troy bilt tiller
/ troy bilt tiller #1
jweaver
HELP!!!! I just " inherited a troy bilt tiller. On the control neck is says Garden Way TH-1019 S/n 388218 built 1/3/79 it has an electric start 8hp briggs on it. Except for the gas and oil its all original 1 owner unit. I need to know what is the true model-horse??, It has fwd, reverse,slow and fast, so is that a 2 speed?? Any ideas how good the cd discs for these are?? or where can i get a manual copy? jim
/ troy bilt tiller #2
I believe your model is a Horse II (2). II stands for the amount of speeds. Pretty much identical to the Horse model in appearance from what I understand. Manuals are available online at Troybilt.com. Use "Horse II" as model number and do a search to see what comes up, and if it looks like yours. You have the largest motor on yours that they offered at the time.
/ troy bilt tiller #3
Also, owners manuals are available onsite for download - free:D
/ troy bilt tiller #5
It's actually considered a 4 speed, you have slow and fast available by changing the position of the lever, and a different slow and fast by hopping the belt over to the other side of both double pulleys (not so easily done when in the garden).
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2014 FORD F-150 (A67714)
2014 FORD F-150...
2012 PROCCO 130BBL (A67714)
2012 PROCCO 130BBL...
