Tractor classification — HP vs torque
/ Tractor classification — HP vs torque #81
Thats the difference between the performance of diesels and gas engines. Diesels when loaded drop in rpm but the available torque increases with that drop in rpm. Gas engines just drop in rpm and also drop the available torque.
That is not always true in tractor engines.
I can't find it now but Nebraska tractor tests at one time had both the gas and diesel Ford 3000 engines graphed and the gas had torque number which extended about 150 RPM Lower down to around 800 RPM IIRC
a quote from yesterdays tractors:
If you were to root out the nebraska test results for the Ford 3000 and 5000 tractors in both the gasoline and diesel versions using the 175 cid and 233 cid engines respectively I believe you'll find that they have almost identical curves... much to the point that the profiles are the same excepting that the spark engine will probably achieve peak torque at 100-150 rpm faster than the diesel. This will result in the spark engine being a bit prouder on the top end because the torque rise was basically identical to the diesel. Again... SAME cam shaft in both. Same lift. Same duration. Same stroke and displacement.
Interesting bore / stroke as well being "dead square" engines @ 4.2" x 4.2"
/ Tractor classification — HP vs torque #82
Sorry you don’t get it.
Properly geared the 110 hp engine could move the Case just fine, but likely not very fast. Torque can be mutipled via gearing. HP cannot be multiplied by gear ratios.
BINGO
… Diesels when loaded drop in rpm but the available torque increases with that drop in rpm...
That kinda gets back to my original question…
The guv’ment, in its infinite wisdom, decreed 25 HP was the cutoff for their emissions mandate…
I could create an absurd argument that, if one was to take the CASE steam tractor from the video, scale it down to 25 HP, the torque created by that particular engine would vastly outpace any modern CUT…
Obviously, a manufacturer isn’t gonna create such a monster, but the amount of torque produced by the various range of consumer aimed diesel engines is different… my original question was: Why don’t manufacturers boast about the differences in torque produced by their 25HP engine as opposed to the other manufacturers engines?
/ Tractor classification — HP vs torque #84
. . . Why don’t manufacturers boast about the differences in torque produced by their 25HP engine as opposed to the other manufacturers engines?
In my opinion, it seems the answer is obvious based on this thread. Most people do not understand torque and its relationship to hp and engine rpm. They are likely comfortable, even if not knowledgable, with hp.
This is likely also true for the marketing folks at the various manufacturers. They too don’t understand or appreciate torque.
/ Tractor classification — HP vs torque #85
Because there are MANY MANY more important things to compare when tractor shopping than torque. HP is how fast work can get done. And thats what is important to just about everyone. How fast can I plant a field, how long is it gonna take me to mow my lawn.
How big of a bushhog or tiller to buy is a function of HP and NOT torque.
You can take a 100yr old steam tractor with 110hp and you can take a 110hp modern tractor and do the SAME RATE of work. Sure....given the traction and weight.....you may only be able to pull an implement 1/2 or 1/3 the size......but you can do so at 2x or 3x the speed.....hence the SAME RATE or work being done.
If you want to talk about lower RPM torque.....or what the curve does when an engine starts lugging.....you can ALSO get that data with a HP curve. Also called area under the curve....rather than looking at peak HP.
But when it comes to comparing tractors.....you can shop a deere vs kubota vs Massey vs mahindra vs whatever you want.....as long as you are shopping the same "class" of tractor with equivalent HP.....while there "may" ve some slight variations in engine torque....its not gonna be anything to quarrel about when tractor shopping and they will all be equally capable.
People constantly questioning torque.....or wanting to compare old steam tractors....or those saying things like HP shouldnt be used to rate a tractor and torque is a better number....those people clearly have zero understanding between the relationship between torque and HP.
Torque is nothing more than how much force can be applied. Nothing more, nothing less. HP is nothing but a number comprised of TORQUE with a time element. IE: how fast can you apply said torque.
/ Tractor classification — HP vs torque #86
Till you get to two 25HP tractors, both diesels and one is a 77 cu.in. engine and the other is over 100 cu. in.. No doubt in my mind as to which one is likely to out pull and work the other. Especially if I'm not afraid to turn the fuel screw a bit.
/ Tractor classification — HP vs torque #87
Horsepower is just a mathematical derivative of torque. All hp/torque curves cross at 5252 rpm. I can chain my two 2 cyl. 26 hp zero turn mowers to an old single 14hp Economy Power King which will drag them all over the farm. 52hp vs 14, the two mowers outweigh the Economy.
I pulled my farriers Cummins diesel Dodge 3500 out of a snowy ditch with my 6 cyl F150, 170 hp. Loaded Dodge probably 10,000#, uphill...he forgot left parking brake on. Pulled probably 3 mph, no chains or weight.
Hp= speed, torque pulls in a sense.
/ Tractor classification — HP vs torque #88
One could also say that torque is just a mathematical derivative of horsepower. Horsepower and torque are indeed directly related to each other and the engines speed.
5,252 rpm is the number of revolutions required to make the hp and torque equal numerical values (i.e., X hp and also X ft lbs). 5,252 rpm is not even achievable in most diesel engines.
/ Tractor classification — HP vs torque #89
Actually.....all else being equal....they will pull and work the same.
But odds are if one is 77cu in and another is over 100 cu in they are probably different size machines.
Put those two engines in the SAME or similar tractors (weight, tire size, traction) and the results will be the same.
/ Tractor classification — HP vs torque #90
Has nothing at all to do with HP or torque. Its all about traction. Both the zero turns can spin the tires while doing so. Just because the powerking can drag them doesnt mean they can work as hard, or have less torque. It simply means they arent designed for pulling something....they have slicks for tires to not tear up your lawn....
But tell me.....which one can pull a 60" mower through tall grass faster without bogging the engine?
You comparison is about as silly as hooking a semi to a 200hp farm tractor.....driving out into the middle of the field and seeing which one will pull the other. The semi obviously has more HP, more torque, and a bigger engine.....so why would it fail to pull a farm tractor around in the field?
/ Tractor classification — HP vs torque #91
I doubt it, I would expect the larger engine to have a better working torque curve and the ability to lug and pull when the smaller displacement will bog down and stall out.
/ Tractor classification — HP vs torque #92
I'd expect the torque curves to be similar in respect to their peak. IE: percent torque rise vs RPM.
In other words.....if RPM drop 10% and torque rise is 15%....I'd expect a similar curve profile for both engines....
For example....kubota D1105 (68CI 25hp engine) vs kubota D1705 (100CI 25hp engine). These are used in the B2601 and L2501. BOTH the same HP spec
The B2601 engine is rated at 25hp/3000RPM and peak torque of 52ft-lbs at 2200rpm
The L2501 engine is rated at 25hp/2200rpm and peak torque of 72ft-lbs at 1500RPM.
Both engines have the peak torque occurring at ~70% of rated (max) engine speed
While operating at 70% of max engine speed (where peak torque is) BOTH engines are still producing ~20-21HP.
While operating at max (rated) engine speed....the B2601 retains 85% of its peak torque #...which puts it at 44ft-lbs. The L2501 retains 81% which puts it at 59ft/lbs
At ~60% the rated engine speed.....
The B2601 engine @ 1800rpm is making 52 ft-lbs and 18HP
The L2501 engine @ 1400rpm is making 70ft/lbs and 18HP.
Look at the graphs.....compare the numbers. YES, the L2501 engine produces more torque. But the 2601 can match the work load by making more RPM's. Everyone seems to forget that you can MULTIPLY torque through gearing. But you CANNOT change horsepower through gearing.
To put it quite simply.....The L2501 makes more torque.....but the B2601 makes proportionally more RPM's. All you gotta do is gear them equivalently and voila.....darn near identical curves.
/ Tractor classification — HP vs torque #93
Every tractor I have ever driven, when in its lowest gear range and lowest axle range, will spin its tires and NEVER stall out.
Yes, you can make them stall, but only by either intentionally doing so or ignorantly doing so.
/ Tractor classification — HP vs torque #94
The government used the most sensible easily quantified metric on fuel consumption. There's a given amount of energy in a gallon or cubic foot of fuel, and thus rate of fuel usage is linked directly to horsepower through net efficiency. Since all manufacturers aim to maximize efficiency for a given engine type, and because emissions are also related directly to fuel consumption for a given engine type, horsepower was the most sensible and simple metric to use for setting a threshold.
/ Tractor classification — HP vs torque #95
They may by your manipulation of numbers. But, from my seat of the pants from quite a few years of tractors and trucks working them, especially with them being geared transmissions under load the larger engines with similar or even less HP all seemed work better in the fields under normal varying conditions. Most of our operations are in the 3-5 mph range with tillage and planting being closer to 3mph. Mainly because we work quite stoney ground and faster speeds in stones just means more down time from broken parts and wrenching. Mowing is done faster usually and tedding and raking a bit faster. More user friendly torque is what makes for nice smooth operation, I have no use for wound up bumble bee engines.
I can sit all day behind a large engine at 1400-1600 rpm and enjoy it much more then an engine at 2400- 2800 rpm.
/ Tractor classification — HP vs torque #96
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A59230)
2016 Nissan Titan...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2012 International WorkStar 7400 Service Truck, VIN # 1HTWGAAR1CJ453408 (A61165)
2012 International...
UNUSED ZJG ZJ-08 MINI DIGGER (A60430)
UNUSED ZJG ZJ-08...
2023 Ford Expedition SUV (A59231)
2023 Ford...
