Water filter operation.
/ Water filter operation. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
This is a new filter I have never delt with. I can't get the handle to move to shut it off. Is there a way to do it?
/ Water filter operation. #2
Possibly you have to pull up or push down on the handle as you rotate it to prevent accidental shutoff?
I pushed the red button to release the pressure and still can't move the lever.
/ Water filter operation. #5
From the manual....
Where the manual shows a wrench being used I'm guessing it takes a bit of beef to turn the handle. Do you have the handle which is also used to remove the filter housing?
From the manual....
I can't turn the lever to shut it off...
/ Water filter operation. #7
When I change my water filter I just close the ball valve open a faucet to release the pressure put a bucket under the filter and unscrew it change the filter.
/ Water filter operation. #8
That handle appears to be used to put the filter into bypass mode - it should be able to be turned with pressure in the system.
The manual page does show the wrench being used to move the handle - are you using the wrench to turn it?
I wound up turning the main off and releasing the pressure by the red button on top. I changed the filter that way. Still can't get the handle to move.
/ Water filter operation. #10
Those valves in the heads are usually a pain. Some of them break when you use them, then leave you without water. I would suggest doing it exactly the way you did.
/ Water filter operation. #11
I have two almost identical to the one you pictured. And yes - it is so difficult to turn on/off that I'm always afraid of breaking the handle off. The only improvement I've come up with was soaking it with WD40 - with synthetic additive. That seemed to have helped a good bit, but it sure didn't make it easy.
If you decide to go with the WD40 solution, if/when you get it turned off, soak it again and work in the WD40.
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
PT 4'x12' Pipe Trailer (A64912)
PT 4'x12' Pipe...
60" HANG ON PALLET FORKS (A65056)
60" HANG ON PALLET...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2017 Ford F-550 XL (A64911)
2017 Ford F-550 XL...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
