Water filter operation.
/ Water filter operation. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
This is a new filter I have never delt with. I can't get the handle to move to shut it off. Is there a way to do it?
/ Water filter operation. #2
Possibly you have to pull up or push down on the handle as you rotate it to prevent accidental shutoff?
I pushed the red button to release the pressure and still can't move the lever.
/ Water filter operation. #5
From the manual....
Where the manual shows a wrench being used I'm guessing it takes a bit of beef to turn the handle. Do you have the handle which is also used to remove the filter housing?
From the manual....
I can't turn the lever to shut it off...
/ Water filter operation. #7
When I change my water filter I just close the ball valve open a faucet to release the pressure put a bucket under the filter and unscrew it change the filter.
/ Water filter operation. #8
That handle appears to be used to put the filter into bypass mode - it should be able to be turned with pressure in the system.
The manual page does show the wrench being used to move the handle - are you using the wrench to turn it?
I wound up turning the main off and releasing the pressure by the red button on top. I changed the filter that way. Still can't get the handle to move.
/ Water filter operation. #10
Those valves in the heads are usually a pain. Some of them break when you use them, then leave you without water. I would suggest doing it exactly the way you did.
/ Water filter operation. #11
I have two almost identical to the one you pictured. And yes - it is so difficult to turn on/off that I'm always afraid of breaking the handle off. The only improvement I've come up with was soaking it with WD40 - with synthetic additive. That seemed to have helped a good bit, but it sure didn't make it easy.
If you decide to go with the WD40 solution, if/when you get it turned off, soak it again and work in the WD40.
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
Vanguard V215-PH 4WD Articulating Heavy Haul Agricultural Tractor (A66734)
Vanguard V215-PH...
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2019 MTD 42in Riding Mower (A66738)
2019 MTD 42in...
