Welding brackets on tractor frame
/ Welding brackets on tractor frame #61
Typically, holes drilled into the center 1/3 of a 'beam' will minimize loss of strength if all forces on it are linear. They are not in a frame or ROPS. I wouldn't drill or weld on either.
Brackets may be attached under existing bolts, say that hold on a loader tower etc. Two-pc brackets can be designed that wrap/clamp around something, frame or ROPS, loader arms, etc.
Well said.
Ever have a close look at aircraft wing spars? They are full of holes like you point out, never near the edges or in web and always centered.
A good clean de burred hole in a web center is perfectly safe.
On vehicle frames you'll find tons of holes generally for options.
Frame welding is a big no no but bolting is accepted, in fact some truck frames are extended by bolting methods.
Ford Tailgate Themed Wall Decoration (A61569)
Ford Tailgate...
2012 Peerless CH-43-2A T/A High Rate Magnetic Frac Blender Trailer (A60352)
2012 Peerless...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
Vertical Steel Well Tank (A61570)
Vertical Steel...
New/Unused AGT SDA-140W Wheel Loader (A61166)
New/Unused AGT...
