Bucket Hooks Weld hooks or bolt them ?
/ Weld hooks or bolt them ? #11
Agree. Watts = amps x volts so at 110v you have about 45 amps which is way more than a household 110v circuit. Any fluxcore 110V MIG would work. At 20amps of 220v from that generator you could run moderate voltage from a 220 welder too, plenty for 1/4 inch.
Weld on grab link hooks with a 110 mig? Not me. I'm not saying it can't be done, but I wouldn't do it. Those hooks are pretty thick, .75" probably. I don't trust my welding skills enough, I'd have the 220V stick machine cranked up for that job :)
JB.
/ Weld hooks or bolt them ? #13
JB.
I appreciate the scepticism regarding 110v welders but remember the bucket lip is probably 1/4 inch at most. Yes, those hooks are big (but not 3/4 inch I don't believe). Still, weldable with a 110v fluxcore machine with appropriate technique. Certainly ain't gonna be done in a single pass. Would 220v be better? Sure bigger welders are usually better but with a 5000 watt generator there are some practical limits to what even a bigger welder could do. It really boils down to the welders skill more than the size of the welder.
/ Weld hooks or bolt them ? #14
I'm not real wild about the style of these hooks but they're ready to bolt on.
10,000 Lb. Capacity Tow Hook Kit
I bought a couple, haven't decided what for yet :) but they would work for just about anything, sling, cable, rope, chain etc. and a higher capacity than a weld on chain grab hook, which is 6,600 Lb for 3/8 grade 70.
JB.
/ Weld hooks or bolt them ? #15
I agree about the skill level, I'll have to take your word about the multi pass part, I'm just a one pass man. One big, pretty sloppy pass :laughing:
Though I have surprised myself on some of my welds since I upgraded to dc stick. inconsistent though as far as looks goes, nothing I've welded ever failed, but wouldn't win a beauty pageant ether.
I don't know if the bucket wall is even 1/4, mine is double walled and I'm pretty sure the walls aren't 1/4. So I think you would need a heavier plate between or put it on a reinforced part of the bucket top.
JB.
/ Weld hooks or bolt them ? #16
JB.
Agree these are all considerations. It basically still comes down to the welder's skill and planning.
Bird poop welds hold much of this country together. The trick is to use enough of them.:D
/ Weld hooks or bolt them ? #17
I had a pro weld my hooks to a 1/2 X 3" piece of steel the entire lenght of the bucket: then bolted that to the top of the bucket with bolts near each side of the 3 hooks and one at each end . Looks nice and strenghtens the bucket too; painted it cub yellow.Congrats. on the cub/yanmar purchase I think you will love it,I do my EX 450 :) I also put a 3/8 piece on the underside ;but large washers would probably work also.
/ Weld hooks or bolt them ? #18
I don't know which would be better, I guess that would depend on your skills at either using a welder or if you have something that could drill metal. I chose to weld some hooks not on my bucket but on my bobtach part of my loader. The metal was thicker and with the bucket off I can lift more.
These are what I bought. They have a nice beveled edge along the bottom which makes the welding easier.
Weld-On Grab Hook - Grade 70 - 5/16" | AW Direct
/ Weld hooks or bolt them ? #19
When I bought my CCY tractor, I asked for three 3/8" hooks to be welded onto the bucket - one in the center and one in front of each loader arm. The fellow who did the welding used a triangular piece of 1/2" steel on the inside of the bucket, directly below each hook. The piece of steel fits into the angle formed by the top wall and back wall of the bucket, and it acts as a support bracket for the hook. The welder's comment was that the brackets would lend more support than a flat piece of bar welded along the top of the bucket's lip. I thought it was a nifty alternative, and the brackets cannot be seen unless the bucket is curled and raised a couple feet, or you crouch down to peer up under the lip of the bucket.
/ Weld hooks or bolt them ? #20
He's right...adding any kind of bend increases stiffness.
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
2017 Mahindra 1526 (A60462)
2017 Mahindra 1526...
DELCO ELIMINATOR 65042 HOT WATER PRESSURE WASHER (A59823)
DELCO ELIMINATOR...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
