Welding brackets on tractor frame
/ Welding brackets on tractor frame #61
Typically, holes drilled into the center 1/3 of a 'beam' will minimize loss of strength if all forces on it are linear. They are not in a frame or ROPS. I wouldn't drill or weld on either.
Brackets may be attached under existing bolts, say that hold on a loader tower etc. Two-pc brackets can be designed that wrap/clamp around something, frame or ROPS, loader arms, etc.
Well said.
Ever have a close look at aircraft wing spars? They are full of holes like you point out, never near the edges or in web and always centered.
A good clean de burred hole in a web center is perfectly safe.
On vehicle frames you'll find tons of holes generally for options.
Frame welding is a big no no but bolting is accepted, in fact some truck frames are extended by bolting methods.
Generator (A64553)
Generator (A64553)
2013 Audi Q5 AWD SUV (A66738)
2013 Audi Q5 AWD...
METAL SAW HORSE (A68842)
METAL SAW HORSE...
2013 Jeep Wrangler 4X4 SUV (A66738)
2013 Jeep Wrangler...
2008 Hummer H3 4x4 SUV (A66738)
2008 Hummer H3 4x4...
Unused 2021 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2021 Ideal...
