Welding brackets on tractor frame
/ Welding brackets on tractor frame #61
Typically, holes drilled into the center 1/3 of a 'beam' will minimize loss of strength if all forces on it are linear. They are not in a frame or ROPS. I wouldn't drill or weld on either.
Brackets may be attached under existing bolts, say that hold on a loader tower etc. Two-pc brackets can be designed that wrap/clamp around something, frame or ROPS, loader arms, etc.
Well said.
Ever have a close look at aircraft wing spars? They are full of holes like you point out, never near the edges or in web and always centered.
A good clean de burred hole in a web center is perfectly safe.
On vehicle frames you'll find tons of holes generally for options.
Frame welding is a big no no but bolting is accepted, in fact some truck frames are extended by bolting methods.
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A61165)
2019 Ford F-550...
Margaritaville Mini Decorative Truck (A61569)
Margaritaville...
2009 International 7300 Slickline Truck (A60352)
2009 International...
Zero Turn Mower (A59231)
Zero Turn Mower...
John Deere Mini Decorative Truck (A61569)
John Deere Mini...
2020 Volvo L60H Articulated Wheel Loader (A61567)
2020 Volvo L60H...
