winterizing
/ winterizing #1
fosterlot
maine
kubota
In order to store a tractor during the winter in an unheated pole building, what are the things I should know?
/ winterizing #2
I'd get the tires off the dirt if you are storing it - plastic, wood, etc to keep them from drying out over time. You want ventilation - stops the buildup of moisture from condensation which leads to rust. Be liberal with oil. Don't cover it. Some tractors want you to block the clutch. I always using mine- so I really don't know more than that. In the manual if you have it.
/ winterizing #4
if it's a gear / clutch tractor...you should use a block of wood etc. to hold the clutch peddle in the depressed position...to prevent it from sticking to the plate...My tractor came with said block of wood from K_ubota for this purpose...
/ winterizing
How about liquid cooled tractors. Should I drain fluids when I know weather will be really cold (-25 F)?
/ winterizing
Thanks for the helpful info. I am a new convert to the joy of tractors!
VAN'S 300 GALLON SPRAYER (A64276)
VAN'S 300 GALLON...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
2001 FORD F-150 LARIAT TRUCK (A64276)
2001 FORD F-150...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
