Upgrading or adding LED lights
/ Upgrading or adding LED lights #1
Tasher80
DLT3000
I have a question regarding LED lights on my Craftsman DLT3000 lawn tractor.
1) Can I just replace the stock headlights with LED bulbs?
2) If I add some LED fog lights that are DC to the tractor can I run them on the same circuit as the stock headlights or will I need to run a separate line and switch from the battery?
/ Upgrading or adding LED lights #2
I have been wondering the exact same thing.
/ Upgrading or adding LED lights #3
LED's draw so little current that it would be hard to overcome circuitry.
Unfortunately to put lighting on an equal par you have to convert everything to a common denominator which is generally LUMENS.
Current draw for LED's for a given 'brightness' is something like 10/1. eg a bulb that draw 10amps will be in the range of 1 amp for a LED and give same brightness.
You seem to wish replacing 2 'filament bulbs' with 4 LED's, I'd say YES. (as long as you don't go overboard)
I was concerned because when I idle down my tractor the lights dim. I didn't want this to hurt any leds. I figured I would change out the headlights with led for lower wattage and also connect 2 x 18 watt led fog lights.
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2020 Bobcat E55 (A64126)
2020 Bobcat E55...
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
