T post removal
/ T post removal #31
I use one similiar to yours, but I don't remember paying $25 for it ( but that was several years ago). Getting on / off the tractor to move on to the next
T-post is the most work when working alone. For few posts I can deal with it. But I wouldn't want to work alone if there were a lot of posts to pull .
Cheers,
Mike
Agree, if you have to do a bunch of posts it is a major pain getting on and off equipment. I helped a farmer yank all the posts around a huge field and we used just a chain on a loader. Two quick wraps with the chain and the post is out. He would lower the bucket and I throw the post in and move to the next one. We moved along pretty fast.
/ T post removal #32
All my steel posts are T-145. The HD version of standard T-posts. I've never had to pull a post where I could not get the tractor. So.... it's a chain loop across the bucket and around the T-post. Angle the bucket so the top and the lip touch the post at the same time. The post never bends.
I have MANY T-posts where I could never get my tractor. If I had to pull any of those - my HI-Lift jack would be my choice.
I have some 675 T-posts for the barbed wire fence around my 80 acres. In all of my 40+ years here - only had to pull half a dozen or so.
Small peanuts.........
/ T post removal #33
When I want to pull a post I simply wiggle it gently until is starts to loosen and then I move it in a circular motion and they lift out with one hand. Takes no time at all and a lot less time than a tool or driving the tractor from post to post. It also requires very little effort as long as the ground is soft. I generally do this after it rains. I have never bent one of the heavy posts doing it this way. Once in a while I'll get a stubborn one and then I just wrap a chain around in near the ground and pull it out with the tractor.
/ T post removal #34
I worked with a local farmer to help him get a patent on a T-post removal device that attaches to the bucket of your tractor.
Doesn't look like the design is in stores yet.
/ T post removal #35
Lots of ways to skin the cat.
If I have a lot of posts to pull I use a FEL mounted tree and post puller I can park my butt in the cab, and it is effortless but not very fast. I do not care that much about efficiency. A couple of times I have wanted to remove some small trees near the posts so the T&P puller let me do both jobs.
If I have a few to pull, it is not worth the time to remove the bucket and attach the T&P puller. Chain is simple enough for me.
Use what works for you.
Engine (A59228)
Engine (A59228)
2014 Dodge Grand Caravan Van (A59231)
2014 Dodge Grand...
RK25 PERFORMANCE SERIES TRACTOR (A62130)
RK25 PERFORMANCE...
Kuhn FC400RG (A60462)
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
