TSC Chainsaw Sharpener
/ TSC Chainsaw Sharpener #81
Mount it with the sharpener sticking out over the edge so the chain can hang in a free loop under the clamp.
Clumping up the free chain doesn't work well.
Does your grinder have a reversing motor?
I notice some of the ones offered today do not.
I have a reverse switch on mine and like it. It is like filing in one direction from the outside of the tooth in on both sides.
You will get the feel of it when you do some sharpening. It is probably still an AC/DC motor so a reversing switch would be possible
if it doesn't have one.
Does the reverse really make that much difference? I haven't used a grinder yet so have no experience.
Yep, that's what I am doing, mounting on the edge of the table. The little desk it just the right size. I did not want to mount on my work bench since it won't be used that often.
Not sure about the reverse but will check. I was able to get the bolts today at lunch so maybe I can get it mounted tonight.
/ TSC Chainsaw Sharpener #83
It seems to be, to me. Others may not be that picky.
You know when you sharpen steel either with a stone or a file you are likely to get a bur if you are a bit too aggressive.
Some folks think that bur means sharp, and the bur is sharp. Easy to cut your fingers. But the bur doesn't last long when your cutting trees.
Any burs you do have you want to be balanced on the right and left teeth.
I grind so the rotation of the wheel is grinding from the outer side of the tooth down toward the center. That way there is no bur on the outer cutting edge.
Since the chain is not reversed to do the other side, just the angle of the holder is, then by reversing the motor rotation the other side is cut the same way, toward the center. That keeps a bur from forming on the outer lip of both sides. If you look at the profile of a tooth you will understand better what I am trying to say.
It is that outer edge of the side of the tooth and the front of the top of the tooth that do all the cutting. The rest is just an area to kick out the chips.
Chips are what you want. If your saw is making sawdust the blade is dull or not sharpened correctly.
My old grinder just has a toggle switch. In the center is off. Flipping it one direction causes clockwise rotation. Flipping the other way causes counter-clockwise rotation.
/ TSC Chainsaw Sharpener #84
i just mount mine on my steel work/welding bench in a set of holes i drilled for the sharpener. when im done sharpening, i remove the grinder and store it on the shelf. I do the same thing with my progressive reloading press. its only installed when i am using it. otherwise its stored away.
/ TSC Chainsaw Sharpener #85
i have a hf sharpener and i stick two stove bolts in the holes and then place the bolts in my vise and tighten up.this is where i do my sharping.when i am done i store in cabinet.
/ TSC Chainsaw Sharpener #86
Pretty sure it's an ac motor, not made to be reversible. Sparks and grit fly rearward-away from the user. I think it could get a bit nasty if it ran backwards and shot the debris toward you.
/ TSC Chainsaw Sharpener #87
In any case, wear a plastic face shield.
Even when the wheel is turning in the direction that throws the sparks back toward the machine they can bounce back and burn you.
/ TSC Chainsaw Sharpener #88
A little trick I read about in a small engine mag was to take a rectangular magnet and place behind the grinding wheel to "catch" shavings. Really helps cut down on the mess at the rear of the grinder.
Okay, I got it mounted to the small desk and it seems to be at a good working height when sitting in a chair.
According to the information sheet that came with my chain I need a set up like 60* 25*. I am thankful I always keep the package my chains come in and when switching out I put the old chain back in the package and hang it on the wall.
The instructions with the sharpener does not give much information on the angles needed. So after looking at several different ways of setting it up I decide to look at the actual chain package and the information sheet inside tells exactly what set up you need for the chain number you bought/use.
I was going to sharpen one last night but the wife says "no grinding smell in the basement":(. So I hope to try one chain in the next day or two and see how it cuts Saturday before sharpening the rest of them.
See pictures below.
David
/ TSC Chainsaw Sharpener #90
See pictures below.
David
Here is the one I got back in the 1970's. Looks very similar to yours. ( I added the light)
I have worn out 4-5 chainsaws and been through many chains over the years, but this thing just keeps on
going. I have mounted lockable or retractable casters under most of my shop tools, including this one, for easy mobility
and storage when not in use.
I'm going to have to purchase a new light weight chainsaw soon. Any suggestions?
Are any made with adjustable carbs these days?
/ TSC Chainsaw Sharpener #91
If you don't have a dedicated shop, here's my set-up solution. Over the years I've made saw horses cut to the length of my short stature that are good for painting or attaching certain tool used occasionally. Thus with a piece of 3/4 plywood nailed down, I can attach a chain sharpener, tool grinder, miter saw. These tools are bolted to the table. So by moving the truck out of the attached garage, I get a solid work bench to do these chores. It seems that my regular heavy work bench with its machinist vise and wood working vise is always covered with stuff and a bit high for sit down jobs, although it also has pre-drilled holes for mounting such tools in a standing position. When finished, the tool is cleaned up and put on a shelf ready for the next time. Cheers, Mike
/ TSC Chainsaw Sharpener #92
See pictures below.
David
Make sure you set and change the cradle angle for R/L cutters. In the picture I see it's set neutral. You won't like the results if you leave it like that.
/ TSC Chainsaw Sharpener #93
Since the lower end ones like our HF (still in the box) do not have indexed angles I am going to consider finding both 30 degree angles and drill a hole at both points and use a round pin so the angle is the same each time I grind the chains so they do not run 1-2 +/- degrees. I will still lock it down but not have to read the degrees off of the grinder scale.
Anyone tried that?
/ TSC Chainsaw Sharpener #94
You might want to consider a hole for the 25 degree setting as well. Most chain manufacturers recommend chisel cutters be sharpened at 25 degrees and chipper cutters at 30 degrees. The two grinders at my hardware store are set at 35 degrees off perpendicular for the motor / pivot arm with left/right adjustment made depending on cutter type.
/ TSC Chainsaw Sharpener #95
In our case 30 degrees works for us. I see the Timberline crank chain sharpener offers the option for 35 and 25 degrees and 30 seems to be the default.
/ TSC Chainsaw Sharpener #96
Don't assume that when you pivot the chain holder from the left degree setting to the right degree setting that the stop that controls the
tooth length will be correct.
It may be, but mine usually needs a little tweak. You want the left teeth and the right teeth to be the same length since as they get shorter
in length they also become shorter in height and are not doing their share of cutting.
I also mentioned the reverse wheel direction. If yours only goes one direction you may find when it is cutting from the center out on the one side that the chain tooth tries to raise up from the bar slot. Holding a little pressure on the chain beyond the tooth will keep it down. I have this problem if I have a brain fart and flip the switch the wrong way on the motor.
You just have to get the darn thing out of the box and use it...
/ TSC Chainsaw Sharpener #97
I guess I should take off Friday. :)
We have a 32"x60" steel table we need to move into the old garage that is under a big oak tree current. Then we need to mount the 6" vice which means drilling holes in the steel plate table, etc. After that we need to mount the sharpener to a base that I can clamp in the vice. Then there is lighting but we can improvise.
That kind of stuff can be done in colder weather but Friday it is to be 63F so I would like to tear down both of the Polaris 325 Magnums top end and see if we can remove the connecting rod cap and replace the bearing inserts w/o cracking the lower end case.
We do plan to leave two of the four chain on forks on the backhoe FEL to help us move the table close to its final resting place to save our backs some. Some how I find time to start more projects than I have time to finish. :) We do have some serious sawing to do but that can happen on cold days in Jan-Mar. Falling flat on my back mid Sep messed up my project schedule in a serious way. :(
I check last night and I do not have a reverse on this grinder.
DarkBlack, I'm not sure I follow what you are saying about the cradle angle being in the neutral position in the picture. I have it at 25*; is there something I am missing?
/ TSC Chainsaw Sharpener #99
I haven't read every entry on this thread, but find it very interesting in what I have read to see the different opinions Man vs. Machine. I sold saws and chains for many years and have sharpened by both methods a lot. I now have an oregon grinder set-up that works well for me. It is important to set the angles correctly when you are sharpening with a machine or by hand. I saw several notes that you were using 30 degrees as the sharpening angle. That is correct for chisel chain. For chipper chain, you should be at 35 degrees.
On my sharpener, I have steel grinding wheels plated with CBN. Because they hold their shape perfectly, I never have to dress them. Cost about $90 each, but worth it, if you are doing lots of sharpening. In addition, I have set up an air line to blow on the tooth as I am sharpening it. That helps to keep the tooth cool (and also the CBN on the wheel) and helps to avoid overheating the tooth and turning it blue. I would recommend cooling to anyone with a grinder, whatever type of wheel you use.
One other thing. There is a tool - a guage that you can lay on top of the chain and see if the rakers are too high. I recommend getting one, if you don't have it. If the rakers are too high, the saw won't dig into the wood far enough to cut well. If they are too low, you increase the risk of kick-back and that is very dangerous.
Cut safely my friends.
/ TSC Chainsaw Sharpener #100
Thanks Eddie. I have some machine shop experience from years ago with a lot of grinding but when I get our HF sharpener set up that will be my first go with powered system. I like the air idea. In business did you wash each chain with soap and water before the grind or just wipe off, etc?
