The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,641
Man i want one of these EA Wicked grapples on my new to me Kubota L3800..really I'd love the whole set up to be EA especially since i'm a NC native. I'm trying to justify to myself the addtl expensive of the other attachments i.e. box blade, scrap blade, PHD, & cutter) from EA vs LMC. Being a weekend warrior, I'm not sure i can justify the addtl expense though..daily or weekly yes, but occasional use, I'm not as sure..
for the grapple in a 60" wide one, Travis seems to think a single lid vs dual lid is better. any of you current owners have an opinion on it as well? huge difference in capability going for the 50" grapple?
thanks for the feedback
If you want my opinion, and I don't know if you do or don't, for an L3800 which has less lift capacity and weight a 1000 lbs less than my Kioti DK35se, I would not go bigger than the 50 inch single lid. That is what I have, and I can tell you I haven't been able to tear it up in the years I have owned it. My tractor has about 300 or 400 lbs more lift and quite a bit more breakout than yours. I had an L3400 which is the predecessor to your tractor and know them pretty well.
Unless you have a need for a wider grapple, and maybe you do, you will profit by having the lightest, toughest grapple you can buy that won't overload your loader's capacity. And for your tractor that grapple is the 50 inch single lid. This is just one mans opinion, but I have had mine now for some time so make of it what you will.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,642
I forget whether I like single or dual more....Travis, please remind me. :D
Now that there is funny, I don't care who you are.:D
To uncblue:, You would have to know ole Island Tractor here to know he is just about the most rabid supporter of the single lid variety to a fault...:shocked:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,643
It seems that Travis is either on vacation or just not willing to take the bait. Maybe he forgot my preference too. In any case, I have reviewed my photo files and it appears that I have a 48" single lid grapple that seems to have done everything I've ever asked of it for the past ten years. I have photos of the same grapple mounted on my little 20hp CK20 which has 1070lbs of lift and also photos of it mounted on my DK40se with 2760lbs of lift.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,644
Thank you all for the personal experiences & the pics. It makes it a much easier decision. I'm going to check price diff & weight diff between 50 & 54". I think either of those will work well & be big enough if I decide to move up to a larger tractor.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,645
You might also take into consideration jaw opening size. As I recall the 50" only opens to 32" which is fine for many purposes. The 54" opens I believe to about 37" which gives a bit more flexibility in grappling big logs, stumps etc. Just as a point of reference, the grapple in my photos has an opening width of 42 or 43".
Another factor that I'd think about is grapple weight. Whatever the grapple weighs must be deducted from your spec'd lift capacity to get net lift capacity. Travis can get you the exact weights and as I recall the 54 weighs maybe sixty or so pounds more than the 50. Not a big deal if your loader is rated for above 1000lbs or more but a consideration if the loader has less lift.
Both the 50 and 54 are excellent grapples. Can't really go wrong with either. If you really see a bigger tractor in your future you might err on the side of the 54.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,646
The 50" wide one only raises the lid to a 30" opening, the 54" raises the lid to 37"
274 lbs on the 50" to 349 lbs on the 54"
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,647
Things that you buy where you know at least once during their useful life you will push past the manufactures recommendation? Buy once cry once.
IIRC, you are on the record for a triple lid.
I do recall his proclamation demanding just that & all was great throughout the lands!!
Then we realized he was just off his meds. :laughing:
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,650
The Kubota L3800 has an overall width of 55.1 inches. For my money, I would not go larger than 50 inches and a single lid. Lighter, less expensive and a better match for that particular tractor in my opinion. It will be your favorite, most valuable and productive accessory; doubling the utility of your rig.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,652
You've been brainwashed. Must be all that fake news about grapples in the MSM. Sad. ;)
Back to earth. You do bring up an important point that new (first) grapple buyers are often confused about: there is no reason to have a grapple as wide as your tractor's standard bucket. If you are pushing through brush the grapple acts like the prow of a ship...it pushes the brush away from the sides as you drive forward. Better to have a narrower grapple that can take advantage of physics and concentrate force rather than disperse it. My grapple is 48" and there are more times when I wish it were even narrower than times I wished it was wider. Of course this assumes you are doing general land clearing and utility work. For cleaning up construction debris a full width grapple is probably better as you are picking up lots of little individual bits of junk on the ground.
You've been brainwashed. Must be all that fake news about grapples in the MSM. ;)
Back to earth. You do bring up an important point that new (first) grapple buyers are often confused about: there is no reason to have a grapple as wide as your tractor. If you are pushing through brush the grapple acts like the prow of a ship...it pushes the brush away from the sides as you drive forward. Better to have a narrower grapple that can take advantage of physics and concentrate force rather than disperse it. My grapple is 48" and there are more times when I wish it were even narrower than times I wished it was wider. Of course this assumes you are doing general land clearing and utility work. For cleaning up construction debris a full width grapple is probably better as you are picking up lots of little individual bits of junk on the ground.
nooooo, Island, we can't have any MSM references in my prized grapple thread, especially with a TX guy and a RI guy in the room! :eek:
Travis
In other news....
This past Saturday, I helped my father in law hook up a 50" Wicked Grapple to his brand new Kubota L3301. :cool2:
I took lots of pics!
Oh, what an awesome match made in NC!!
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,656
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,657
In other news....
Travis
OK that did it Travis I'm ordering one. Did you need to make any changes in the grapple's standard hose lengths or connectors for your Kubota? The LA534 (I think that's the FEL on the B2650) is probably about the same as your father's. I may as well have it come with whatever connectors and hose lengths the work the best.
We added a little extra length, making them 60" long. There's a guy over in our EA Channel Facebook Group who just received one last month for his B2650. He posted a few pics back on Jan 17, so check it out if you're on FB. Our couplers are a different series from the Kubota/Land Pride, so we sent an extra pair of couplers for his tractor and added $20.
His outlets are in the center, but they are pointed to the side instead of forward. This configuration will require longer hoses or we can include 90 degree fittings(that's what I sent him).
Feel free to give me a call if this makes no sense. I am usually typing between phone calls & emails, so I frequently look back at my posts and say WTH. :laughing:
Travis
Here's one pic of Patrick's rig:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,659
Thanks I'll be in touch.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,660
Milo, great choice. The 50" is literally perfect for your B2650. Had they made one ten years ago I would have bought it for my CK20.
One question related to connectors and hose lengths: how are you going to run hydraulics for your grapple? I used a rear remote on my CK20 and I have a WRLong diverter valve on my DK40se. Both work just fine. I actually have a moderate preference for the rear remote set up so long as the control lever is convenient to your right hand. The other advantage of using a rear remote is that it can be utilized for other very useful hydraulics when you are not grappling. For example you could run a hydraulic topping lift.
Generally installation of a couple of rear remotes costs about the same as installing something like a WRLong diverter valve. More bang for the buck IMO.
Also, EA will provide hoses that are of adequate length to reach your loader torque tube with enough slack to fully curl and dump without stretching the lines. You will notice however that the necessary slack becomes a snagging hazard when grappling as the hoses flop about and droop. EA sells an upright spring with hose clamps on it that bolts to the grapple and is a simple and effective though rather expensive solution. Travis can quote it for you or you can take a look at the principle on their website (it is commercially available, EA is a reseller and it is not a EA manufactured product) and with and old garage door spring, a welder and a grinder you can make your own for peanuts.
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2013 Chevrolet Silverado 1500 (A64194)
2013 Chevrolet...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
