welding carts
/ welding carts #61
I got to see an Oxygen bottle launch thru a vehicle, and fly down the road, ca.1992. I was working register (high-school job) at a gas station at a busy intersection of two multi-lane roads, where we had frequent accidents. After awhile, you develop an ear for the sound of a skid that's leading to a collision, versus the dozens of others you'd hear each day of someone just stopping short.
Anyway, one day I hear one of "those" skids, clearly someone trying to stop... hard. I look out the window just in time to see a work van rear-end a car that stopped in front of him. Then I see a 60" tall bottle take off out the back of the van, and go flying up the street behind him, as the oncoming cars swerve off the road to avoid the thing.
Story I got was that the guy was too lazy to install his safety cap, and just had his whole oxy-acetylene torch rig laying down in the back of the van, regulators pointing forward. When he rear-ended the car in front of him, the whole cart slid forward, and the oxy bottle regulator snapped off when it hit the mounting bracket under the driver's seat. The whole bottle took off out thru the back door of the van, and although I couldn't leave the register to go inspect for myself, someone had said it left a pretty near-perfect Ø10 inch hole in one of the back doors.
That said, I still transport all of my bottles laying down flat. I put the bottom of the bottle against the front wall of the pickup bed, lay the bottle down, and run a pair of straps as an "x" across them to the lower pad eyes in the bed. If a bottle seems like it wants to slip, such a small diameter bottle that doesn't provide enough vertical drop on the strap, I just run a single loop around it with each strap. But I also ALWAYS remove the regulator and install the safety cap when a bottle isn't strapped into the cart.
/ welding carts
You guys are free to start a bottle safety thread. I got a good start on my deluxe welder cart yesterday and will post pics when available.
/ welding carts
I got some cable hooks added today. These will be added to both corners so this is the end the welder will stick out from. The far end will get the tank..
/ welding carts #65
I am real pleased with the HF ones with the bottle racks. Have both. Use one for O/A torch and tools/etc. Have my arc welder on the otherbwith rod and etac in the bottom compartment. I am contemplating putting a piece of 3/8 or 1/2 " plate on top of the big one for a welding bench. Will then drill and tap for hold downs and vises.
Ron
/ welding carts #66
To be more relevant to the thread at hand...
Here's my welder cart, it was a $50 auction find, couldn't beat it with a stick so I got it and will modify it to my needs... Obviously the welder is on the top shelf area, the bottom area will get filled in for consumable storage and hopefully I'll make enough room beside the welder for my plasma cutter... I have two cable hooks on the opposite side at the moment but will add something to the back for my 50' 50A extension cord that I will mount the female socket to the cart and possibly make a panel on it so I can connect both the plasma and welder to and pull some 110V for grinders and such... one person can't weld grind and cut at the same time so the circuit will be fine... I just got the pictured bottles and they're too tall so I have to lift the top 1' which I will hinge, and put some sheet metal on the back side of the work surface for safety. I have all the materials for the modification, just need to finish a transmission rebuild before I do fabrication... The miller welder is going to the Garage, my other stick welder already has wheels...
/ welding carts
Ron
My work space is to small for anything like that. :( Hence my small welder cart...
/ welding carts
Got some larger wheels added and a tank mount bracket. I got this Stainless steel bracket off of amzone for about $20 and its pretty nice. The rear tires are pneumatic ones I had laying around here which aren't all that big, but I can replace them with larger ones if I can't appicate there rought terrian ability. The .75 black plastic tank base holder is not yet bolted on.
/ welding carts #71
I’ll be proud of that! A welding cart and table are much like an artist plate and easel. Form follows function. Expect great and interesting projects now ;)
/ welding carts
Thanks! Just hope the wheels are big enought. No biggy to make the rears larger.
/ welding carts #73
Since you didn't take my advice and bought that cart anyway I don't see how I can say anything but...Nice job! It looks like it is gonna work well. I think the big pneumatic tires are a plus. But don't take my advice. Please make sure to post pictures with the welder and cylinder in place.
Eric
/ welding carts #75
Clever way of adapting cart to include a tank. You can always fabricate something in metal later in place of the wood.
/ welding carts
My everlast 212 welder is predicted to arrive on Tuesday. Of course I have nothing to plug it in to. :oops:
/ welding carts #78
Hey, ya got 4 days, get with the program - BTW, how far is your clothes dryer from your shop area?
JK about gettin' with the program, but NOT about that adapter - pretty sure the 212 comes with a 6-50 plug - would probably also need a 6-50 extension cord. I made mine, it's 6 ga. SO cord, 85 feet long, it'll run my mm252 welding anything less than 1/2" thick.
Something similar should at least let you play til something more permanent can get done - C'mon, you KNOW you wanna play :D ... Steve
(OK, maybe I'm transferring just a tiny bit)
/ welding carts #79
Looks like that model comes with drive rolls for .030 and .035 wire so unless you're into body work you're good - They did, however, the same as Miller did to me on the mm211; only a 10' mig gun - Everlast wants $159 for a 15' gun
I couldn't even talk Cyberweld into credit/upgrade for a 15' INSTEAD, ended up just buying a 15 (I can't stand short cables) - only good news is I have a 10' "emergency" gun that'll fit either the 211 or 252 - the ACTUAL will probably be my kids finding a brand new 10' mig gun after they "pat me in the face with a shovel" :rolleyes:
/ welding carts #80
That 3/4 plywood is pretty tough and the axle is near center under the tank.
Hmm, that tough plywood should make some good kindling being near a welding operation.
Sure hope a tough plywood welding table is out of consideration, ha.
Nice looking cart.
Good luck, KC
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
3269 (A63117)
3269 (A63117)
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
