winterizing
/ winterizing #1
fosterlot
maine
kubota
In order to store a tractor during the winter in an unheated pole building, what are the things I should know?
/ winterizing #2
I'd get the tires off the dirt if you are storing it - plastic, wood, etc to keep them from drying out over time. You want ventilation - stops the buildup of moisture from condensation which leads to rust. Be liberal with oil. Don't cover it. Some tractors want you to block the clutch. I always using mine- so I really don't know more than that. In the manual if you have it.
/ winterizing #4
if it's a gear / clutch tractor...you should use a block of wood etc. to hold the clutch peddle in the depressed position...to prevent it from sticking to the plate...My tractor came with said block of wood from K_ubota for this purpose...
/ winterizing
How about liquid cooled tractors. Should I drain fluids when I know weather will be really cold (-25 F)?
/ winterizing
Thanks for the helpful info. I am a new convert to the joy of tractors!
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
2022 Deere 317G (A64126)
2022 Deere 317G...
