Well House Load Center??
   / Well House Load Center?? #21
I'd agree with you on the NEC and grounding, but that's probably a sit around the stove and chat all winter item.
I'm not an NEC expert, but always happy to learn. Is that rule for sub panels in the same building? I.e. a well pump panel would be a different building, and therefore need a ground? (What is the section, or sections, that apply for that?)
All the best,
Peter
The old code was that each outbuilding sub panel was considered a separate electrical service. My wood shed is wired with a separate ground. The well pump was once wired with a separate ground, but the old underground feeder died and I'm running a new service from the shop.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
ExMark Vantage 48in Stand-On Commercial Mower (A59228)
ExMark Vantage...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
