What is this and how can I use it?
   / What is this and how can I use it? #11
Just make a bracket for the fender and mount the valves there.
   / What is this and how can I use it? #12
Your 3pt probably would not work if that QD was separated. The complete assembly could be pressurized if the 3pt lever was engaged.
Should you install a valve, the pressure side of the QD would go in the valve IN port and the other would go to the valve's PB port. A third hose from the OUT port would go to tank.
Check this valve out if you want a two lever small valve.
Surplus Center - 2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE
If you need float, there is another valve available.
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
