooled tractors. Should I drain fluids when I know weather will be really cold (-25 F)?
/ winterizing
Thanks for the helpful info. I am a new convert to the joy of tractors!
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
2017 Nissan Pathfinder SUV (A61574)
2017 Nissan...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2015 Bobcat E42 (A64126)
2015 Bobcat E42...
