The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,651
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,652
The Kubota L3800 has an overall width of 55.1 inches. For my money, I would not go larger than 50 inches and a single lid. Lighter, less expensive and a better match for that particular tractor in my opinion. It will be your favorite, most valuable and productive accessory; doubling the utility of your rig.
You've been brainwashed. Must be all that fake news about grapples in the MSM. Sad. ;)
Back to earth. You do bring up an important point that new (first) grapple buyers are often confused about: there is no reason to have a grapple as wide as your tractor's standard bucket. If you are pushing through brush the grapple acts like the prow of a ship...it pushes the brush away from the sides as you drive forward. Better to have a narrower grapple that can take advantage of physics and concentrate force rather than disperse it. My grapple is 48" and there are more times when I wish it were even narrower than times I wished it was wider. Of course this assumes you are doing general land clearing and utility work. For cleaning up construction debris a full width grapple is probably better as you are picking up lots of little individual bits of junk on the ground.
You've been brainwashed. Must be all that fake news about grapples in the MSM. ;)
Back to earth. You do bring up an important point that new (first) grapple buyers are often confused about: there is no reason to have a grapple as wide as your tractor. If you are pushing through brush the grapple acts like the prow of a ship...it pushes the brush away from the sides as you drive forward. Better to have a narrower grapple that can take advantage of physics and concentrate force rather than disperse it. My grapple is 48" and there are more times when I wish it were even narrower than times I wished it was wider. Of course this assumes you are doing general land clearing and utility work. For cleaning up construction debris a full width grapple is probably better as you are picking up lots of little individual bits of junk on the ground.
nooooo, Island, we can't have any MSM references in my prized grapple thread, especially with a TX guy and a RI guy in the room! :eek:
Travis
In other news....
This past Saturday, I helped my father in law hook up a 50" Wicked Grapple to his brand new Kubota L3301. :cool2:
I took lots of pics!
Oh, what an awesome match made in NC!!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,655
Travis
Don't worry. Only grapple politics allowed on this thread. Small grapples and small hands go together.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,656
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,657
In other news....
Travis
OK that did it Travis I'm ordering one. Did you need to make any changes in the grapple's standard hose lengths or connectors for your Kubota? The LA534 (I think that's the FEL on the B2650) is probably about the same as your father's. I may as well have it come with whatever connectors and hose lengths the work the best.
We added a little extra length, making them 60" long. There's a guy over in our EA Channel Facebook Group who just received one last month for his B2650. He posted a few pics back on Jan 17, so check it out if you're on FB. Our couplers are a different series from the Kubota/Land Pride, so we sent an extra pair of couplers for his tractor and added $20.
His outlets are in the center, but they are pointed to the side instead of forward. This configuration will require longer hoses or we can include 90 degree fittings(that's what I sent him).
Feel free to give me a call if this makes no sense. I am usually typing between phone calls & emails, so I frequently look back at my posts and say WTH. :laughing:
Travis
Here's one pic of Patrick's rig:
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,659
Thanks I'll be in touch.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #1,660
Milo, great choice. The 50" is literally perfect for your B2650. Had they made one ten years ago I would have bought it for my CK20.
One question related to connectors and hose lengths: how are you going to run hydraulics for your grapple? I used a rear remote on my CK20 and I have a WRLong diverter valve on my DK40se. Both work just fine. I actually have a moderate preference for the rear remote set up so long as the control lever is convenient to your right hand. The other advantage of using a rear remote is that it can be utilized for other very useful hydraulics when you are not grappling. For example you could run a hydraulic topping lift.
Generally installation of a couple of rear remotes costs about the same as installing something like a WRLong diverter valve. More bang for the buck IMO.
Also, EA will provide hoses that are of adequate length to reach your loader torque tube with enough slack to fully curl and dump without stretching the lines. You will notice however that the necessary slack becomes a snagging hazard when grappling as the hoses flop about and droop. EA sells an upright spring with hose clamps on it that bolts to the grapple and is a simple and effective though rather expensive solution. Travis can quote it for you or you can take a look at the principle on their website (it is commercially available, EA is a reseller and it is not a EA manufactured product) and with and old garage door spring, a welder and a grinder you can make your own for peanuts.
2019 Peterbilt 520 Trash Truck (A55973)
2019 Peterbilt 520...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2001 Club Car Precedent 48V Electric Cart (A55853)
2001 Club Car...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
2014 CATERPILLAR 304E CR EXCAVATOR (A52707)
2014 CATERPILLAR...
