Welding brackets on tractor frame
/ Welding brackets on tractor frame #1
Buggs67
Perry Cty, Pennsylvania
Kioti 2014 CK2510 TLB
I'm new to welding and just got an arc welder. I want to weld some brackets on the tractors frame and I don't want to damage any electronics. Do I need to disconnect the battery? Both terminals or just NEG?
/ Welding brackets on tractor frame #2
Tag for interest as I'm also too chicken to weld on the tractor itself.
/ Welding brackets on tractor frame #4
/ Welding brackets on tractor frame #5
Put your ground clamp close to the point you are welding on.
Current will flow between the arc point and the ground clamp.
You should be fine. No need to disconnect the battery.
In theory there will be a voltage drop between the arc and the ground clamp, and this voltage could drive currents to flow elsewhere, but unlikely, as such currents would see the path of minimum resistance, which is between the arc point and the ground clamp, and not flow elsewhere to any significant degree.
edit: Actually it is the voltage that drives the current flow, and saying the currents would see something is rather simplistic, but actually that is the apparent result at the end of the day...
/ Welding brackets on tractor frame #6
Depends on the age of the tractor. If the tractor has IC control modules, best to pull the battery ground to be safe. Same with welding on a car or truck.
/ Welding brackets on tractor frame #7
It's usually easier to pull the ground cable off, then to replace parts.
With the ground clamp close to the working area you usually will not have any problems,
but electronics are funny critters what never bothered for years can be destroyed today doing the same thing.
I have seen simple alternator diodes go out from welding and engine controllers survive, I prefer to disconnect the battery ground.
/ Welding brackets on tractor frame #8
Call your dealer service dept just to double check.
Before welding on our new Kubota I check with dealer service and they be very wise to disconnect battery more so if it has cab.
/ Welding brackets on tractor frame #9
Disconnect one side of the battery - I usually disconnect the ground (frame) side before welding on any part of the tractor.
That said, about the only things that I will weld to on any tractor are the loader and body work. Too much of the rest of the tractor is either cast iron or cast steel. You don't want to weld to either.
So a good rule is DO NOT weld to the frame if there is any way you can do the mounting by drilling, tapping, or bolting. You can weld anything you want to the fenders or the loader bucket - but not to the cutting edge.
luck,
rScotty
/ Welding brackets on tractor frame #10
Disconnect the battery ground does just that, disconnect the BATTERY ground. Often the components are also grounded to the frame and not back to the battery so it doesn't matter if you just disconnect the battery ground.
/ Welding brackets on tractor frame #11
I was chicken and disconnected the battery, just in case. That effort was going to be less than any issue that may be caused. Plus, it’s a tractor*. There isn’t even a click to have to reset.
*Assumption.
/ Welding brackets on tractor frame #13
Its quick to disconnect the battery so may as well. I use double grounds. 1 on each side of the weld area. Not sure I need to but never had an issue.
/ Welding brackets on tractor frame #15
I have welded on units with all that electronic crap----NOT a good thing to do but can be done---as already stated remove battery cables and ground very close to weld site.
As a side note---do not weld anything to frames themselves----always drill and bolt. Welding will weaken the frame and make things a pita on down the road for you or someone else to remove!
/ Welding brackets on tractor frame #16
Won't the hole(s) for the bolt(s) weaken the frame? That's a reason not to drill in a ROP post so I would think the same applies to the frame.
/ Welding brackets on tractor frame #17
Typically, holes drilled into the center 1/3 of a 'beam' will minimize loss of strength if all forces on it are linear. They are not in a frame or ROPS. I wouldn't drill or weld on either.
Brackets may be attached under existing bolts, say that hold on a loader tower etc. Two-pc brackets can be designed that wrap/clamp around something, frame or ROPS, loader arms, etc.
Thanks for all the feedback. I should have been more specific. I want to weld brackets onto the supports for the FEL that are bolted onto the frame of the tractor. I can drill and tap and bolt on the brackets and it appears that that is safer although will take a lot more time.
/ Welding brackets on tractor frame #19
Welding on your tractor should be a while down the road. Lots of hood time is needed before the real work begins.
/ Welding brackets on tractor frame #20
Not trying to be an a$$ but this is the first good reason not to weld to a frame of any kind:
Second reason is why weld to a frame unless you're repairing a break/crack. Once you start welding to a frame you're setting yourself up to cracking, whatever you're mounting, use bolts you'd be far better off, my two cents worth.......Mike
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2023 Unused Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
2023 Unused Monroe...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2017 John Deere 331G Compact Track Loader Skid Steer (A66734)
2017 John Deere...
