Tooth bar uses?
   / Tooth bar uses? #11
A Public Safety Announcement!! I was able to do the previous with trees/shrubs with <5" trunck diameter. I tried this technique with a dying plumb in the ~5" size and it started to put me on three wheels :eek:. I will try the old long chain off my drawbar for this tree. Jay
   / Tooth bar uses? #12
jbrumberg
I have pulled out sagebrush with the toothbar but never anything any bigger. Might have to try it on something bigger, with a large bit of caution though.
   / Tooth bar uses? #13
I am quite happy with my toothbar. It is mounted on a 61in HD bucket and works great for general landscaping and as previously stated adds capacity to the bucket for carrying things. I also got the cutting edge and will swap them in the winter time. Where are you in VT - which dealer are you talking to if you don't mind me asking. You can also PM me if you want to hear about my dealer experience which was and is great.
Cheers,
Brad
   / Tooth bar uses?
WOW… What a great response for the new kid on the block… I appreciate all the helpful info. The tooth bar is now top on the list.
I thought you guys would like to see some pics of what I am up against after building this new albatross (I mean house)… which we are going to be digging out from underneath for a long time. I don’t think the tooth bar can help me with that though. As mentioned, a 2320 or 2520 is in the near future – hopefully a month or two. So for now I’m just planning on what to do with it… lots of landscaping projects, cutting up and moving wood, etc.
As you can see our terrain is quite hilly with flat areas where the house sits. Around the house I plan to scrape the grade down and build rock walkways that extend around back to rock patios surrounding the deck. Lots of trees to plant too. You can see from the longer shots that there was a beautiful 200 year old stone wall that our clueless site guy wiped out and left in a pile of rocks. Do you think a 2320/2520 can handle those rocks? Or should I rent a big machine with a FEL and BH to do the work? The plan is to rebuild the wall from the edge of the driveway to the woods on the right as you drive up. Some of those rocks are huge and may be hard to get a perspective on from the pics. But it looks like what you did JDFANATIC with your 2210 was no problem. That 2210 looks like a workhorse! In any case, the tooth bar will definitely help.
Our driveway is gently sloping about 2000 feet. I’ll have to get a blower to take care of the winter months and a rake or BB to do the grooming.
We have about 11 acres, half of which is woods. I want to clear another 2 to 3 acres where there are hundreds of feet more of stone walls. A horse barn to the left is in the future as well. I think after cutting trees, the FEL with tooth bar will tear through the smaller stuff and make way for the barn & lawn. Can’t wait to get started.
What do you guys think the best tires will be for this land? R4’s over Turfs? In the spring we get quite a bit of water runoff around the land so I’m a bit worried about R4s tearing up the lawn. But I don’t think the turfs will work well in the woods – especially hilly woods.
Any other thoughts on implements to tame this land?
Anyways, thanks again for the info.
   / Tooth bar uses? #15
Regarding the choice of tires: the R4's seem to be a popular choice, and when ordering my tractor I specced those out (not out of any particular experience, but just the fact that I liked the "manly" looks of the industrial tread). The JD dealer strongly advised me to consider the R3 turfs instead. His reasons (closely matching those of an independent and highly knowledgeable person) were the following:
* on a small tractor like anything in the 2000 series the turf tire "floats" better under most ground conditions
* the R3's will make larger surface area ground contact due to the tire and tread shape (and lower operational pressure), effectively increasing grip
* when spinning in wet clay both the R3 and R4 will quickly turn into a slick ball of slime, and they suck about equally. R1 ag tires would help in these conditions.
* for winter conditions and heavy snow a turf tire with chains will provide the best grip, bar none (short of running on tracks)
I would usually be suspicious of a dealer pushing me one way or another on a choice like this, but he had no obvious reason to do so; there was one 2320 with R4's arriving at the dealership quickly, and going with R3's just made the tractor a special order and added to the wait time. I got similar feedback from several other sources on this question (including several people on this board).
Now that I have the tractor, I have worked it in my woods and my fields, as well as digging with the FEL and moving dozens of yards of material. I could not find fault with the turfs, and could recommend them to anyone. That is not to say that I am poo-pooing the R4's as the only fair way for comparison would be to run two tractors with the two different treads side by side. But my experience has been that the R3's are giving me superb grip under normal or dry conditions, but they are NOT recommended for digging in a clay pit in the rain ;). As an added bonus, they have been forgiving on my lawn when I did some sharp turns with 4WD engaged. As far as the winter performance goes, I will be able to speak to that in six months.
   / Tooth bar uses? #16
VTtractorguy,
What a beautiful spread you have there! I think you have a definate need for a box blade, FEL, and probably a few other implements! :) I have turfs on my 2210, but agree they are useless in wet clay. A friend on mine has the industrials on his 2210 and swears by them (and he has golf course-like turf). I think that argument will go on forever.
   / Tooth bar uses?
Thx Efreet and JDFANATIC. Agreed on the tires. I'm thinking I'll do the R4s as I do have clay around here and want to go in the woods to do clearing. I've been told that there is a new type of chain that works well with these tires... Something about extra lugs that give better bite when some fall between the bars. Not sure what that is but we'll see.
JD, you think a BB is the better choice for this driveway as opposed to a rake? Is it also good for smoothing woods dirt once the roots & stumps are out?
This is the third house we've built (glutton for punishment) and is by far the one that needs the most landscaping.... I really need this machine. :(
   / Tooth bar uses? #18
To clarify: I ended up going with the turf tires, and they work for me great, including the woods and the field. The point about clay was that BOTH the R3 and R4 seem to struggle in wet clay just about equally, and only an ag tire or tracks will perform significantly better under these conditions. The turf tires seemed to have some advantages on a small tractor, and so far they are working for me just fine. I am not sure whether you are planning to use your tractor in the snow, but given that you are in Vermont you very well might. I have heard some pretty strong statements in regards to the best tire choice in snow, and it always seems to be "turf tires with chains".
Regarding the attachments: I have a box blade, and it would be my first choice for driveway maintenance. I do not have a landscape rake, although I am planning on getting one eventually for certain types of finish work. But for leveling, smoothing, spreading stone, etc the boxblade is likely to be your most versatile tool.
   / Tooth bar uses?
Yup... going to be snow blowing that long 2000' driveway and will be doing some loader work to pile the snow high in areas. Maybe the turfs are best. I guess I can put the chains on for deep woods work if need be.
Sounds like the BB will be it for the driveway. What uses do you think the rake is better than the BB?
   / Tooth bar uses? #20
VTtractorguy:
Nice pictures :D! I see a tiller in your future for garden and flower beds as well as an old beat up junkyard car/truck hood (AKA "stone boat") to help you skid the larger rocks that you can not lift. Jay
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A55787)
2017 JLG Skytrak...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
Hydraulic Power Unit S/A Towable Pump (A55787)
Hydraulic Power...
1969 REO M35 2.5 Ton Military Truck 6x6 (A55788)
1969 REO M35 2.5...
